#301 |
laying low
![]() Join Date: Mar 2001
Re: Color Wiring Diagram FINISHED
You guys should know boundstaffpress hasn't logged on here since July 2015 just so you know and aren't waiting patiently for an email.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 12-24-2016 at 11:30 PM. |
#302 |
Here is the full cleaned-up version:
#303 |
laying low
That's way better. I have been trying to print some clear copies of the others but no success.
#304 |
That looks super nice! Excellent work.
1968 LWB C20 / AC / Wood Bed |
#305 |
does anyone have this in a spreadsheet by chance? ive been searching and cant find it.. i cant get a ahold of a color printer, honestly a chart or spreadsheet is easier while im going through.. thanks in advance!
#306 |
A BIG thank you to all who posted diagrams and offered advice. I have just been through all 13 pages, downloaded and printed a heap of information all of which is worth its weight in gold. I am still neck deep on gloom over this EZ kit but it will come good soon.
Regards Peter. |
#307 |
Does anyone have a generator/reg delete converting to 3 wire alternator that would kind of overlay this outstanding rendition?
#308 | |
![]() Join Date: Apr 2016
http://67-72chevytrucks.com/vboard/s...d.php?t=763180 12SI with regulator delete and add accessory junction block overlay. Example application for parts store is 1984 High performance Chevy Camaro, with 5.0L (305G) engine 94amp alternator ![]() CS130 with regulator delete and add accessory junction block overlay. Example application for parts store is 1989 Pontiac Safari 105amp v-belt alternator ![]() More info about CS130 resistor and terminal https://web.archive.org/web/20220703...20IN%203.0.pdf Example pigtail with resistor https://www.amazon.com/dp/B0055ALN56/ Last edited by dmjlambert; 07-02-2022 at 08:41 PM. Reason: updated CS130 info link |
#309 |
HEI overlay
#310 |
#311 |
There isnt one of these buy chance for the 73 to 87 trucks is there?
#312 |
Wiper correction overlay
#313 | |
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Trueman |
#314 |
Helping my brother work on a friends Blazer, this diagram was very helpful!
One question though, what does the black and black/white fused wires go to? I see they terminate at the firewall junction, but doesnt look like they go anywhere on the cab side. Thanks! Nick |
#315 |
An electrical circuit consists of 3 main wiring components that is live(also known as phase or main), neutral and earth(ground). To distinguish between them different countries use different color code for identification.
In India 3 colors i.e. Red, Blue and Yellow are used for 3 phase live supply, Black is used for neutral and Green or Green with yellow stripes wire is used for earthing(ground) . Here's a Wikipedia link for electrical wiring. You can go through details and can learn different color codes for wiring in various countries. |
#316 |
Hello, can I get that Hi-Res copy as well? Thank you in advance mllrd269@gmail.com. Looks great, great job BTW
#317 | |
jimbosprint's version with minor mods is in post 344 of this thread. http://67-72chevytrucks.com/vboard/s...27#post9186727. You can right click on it and save it to your computer if you want. Last edited by dmjlambert; 03-18-2023 at 09:32 PM. Reason: edited URL for the hi-res diagram |
#318 |
Greetings- may I have a high-res copy also?
moon@moonskie.com Thank you for all the time & effort you have afforded us!!
1970 CST long bed Fleetside |
#319 |
Could I get a Hi-Res copy as well? Thank you for putting this together! Super helpful
jimmywhispers14@gmail.com |
#320 |
Hello, can I get that Hi-Res copy as well? Thank you in advance rhernandez0727@att.net. Thanks.
#321 |
Hello, can I get a high res copy too? ktmmatt@gmail.com. Thank you.
#322 |
![]() Join Date: Dec 2009
10-13-2017 was the last time Original Poster has logged in.
This is the same wiring diagram in the Factory Assembly Instruction Manual. Here's a link another member shared link: http://www.chrismeadtattoos.com/wiri...ruckwiring.jpg .
#323 |
Awesome, thank you.
#324 |
The full resolution copy is just a few posts back guys. Scroll.
#325 |
Re: I suck at reading wiring diagrams..
Just took a 350 out of my C10 for a new L83. Marrying the ignition to the computer is beyond my 72 year old brain. A lot of what you have written helps. Everything will be stand alone. Engine needs hot to starter and one wire to cpu. AC will be stand alone as will be lights.
