Old 12-12-2016, 05:15 PM   #101
MMcMasters
MMcMasters's Avatar
Re: 1970 Med Olive Project
Originally Posted by Phill0406 View Post
Cool idea with the spacers, haven't seen that before.
Great build so far.
I can't take credit for it, it was Todd's idea. I knew I wanted to raise the tank a few inches so it would be hidden within the chassis at ride height. I just stole his idea
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 12-12-2016, 11:05 PM   #102
kehstr
kehstr's Avatar
are the boyd racing tanks designed to go on top of the frame, or is that just what you are doing with a lowered truck?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 12-12-2016, 11:40 PM   #103
MMcMasters
MMcMasters's Avatar
Being lowered this much necessitates the tank being mounted on top.
Mike
Old 12-15-2016, 01:48 PM   #104
PBFAB.COM
PBFAB.COM's Avatar
Truck is coming along nicely Mike. I like your wheel choice. Amazing truck to start with.
Dave
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-15-2016, 02:43 PM   #105
MMcMasters
MMcMasters's Avatar
Dave
Thanks Dave! The last few months have been pretty busy at work but I'm through it now and hope to get back on the truck and make some really good progress. My goal is to be driving it by the time the weather breaks.
Mike
Old 12-29-2016, 09:06 PM   #106
MMcMasters
MMcMasters's Avatar
The holidays are over, it's time to get my butt back in the shop and get to work. We got the Transmission finished up yesterday. I probably should have went with a 4L80 but I had a 4L60 core given to me. I spent some $$ to beef it up. 5 pinion planetary, higher capacity 3-4 drum with better clutches, Kevlar bands, hardened sun shell, 300m input and a Transgo HD shift kit. It should hold up just fine at my power level even though I tend to beat on my stuff pretty hard. I also got a precision 3200 converter. The transgo recalibration kit eliminates the pulse width modulation.
This was an early 4l60 and I'm working out the little details as far as flywheel spacing to the converter. I had to change the bellhousing and I ended up with with a 4l80 flat flexplate with a spacer. I had to open up the converter mounting holes on the flexplate a little as well. There are so many variations of the 4L60 it will make your head spin. If I had hindsight, I would have just bought a new gearstar level 4 and been done with it.
My son cleaned everything up tonight and painted it. Things should start moving at a faster pace soon. Once we get the engine/trans in and verify pinion angles, I will order my driveshaft. I plan to finish plumbing the fuel system and trans cooler and building the exhaust next. Then it's time to start swapping the body over to this chassis.
Mike
Old 12-31-2016, 01:56 AM   #107
kehstr
kehstr's Avatar
Did you get the trans all mounted? I did this same thing with my trans in my truck and would be more than happy to help if still needed
@Chad's Fab
Old 01-08-2017, 02:45 PM   #108
MMcMasters
MMcMasters's Avatar
It turns out the precision converter I had was wrong. The mounting pads and the pilot snout were for a non LS 4L60. I called and talked to Brian at Circle D and he got me set up with the right converter that would be used with my stock flexplate without the need for a spacer.
The engine/trans are back in the chassis for good. I set it up for 5* down angle and mounted the trans crossmember. I'm going to have a local shop build the driveshaft this week. Small progress but I'm moving in the right direction.
Mike
Old 01-08-2017, 03:38 PM   #109
Dustmaker65
Dustmaker65's Avatar
Looking good Mike! It won't be long now and the green truck will be under the "knife"!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 01-08-2017, 03:58 PM   #110
MMcMasters
MMcMasters's Avatar
Man I hope so! Time is my biggest obstacle, the whole job thing is really getting in the way of my shop time.
Mike
Old 01-08-2017, 04:02 PM   #111
88Stanger
88Stanger's Avatar
beautiful build
88Stanger is offline   Reply With Quote
Old 01-09-2017, 09:29 AM   #112
Bennett68C10
Bennett68C10's Avatar
That frame looks awesome with the drivetrain in it
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-09-2017, 10:39 AM   #113
MMcMasters
MMcMasters's Avatar
Originally Posted by 88Stanger View Post
beautiful build
Thanks guys, it's getting there. I'm disappointed I'm not further along but life keeps getting in the way.
