Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-25-2016, 06:51 PM   #401
IronCanine
I'm trying....
IronCanine's Avatar
Re: Attempting my first build 72 K5
Turned out great Mike...and I feel ya. There's not a lot of bright work on the interior, but it put me on dialysis too. Keep up the good work.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 06-25-2016, 09:14 PM   #402
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice chrome! Thanks for the update.
Old 06-26-2016, 11:32 AM   #403
sockalaminski
Now I remember why I decided to de-chrome.....looks great though.
sockalaminski is offline   Reply With Quote
Old 06-29-2016, 01:24 PM   #404
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Thanks guys. I appreciate the compliments and am happy to see you're all still following my build!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 06-29-2016, 01:48 PM   #405
72K5CSTDarkOlive
Long story,but going to keep it short for board. The body is at a new shop and it's in much better hands now.
This is how I found my truck after they closed down for business.
Name:  2016-05-05 13.55.47.jpg
Name:  2016-05-05 13.59.12.jpg
This is the shotty work from the first shop. Their idea of how they would fix the rear quarter panel.. putting 1/2" to 3/4" of bondo.. Unbelievable! First of all, you're not supposed to bondo over primer.
Name:  RH_bed Panel.jpg
It took 8 hours to remove 2.5 gallons of bondo. He's going to fix the rear quarter panel properly by pulling and straightening the areas that are pushed in.
Name:  2016-06-28 12.26.44.jpg
Old 06-29-2016, 02:46 PM   #406
sockalaminski
Sorry to see you were the victim of a POS body shop. It's hard to find a reputable body shop who will do the work correctly. The worse part is, if you don't keep track of what they're doing, you may never know. Body men are paid to make dents disappear and unfortunately, some body men despite having a good rep can do shady work and are VERY good at making things "look" great. I found bondo work on my Blazer that was laser straight, not cracked and looked like the sheet metal was never damaged, but ended up having 3/4" to 1" of putty. The funny thing is, me as an amateur was able to straighten the metal with basic body work tools and used less than 1/16" of bondo in less than two hours. Go figure.......
Old 06-29-2016, 03:46 PM   #407
72K5CSTDarkOlive
I'm just thankful they never were able to finish my Blazer because I would've been driving a frame off restoration with a ton of bondo.
Old 06-29-2016, 03:57 PM   #408
72K5CSTDarkOlive
Charlie is making a great progress on the panels and removing some of the dents the "right" way. The black is the low and high spots that he is going to remove by block sanding so everything is straight and smooth
Name:  rear wheel wells.jpg
Old 06-29-2016, 03:59 PM   #409
72K5CSTDarkOlive
A couple dents repaired the "right" way (no bondo!)
Name:  LH quarter paneljpg.jpg
Old 06-29-2016, 05:41 PM   #410
tjsblazer
tjsblazer's Avatar
That sucks Mike.
Glad it is getting back on track for you.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-30-2016, 08:00 PM   #411
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm glad to see your build is back on track and in the right hands. It's going to be top shelf once complete. Hang in there. Sorry that you had deal w that dishonest shop.
Old 06-30-2016, 08:15 PM   #412
IronCanine
I'm trying....
IronCanine's Avatar
The worst part of what that other shop did was that you have such a great tub. They're so hard to come by, that to disrespect it like that is almost sacrilege. Good on you for getting it back on track.
Old 07-01-2016, 12:13 AM   #413
72K5CSTDarkOlive
Originally Posted by tjsblazer View Post
That sucks Mike.
Brad, you're spot on, I was thinking the exact same thing myself. But, a shady person saw an opportunity to take advantage of someone who didn't know better.
Old 07-06-2016, 04:38 PM   #414
tinydb84
tinydb84's Avatar
Looks good. Who is doing your body work now?
David
Instagram: myfabguy
Old 07-07-2016, 12:19 AM   #415
lks dcvn
lks dcvn's Avatar
Good call on moving to a new shop!
lks dcvn is offline   Reply With Quote
Old 07-07-2016, 07:34 AM   #416
UGAK5
Agree with the shop move comments - - thats a scary situation in my opinion. Sucks to feel taken advantage of........
I know your build evolved and changed after having started it awhile back, which leads me to an engine question. I have been advised to save getting the engine for as long as possible so as not to have the engine sitting idle and immobile (valve springs compressed in the same position, etc.).
Any issues with that (that you can tell) or are you cranking the engine over every so often? Curious how you are managing that.
Thanks!
UGAK5 is offline   Reply With Quote
Old 07-07-2016, 11:49 PM   #417
72K5CSTDarkOlive
Thanks!
Thanks guys. I'm really happy with the new shop. Stopped by today to drop off the top so they can make sure the doors align. I'm going back again this Saturday to deliver the chassis.
If I originally was going to do a frame off I would have planned this a lot better and held off on the engine. I haven't fired it up since I've had it. I'm just gonna pray to the engine gods and hope it fires up and runs good!
Old 07-07-2016, 11:55 PM   #418
72K5CSTDarkOlive
BFS Auto. He brought in one of his go to guys for these particular restoration projects.
Old 07-20-2016, 07:57 PM   #419
72K5CSTDarkOlive
Question about correct steering coupler...
I ordered a new rag joint from Advanced Auto - Lares part # 201 and it says it's an exact fit. It seems odd to me that the new rag joint has only 11 splines.
I did replace my steering gear box with an AGR and it has the same spline count as my original. It is possible my "original" might have been replaced with a later model but I highly doubt it.
I initially tried to rebuild my old coupler but failed miserably. I bent one of the studs trying to press them in the back of the coupler.
Does anyone know if this seems right?
Name:  Lares Steering Coupler 201  Advance Auto Parts.jpg
Old 07-24-2016, 02:51 PM   #420
sockalaminski
I don't remember if mine had the full amount of splines all the way around or not. If memory serves, I remember the shaft size on the 67-72 chevys was 13/16" whereas 73 and up are 3/4". I'd say if it fits nice and tight, you have a winner.
Old 07-25-2016, 02:19 PM   #421
bluek5
bluek5's Avatar
Here is a picture of used one I bought from Thomas at DLTruck1973. You might give him a try if you are unhappy with the new one.
bluek5 is offline   Reply With Quote
Old 07-25-2016, 07:39 PM   #422
DeadheadNM
Carpe manana
DeadheadNM's Avatar
FWIW - I bought one a while ago from Eckler's and it fit fine.
Old 07-25-2016, 09:53 PM   #423
tjsblazer
tjsblazer's Avatar
I got one from this guy when he rebuilt my gear box.
http://www.powersteering.com/
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-26-2016, 01:14 PM   #424
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Yea... that spline count is not right.
Tom Vogel is offline   Reply With Quote
Old 07-27-2016, 08:13 PM   #425
72K5CSTDarkOlive
I sent the one from Advance Auto Parts back and they refunded my money. I called AGR and they weren't much help, but I did find out that after reading the product description on Summit it requires a 36 spline so I'm going to give this one a shot since the description matches the specs for my application. Ecklers says 13/16 but no list of spline count so I'm gonna assume it's for an original with 31 splines.
http://www.classicparts.com/1967-76-...info/SS-5152/#
Jeff - the link didn't work. Website says it temp out of service
