Old 05-20-2016, 08:56 PM   #51
BlueJeep
BlueJeep's Avatar
Re: Putting Camaro front in 55 second gen
I used this, worked great and inexpensive compared to AN stuff.
http://www.amazon.com/S-U-R-R-Auto-Parts-KP1200-Re... http://www.amazon.com/S-U-R-R-Auto-Parts-KP1200-Re...
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-23-2016, 08:24 AM   #52
Kim57
Kim57's Avatar
Tank fit in there real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-24-2016, 01:10 AM   #53
mygirlz55
Is it necessary to flip the front bumper or can it be installed normal?
mygirlz55 is offline   Reply With Quote
Old 05-24-2016, 07:23 AM   #54
Dave0
No, I think it just looks better...
Dave0 is offline   Reply With Quote
Old 05-24-2016, 08:00 AM   #55
Bobbyh68
Dave
I'm in the middle of doing the same front end swap, putting a 79 firebird on my 56. I noticed my 6.0 engine sits more to the rt./passenger side about an inch.
Does yours? How did you address this issue?
Like the rear hangers and fuel tank, wish I would of went that route.
Bobbyh68 is offline   Reply With Quote
Old 05-24-2016, 08:14 AM   #56
Kim57
Kim57's Avatar
I flipped mine.
I think it fits the truck better.
Kim
My build thread
Old 05-24-2016, 05:11 PM   #57
Dave0
Originally Posted by Bobbyh68 View Post
Dave
I made mounts, I made them so the exhaust is centered. I think its still offset some, just make sure the engine and transmission is parallel to the rear end. You want the engine and tranny offset the same.
Watch out, the steering box gets close to the power steering pump. Thats why I raised mine up so high...
Old 05-24-2016, 06:53 PM   #58
Dave0
Modified cross member for drive shaft. Here is a pic of the notch I cut in the frame, (lt side only) for fuel tank. And the location the filler tube lands...
Old 05-24-2016, 07:12 PM   #59
tmoble
That looks good. More pics whae the tank is mounted up? maybe one from the back? Does it hang down much?
tmoble is offline   Reply With Quote
Old 05-24-2016, 07:20 PM   #60
Dave0
Not terrible, When I get it back in, I will take a better pic...
Old 05-25-2016, 08:20 AM   #61
Kim57
Kim57's Avatar
Tank fits in there real nice.
Kim
My build thread
Old 05-26-2016, 06:39 PM   #62
Dave0
Has anyone successfully put a 5.3 in a 55 to 59 with the master cylinder on the frame?
Im not seeing room for tranny cross member brakes and exhaust...
Old 05-26-2016, 06:57 PM   #63
Kim57
Kim57's Avatar
A few pics of mine with a Chevelle front clip and a 6.2/4L70 in it.
It has a CPP cross member and hydro boost that has the master set back under the bed .
There was room for it under the cab I just didn't want it there.
You should have the same room with a Camaro clip and one of the smaller vacuum power boosters.
Kim
My build thread
Old 05-26-2016, 07:16 PM   #64
Dave0
Thanks Kim! looks good...
I dont mind making a cross member, but im not seeing the room! I could if I moved it down like you did...
Old 05-26-2016, 07:24 PM   #65
Kim57
Kim57's Avatar
The height of mine was dictated by the height of the oil pan.
I have a CTS pan on it and raised the engine so the pan doesn't hang below the cross member.
Kim
My build thread
Old 05-26-2016, 07:31 PM   #66
Dave0
Hard to tell but your engine looks like it sits back further than mine...Did you have to modify the cab to get the tranny to fit?
Old 05-27-2016, 12:24 AM   #67
dsraven
Try the hydroboost you will have more room. Maybe better brakes too because under floor boosters are usually smaller.
Old 05-27-2016, 09:25 AM   #68
Kim57
Kim57's Avatar
Set back just enough to clear the steering box.
Had to make more room for the intake.
Transmission tunnel isn't that big.
Kim
My build thread
Old 05-27-2016, 01:07 PM   #69
Dave0
Yes yours is! If mine was set like that. I wouldnt be in such a bind for room!
I got a few days here to figure it out, thanks for the pics and nice work!!!
Old 05-29-2016, 01:09 AM   #70
yossarian19
I did it.
I wouldn't do it again.
It's kind of a mess by the time you have a 4L60E, hydrboost, master cylinder and 2.5" exhaust all living in the same space.
I'd just put the brakes on the firewall like every automaker has been doing since 1960 or so. It's ugly but personally I'm not bothered by it.
I think I have a pic in my build thread of how it all fits together. You may have your engine / trans further back than I do, hope so anyway.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 05-29-2016, 12:16 PM   #71
Dave0
Screw it! I cut apart the 55 bracket, used the old clutch trunnion to go thru the frame... All I need is to make a shaft (welded to pedal) to hook everything up. I will have to put it under body mount bracket... It should fit without modifying it...
Old 05-30-2016, 02:16 PM   #72
Kim57
Kim57's Avatar
That should work.
Kim
My build thread
Old 06-05-2016, 08:59 PM   #73
Dave0
No serious progress, tranny mount all buttoned up...
Old 06-12-2016, 05:14 PM   #74
Dave0
Small under frame tranny cooler, will be plumbed with a/n lines and fittings... Im trying to eliminate as much "up front" as I can. Things are tight enough... I canned the power steering cooler too
Brake lines and linkage work...
Old 06-13-2016, 09:40 AM   #75
Kim57
Kim57's Avatar
That's nice.
Kim
My build thread