Mike
Old 01-09-2017, 12:43 PM   #114
knomadd
knomadd's Avatar
You've got that right! That's how I've been feeling with my project. Yours is looking good though.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-09-2017, 06:02 PM   #115
MMcMasters
MMcMasters's Avatar
I don't know how I missed this message and I apologize for not responding earlier to your offer. Thank you for the offer but I was able to get everything sorted out.
Mike
Old 01-10-2017, 12:08 AM   #116
kehstr
kehstr's Avatar
it's all good, glad you were able to get it all worked out
@Chad's Fab
Old 01-10-2017, 09:12 AM   #117
Bennett68C10
Believe me, I know exactly how that feels
Keith
66 Suburban
IG: bennett68c10
Old 01-19-2017, 09:31 PM   #118
MMcMasters
MMcMasters's Avatar
I started plumbing my fuel system this week. I built everything out using standard braided line to get my measurements. Then I ordered all of my lines from Brown&Miller Racing. These are by far the best lines in the business in my opinion. They are a high temp fiber braided line, PTFE lined to resist any fuel or additive, crimped on fittings and are rated to 200psi.
I mocked up my filter/regulator in several positions but I wanted to have it in the most accessible location for future maintenance. By mounting here I will be able to change it out fairly easy and it will keep my feed and return lines short. My stainless line clamps didn't show up today so unfortunately this is as far as I got and I wasn't able to run the main line from the filter to the fuel rail.
Mike
Old 01-19-2017, 11:49 PM   #119
GAc10boy
GAc10boy's Avatar
I started plumbing my fuel system this week. I built everything out using standard braided line to get my measurements. Then I ordered all of my lines from Brown&Miller Racing. These are by far the best lines in the business in my opinion. They are a hight temp fiber braided line, PTFE lined to resist any fuel or additive, crimped on fittings and are rated to 200psi.
Those lines look amazing! Great idea.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 01-20-2017, 05:52 PM   #120
MMcMasters
MMcMasters's Avatar
Thanks Robbie!
Mike
Old 01-20-2017, 10:28 PM   #121
Advanced Design
Advanced Design's Avatar
I agree with Robbie about the lines. Good looking product with some impressive specs.
Still enjoying tagging along.
Advanced Design is offline   Reply With Quote
Old 01-20-2017, 10:47 PM   #122
GR8-68
GR8-68's Avatar
Very nice work, I like it
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-12-2017, 11:55 PM   #123
MMcMasters
MMcMasters's Avatar
Thanks guys!
Mike
Old 02-13-2017, 12:11 AM   #124
MMcMasters
MMcMasters's Avatar
Slowly but surely I'm getting to the finish line on this chassis. This weekend I got my driveline angles sorted out. I need 3* shims to correct my pinion angle and I'm done there other then finish welding the bag mounts and painting the rear end. Should have the shims by Wednesday.I got the new driveshaft painted today and started building the exhaust.
I had a set of ultra flows, a bunch of J bends and some 45's on the shelf so I'm going to try to get the exhaust finished on the cheap....because I'm cheap
I also bought a U weld h-pipe kit. I have from the h-pipe to the mufflers mocked up and tacked together. I wasn't able to finish the head pipes today because the exhaust runs right into the transmission crossmember. I tried flipping the crossmember over and I was able to gain some room but it's still right in the way. I'm going to modify the crossmember or just build a new one to make my life easy. I plan to flange the system before and after the trailing arm crossmember in case I ever need to remove it without having to cut the mufflers off.
I'm moving slowly but I am very motivated even if my results don't show it
Mike
Old 02-13-2017, 01:36 AM   #125
Jason7121
Jason7121's Avatar
Didn't realize you also had a build thread. I follow you on instagram and you helped with my header questions. Great work with everything.
Jason7121 is offline   Reply With Quote
