09-27-2016, 09:10 PM | #101 |
Re: New Daily Driver
I definitely second WarMongers idea of hardline all the way to the carb definitely safer than sorry
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
09-27-2016, 10:04 PM | #102 | ||
A day late and $1 short...
Thanks We'll see if I take this on or order one from Kevin at Kev's Classics.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
09-27-2016, 10:18 PM | #103 | ||
Y'all know your new vehicles have rubber hose in the fuel systems with much higher pressure, right?
09-28-2016, 07:04 PM | #104 | |
You really only need the flex line between the frame and the pump to allow the line to flex with the engine/trans. As long as nothing else is a moving part, hard line should work fine. Also, most newer vehicles are using nylon (plastic) line since ethanol eats rubber pretty quickly. Heat becomes a concern with the nylon stuff though.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
10-02-2016, 01:11 AM | #105 |
A guy with a truck
Watching this
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-08-2016, 01:46 PM | #106 |
Let's talk disc brakes. I'd like to upgrade to... No, I NEED to upgrade my brakes. I liked the performance of the 4-wheel disc setup I had on the stepside, it was a mix of ECE and CPP. Recently a well known builder warned me to stay away from CPP parts, I'm guessing he's seen some failures or quality issues. I like the fact that CPPs modular spindles keep the track width, but I'm more concerned about buying anything that may fail later. With this in mind I'm think of a couple scenarios. Opinions? Experiences?
1.) ECE 2.5" drop spindles with factory style single piston calipers, factory iron M/C with stock proportioning valve, and ECE rear drum upgrade kit. All this from ECE would be around $1400 + shipping 2.) Custom built 4 wheel disc brake kit using factory Corvette brake parts, McGaughy's spindles, and a Wilwood M/C with proportioning valve set up. $2500 3.) CPP 4 wheel disc kit. $1545 + shipping
10-09-2016, 01:00 AM | #107 |
A guy with a truck
Keeping 15s? 6-lug? Have you looked into any of the captfab rear brackets? I think you can put together a 4 wheel disc setup for much less than those, unless you like the convenience of a kit.
Only issues I've ever heard of from CPP arise from customer service.
10-09-2016, 09:35 AM | #108 | |
10-09-2016, 11:16 AM | #109 | |
10-09-2016, 11:25 AM | #110 |
Just hopped in, I like the upgrades.
10-10-2016, 04:49 AM | #111 |
Missed seeing you back into a truck. This one looks super good. Hope to see it at a future CTC event.
10-10-2016, 06:29 AM | #112 |
Yep, it was tough to stay home from CtC this year, but I have to be smart with my vacation and my $$. Hope to see y'all next year.
10-10-2016, 12:46 PM | #113 | |
A guy with a truck
DJM drop spindles-$220 ECE 6-lug rotors-$200 Calipers, balljoints, etc from rockauto Captfab rear setup I think you can put it all together for around $1k, just guessing. Requires a little planning/leg work, but to mee, that's half the fun
10-10-2016, 01:03 PM | #114 |
I agree with Chris. The only issues I've heard and read about with CPP are customer service driven. I personally bought the Modular drop spindles just to be able to run bigger brakes in the future and a bonus is the narrower track width. I just made sure to buy them from a board vendor so I didn't have to deal with CPP directly.
As for brakes, I went with Wilwoods, but I wanted the look too. I've read a few times that 4 wheel disc on a truck isn't really necessary, but if you plan on towing, racing or anything like that, it can't hurt. I hear McGaughy's and ECE are similar to the CPP kits for stopping power, but I don't have personal experience with any of them. Good luck!
10-10-2016, 01:15 PM | #115 |
68 C 10
I like option #1
I like one phone call, one order. I don't have time to chase parts and hope I'm ordering the right ones.
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
10-13-2016, 02:45 PM | #116 |
I ordered the first part of my brake upgrade today, and I am hopeful it turns out well. The quote, "There's a sucker born everyday" is bouncing around in my head. I ordered a master cylinder/proportioning valve and a pre-bent line kit from Performance Online. Never ordered from them so I'm cautious. Also, I tried the pre-bent lines from CPP with my stepper and because I swapped the '68 crossmember for a '73 my brake upgrade wasn't the norm, so I ended up not using their lines. Unfortunately, I have no idea what happened to those lines. Anyway, a friend of mine has a spare set of new 12" 6-lug rotors I can get on a deal and I'll be ordering CPP modular spindles and caliper brackets soon. Who on the board sells CPP? Everything else I can source at my local parts store. For now I'm going to try and get the rear drums working better with the front discs, but at some point I'll do a 6-lug rear disc conversion. I hope to have all of the parts required by the veteran's day weekend so I can take advantage of the extra day off to do the swap, can't have the daily driver down too long. We'll see...
10-13-2016, 04:09 PM | #117 |
A guy with a truck
Sounds like a solid plan. Do us a favour and measure before/after track width with the CPP modulars
10-13-2016, 04:24 PM | #118 |
Will do!
10-13-2016, 04:36 PM | #119 |
I bought mine from Matt from Matt's Classic Bowties, I believe his forum name is MCB Matt. He has several threads in the Vendors Marketplace.
10-24-2016, 05:09 AM | #120 | |
11-11-2016, 07:44 PM | #121 |
She gone!!!
11-11-2016, 08:06 PM | #122 |
What? What's next?
11-11-2016, 08:12 PM | #123 |
Don't exactly know yet. Maybe a convertible for my wife or maybe another C10, will be a few days to a week before we know.
11-11-2016, 08:16 PM | #124 |
Convertible Chevelle's are fun ,I have one .
11-11-2016, 08:47 PM | #125 |
Catching up ...reading about brakes and expecting to see brake upgrade pictures, nope...congrat's and have fun finding the next one.
