07-27-2016, 09:43 AM | #76 |
Re: 72 Jimmy "Colonel Mustard"
It wont be long now til we see some serious action ,looks good.
08-05-2016, 02:50 PM | #77 |
08-05-2016, 04:21 PM | #78 |
Bolted some parts on finally. Got the axles under it, the steering box, pitman arm, trans and t-case crossmembers, shocks and a few other things. Slow progress but its rolling again. Should have the engine crossmember back next week so I can start setting the drivetrain in. I've been struggling to make a decision on the fuel tank situation, I really want to use a factory style tank with an internal fuel pump. I think I have something worked out, should know tomorrow.
08-05-2016, 05:05 PM | #79 |
Looking great ,staying tuned in to see more.
08-11-2016, 05:22 PM | #80 |
08-11-2016, 05:26 PM | #81 |
Im back at work full time now after the physical terrorist got finished with me but when I can get some time I would love to drop by again to see it.
08-13-2016, 03:42 PM | #82 |
Finished assembling and installing the dirty dingo cross member
** ** Test fit the motor. The camaro manifolds worked like a charm, slid right in. I read about them on someones build (thanks!) ** ** ** ** waiting on the torque convertor that's coming monday, so I can keep moving. |
08-13-2016, 04:46 PM | #83 |
I'm trying....
Wowzers. That is legit. Great work.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
08-13-2016, 06:48 PM | #84 |
Looking good ,staying tuned in for more until I can drop by again.
08-18-2016, 09:27 AM | #85 |
08-18-2016, 09:38 AM | #86 |
Some more progress
Installed the new flywheel. ** ** Installed the advanced adapters transfer case adapter to link the 4l80e to the np205 ** ** new torque convertor ** ** mounted the transmission to the motor ** ** Going to move the cross member back. Came up a little short even with the motor mount sliders ** ** Lowered the body almost all the way on the frame to check motor clearence ** ** ** Clearance was good all the way around ** ** ** While the body is down I am going to figure out the radiator and fan situation. |
08-18-2016, 09:39 AM | #87 |
Man I need to come see that beast again ,looks great ,hope to swing by there soon.
08-18-2016, 02:51 PM | #88 |
A guy with a truck
Oh, hells yeah. Looking good
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-25-2016, 01:26 PM | #89 |
08-25-2016, 01:33 PM | #90 |
For the hydroboost plumbing I ordered new lines that fit the 04 2500 donor. I ordered a pressure line for my 72 and cut the ends off of it and flared them onto the hydro lines so they would thread into my gear box. $100.00 worth of lines and a couple of flares. I bent up a return line from piece of scrap that will go over the frame rail and to the return at the pump.
08-25-2016, 01:41 PM | #91 |
I got laughed at by the guys at work on how much time I spent agonizing over drilling the new holes to move the trans crossmember back. There just wasn't a good way to measure accurately enough to make me feel comfortable. I finally got tired of being ridiculed and drilled the holes. I did find out that my frame is 1/8" out of square.
** ** It finally supporting its own weight and torqued down ** ** |
08-25-2016, 01:52 PM | #92 |
Installed the intake manifold. I replaced the original with a dorman truck manifold. I added RTV around the top of the grommets out of habit, but the water intrusion issues on the LS trucks were from a bad hood to cowl seal. I don't think that will be an issue on my rig, but the upper plate is designed like a ramp to flow water right into the harness grommets. I figured it couldn't hurt.
** ** ** I stripped down the fuel rails to clean, polish and reseal. Had the injectors rebuilt locally. ** ** ** Last edited by ochre 72; 08-25-2016 at 02:51 PM. |
08-25-2016, 02:15 PM | #93 |
Installed the engine portion of the wiring harness. Speartech does a nice job on their harnesses
** ** Added an oil cooler block off plate, installed the crank sensor, starter and a few other odds and ends. Unfortunately my front drive shaft is too short and rear is too long. I wasn't thinking about this ahead of time and had both powder coated. An old guy told me once "it costs money to learn to play poker", he was right. Will be measuring so I can get them corrected. Next I will be getting my brake and fuel lines plumbed up and I'm still not sure how to overcome my gas tank issue. I really want to have an in tank, factory style pump, but don't really want a squared off custom tank. |
08-25-2016, 03:10 PM | #94 |
Do some searching in the LS section guys are using the 90 blazer tanks and install backward so the filler is on the correct side. I know there is a series of years with the same tank just don't know the spread LOL. It may not appeal to you because the square end of the tank hangs down in the back. You may have to add a crossmember in the rear to attach the tank to, the mounting straps run parallel to the frame rails on the new style blazers. I will try and look later and find you a link if interested let me know.
08-25-2016, 03:32 PM | #95 | |
08-25-2016, 04:02 PM | #96 |
You can opt for the late 87-90 wrangler tank which is EFI ready (baffled inside as well) and is a direct bolt in with angle iron to support the tank instead of moving cross members. The tank is small at 15 gallons though.
Starting with post #28 in this thread you can see how it looks and is plumbed. http://67-72chevytrucks.com/vboard/s...d.php?t=427417 Post #39 shows the angle iron pix. |
08-25-2016, 06:11 PM | #97 | |
08-26-2016, 03:45 AM | #98 | |
Collector of Projects
http://67-72chevytrucks.com/vboard/s...d.php?t=693077 |
08-26-2016, 02:48 PM | #99 |
I think this is the one I was talking about
http://67-72chevytrucks.com/vboard/s...d.php?t=670191 Here is a few more for ideas http://67-72chevytrucks.com/vboard/s...49#post7489149 http://67-72chevytrucks.com/vboard/s...d.php?t=702634 |
08-29-2016, 04:29 AM | #100 |
