Old 05-29-2016, 03:43 PM   #326
Metaldoc
Metaldoc's Avatar
Re: 67 long box
First try, as bat man says in the Lego movie. I love it when a plan comes together and all works. Threw in some decking cut offs and it looks perfect. Now pull it all apart and paint all the pieces.
Metaldoc is offline   Reply With Quote
Old 05-29-2016, 10:20 PM   #327
Xeen
Xeen's Avatar
Re: 67 long box
I Like your creative solution, nice work.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-31-2016, 09:07 PM   #328
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks xeen . I'm enjoying this build. I like to be a little different, but not over done. My mind would have led me off on a wild total radical, maybe next one, but this ones my daily driver and to the cottage.
Old 06-02-2016, 08:09 PM   #329
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Brake fluid in and bled only 4 leaks. Rear end filled, engine oil in. Forgot the anti-freeze but tomorrow will do. Greased it all. I can fit the bed on now the brakes are done, much easier with box off and two of the leaks where at the rear flex coupler. Bed rails all painted and started on the front bed board mounting angle that had to bolt through between the cab. Cap screws through the front and the holes going down are cap screw holes with welded in nuts. I can screw down all the bed bars from the top.
Old 06-02-2016, 10:08 PM   #330
Advanced Design
Advanced Design's Avatar
Re: 67 long box
Great ideas all coming together. Very nice!
Advanced Design is offline   Reply With Quote
Old 06-02-2016, 10:32 PM   #331
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I think I'm happy with the side angle to hold the edge of the boards, now I can run bolts through the outside edge and follow around the inner fender to complete the look. I had to cut off a half inch of the edge to fit in and lost the groove.
Old 06-03-2016, 06:41 PM   #332
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Stone guarded sprayed in the bottom of the bed sides, inner and outer fenders. Should make it quieter.
Old 06-04-2016, 11:40 PM   #333
Metaldoc
Metaldoc's Avatar
Re: 67 long box
This is the plane my neighbor built that was on the trailer. Nice job.
Old 06-06-2016, 11:29 AM   #334
Custom.Chevy
Custom.Chevy's Avatar
Re: 67 long box
How did you come up with your sway bar? Just curious because I have the ability to do something similar i just never thought of doing it myself. What material tubing and size did you use. Did you find info on how much torsion is needed to twist the tubing and then increase the leverage by making those long mounts. I think its cool and its just one more thing you can say you did yourself.
instagram - @custom.chevy
Custom.Chevy is offline   Reply With Quote
Old 06-06-2016, 05:21 PM   #335
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks I love making everything I can, The cost is much cheaper. I used 4130 Chromalloy 1" solid bar and 2"x3" hss. The links are 65 Impala and the bushings are just 1" sway bar. I made the trail arms so just added a bracket to mount. The mount location has one bolt through the bed mount. As for the length I modeled it after the Hotchkis rear sway bar.
Old 06-06-2016, 08:50 PM   #336
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Put the last fluid in and it runs. Sounds great to hear that run again, it's tough to through some parts of the build but the pay off is coming.
Old 06-07-2016, 08:45 PM   #337
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Engine bay lighting looks good
Old 06-08-2016, 03:56 PM   #338
Xeen
Xeen's Avatar
Re: 67 long box
The truck looks great, all your hard work is paying off, I bet you are excited to be at this point, so close to being able to drive it.
Old 06-08-2016, 05:21 PM   #339
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks man and the anticipation is killing me. I debugged the electrical today and I had to move the horn wire to constant and the wiper to keyed power. Not bad for all that work on the wiring. Everything works now. My horn was dead so I tried the adjustment screw and now have a working horn, thanks to vwnate1.
Old 06-09-2016, 12:11 PM   #340
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Drove it up and down the street for the first time. That felt great and it felt great. Small exhaust leak manifold to pipe no big problem. Start putting on the box now.
Old 06-10-2016, 09:33 PM   #341
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Trail fit , looks great still need to trim the edges to fit but all good.
Old 06-14-2016, 05:50 PM   #342
Metaldoc
Metaldoc's Avatar
Re: 67 long box
It all fits in and on. I lovin this look with the composite and flat bar. You can't even tell the bed was raised 2 inches with the tailgate mod. Undecided on the wheel house bolt edge, I might put a strip over it with cap screws through. Put the tail lights in and with a few grounding issues they all work.
Old 06-14-2016, 07:11 PM   #343
Sicksty8
Sicksty8's Avatar
Re: 67 long box
It's coming together nice eh?! Looks really good and I'm loving the bed work. Composite looks really good in there. Keep on givin er!
Sicksty8 is offline   Reply With Quote
Old 06-14-2016, 10:06 PM   #344
Gavinski
Re: 67 long box
Just found this thread a few days ago and just got caught up today.
The truck is looking sick! And it looks as though you are fairly close to me (I'm in N3Y 4K6).
I have yet to start my tear-down on my inherited '67 LWB Fleet (Babe is her name). I'm hoping it will turn out even half as nice as yours has!
Gavinski is offline   Reply With Quote
Old 06-14-2016, 11:24 PM   #345
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks it was a lot of extra work and well worth it.
Thanks, I'm getting real close to the safety and on the road. I bought this truck in Waterford, the guy had 4 or 5 of them. I got a little carried away when I started fixing all the stuff it needed to pass the safety. I'm getting upwards of 1000 hours now in it and it still looks the same on the outside. It's all about the build. Good luck on your build.
Derek
Old 06-16-2016, 03:58 PM   #346
Metaldoc
Metaldoc's Avatar
Re: 67 long box
The bumper looks rusty and ugly, but I like it on there, the wife doesn't.
Old 06-16-2016, 08:58 PM   #347
Xeen
Xeen's Avatar
Re: 67 long box
Hmm I can dig the patina idea but what the hell be a contrarian.
How about a nice Metallic Silver on both bumpers, headlight bezels and the grill, perfect, glossy and clean, no faux patina.
Maybe consider replacing the rear bumper with a paintable sport model.
Old 06-16-2016, 10:48 PM   #348
Metaldoc
Metaldoc's Avatar
Re: 67 long box
With the help of a few buds we put the glass in and tossed the hood on. A thanks going out to Canuckvetter for the cig lighter looks perfect. I have to paint the ashtray I don't like it grey, looks undone.
Old 06-17-2016, 12:27 AM   #349
68bowtie
68bowtie's Avatar
Re: 67 long box
the color of the bed wood is fantastic. i love it.
i also like the sport bumper idea. i have the same dilemma with a 71 patina project. i have a really straight white patina front bumper, and gray step bumper on the rear. i've been trying to decide whether to leave it alone, paint it white, or find a patina sport bumper.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
68bowtie is online now   Reply With Quote
Old 06-17-2016, 12:58 AM   #350
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I not totally sold on the bumper but it is the factory one. I can always change it later. The composite boards came with that weathered look with the black grains in the grey. They look like an old barn board or bed wood aged.
