#26 |
Kung Fu Master
![]() Join Date: Oct 2005
Re: Straight axle duramax build
Yeah, very clean install, nice job!
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
#27 |
6>8 Plugless........
![]() Join Date: Sep 2007
That looks great! Pretty cool to see the ford coil stuff worked great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#28 |
Chevys Kick A$$
That's sick looks killer from here keep up the good work. I can't wait to see some more pictures of it!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#29 |
Vintage 4x4s
looking forward to more pics of it done. Great work, really like what you've done!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#30 |
are those stock height super duty coils that you used? looking into doing the same style SFA with my 06 duramax. sick build buddy
#31 |
Thanks sir. They are 4" lift springs. I imagine it's possible to run a stock spring but I think you would have to look into the triangulated 3 link style just for clearance. Check out wfo they pretty much have everything to straight axle these
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
#32 |
thanks for the info, and yeah I've talked with the boys at WFO, knowledgeable guys with great products. looking forward to some more pics of your build
#33 |
. Looking forward to seeing the pics once it's buttoned up. . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
#34 |
I'm just glad to be here!
What are you doing for the front drive shaft? I have an '06 2500HD Duramax that you now have me thinking of doing this...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#35 |
Stock shaft with an offset u joint. There is numerous ways of doing it but this is the most simple and cheapest. The other thing would be slip yoke eliminator at the tcase and run a new d line
#36 |
Another question about this. For the ford axle, did you use all the stock ford steering links?
#37 |
Yes factory ford steering. Wfo sells a tapered pitman arm that is made for it
#38 |
I have an 06 duramax and spend most of my time on duramaxforum.com but came across your sas thread while doing some research for my future project. Super clean man! I was planning to do the same thing using 05+ ford axle with ford coil buckets and whatnot. I'm also located in marysville, I would love to check out your setup some day and to maybe pick your brain about what all you used. I've been looking at WFO's stuff and like I said, your setup is exactly what I've been looking for.
Thanks in advance! |
#39 | |
#40 |
