#426 | |
Still Learning
Re: Project "Redemption" 68 SWB Fleetside
How about some updates Keith..... ![]() |
#427 | ||
![]() Join Date: Dec 2006
![]() Quote:
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#428 |
Hey Keith, have you figured out what you're going to do for the fuel line connection at the fuel rail? I'm not sure what I want to do yet and I'm looking for ideas.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#429 | |
#430 |
No worries Keith. I'm in about the same spot. Just trying to plan ahead for when I do get there.
#431 |
Got some work done on the exhaust yesterday. I ended up sending the Black Widow mufflers back because I couldn't get them to fit and work the way I wanted to! Just not enough room with the rear Dropmember for what I want to do with the exhaust! I decided to go with some Borla S-Type mufflers. I ended up mounting them under the cab cause that's really the only place I had room to mount the mufflers and be able to run the side exhaust! Might be a little hot on the floorboards but some heat insulation should take care of that
#432 |
Then I ran the pipes out and over the frame between the two bed crossmembers! I'll finish off the rest when I mock the bed up and figure out where I want the tips to be! Still need to add some hangers to it as well.
#433 |
A guy with a truck
Dig it. Nice and simple. Gonna keep the tips hidden?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#434 |
I like how you did the exhaust Keith, how will the Borla mufflers sound????
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#435 | |
Thanks, not quite sure yet on the tips, I know I don't have much room when aired out
![]() Quote:
#436 |
![]() Join Date: Feb 2010
please tell us more about what type of clamps and exhaust pipe you are using, its looking good! im in a similar spot in my build.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
#437 |
Exhaust routing looks very nice.
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#438 |
![]() Join Date: Dec 2012
Looking good Keith!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#439 |
That looks good Keith!
#440 |
![]() Join Date: May 2016
Nice work man, Exhaust looks great
#441 | |
https://www.summitracing.com/parts/sum-692025/overview/ https://www.summitracing.com/parts/sum-670146/overview/ Thanks guys, I'm pretty happy with the way it turned out. Just have to do some finish welding and add some hangers to it.
#442 | |
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#443 |
Thanks Brandon, I picked up some trick exhaust hangers from Stainless Works that I got from Summit Racing too! Got those installed this weekend!
#444 |
Got some work done on the truck this weekend. I removed the intake off the motor and installed new knock sensors and a new wiring harness since mine was a little beat up. While I was working on the motor I installed my Holley fuel rails with new injectors.
After finishing that I went back to working on the frame. I got the ride height set at 5" and centered the rear end so I could tack my bag mounts on. I'll finish welding them up when I take the chassis back apart for powder coating!
#445 |
Looking good Keith
#446 |
Everything is looking great Kieth.
#447 |
Thanks guys, slow and steady
#448 |
Needed some inspiration before I start tackling the rust in the cab! I think I've got all I need now
#449 |
![]() Join Date: Nov 2010
Holy piss!
#450 |
Drooling !!
