Old 05-14-2009, 09:55 PM   #26
1tuff71
1tuff71's Avatar
Re: Blazer Seat Bracket Question
Forgot you posted the pic's and yours are the same as mine... HATE THEM! Don't know how they ended up in mine. Figured I would swap them out later.
1tuff71 is offline   Reply With Quote
Old 05-20-2009, 01:32 PM   #27
RLONG
RLONG's Avatar
Bought covers from LMC to small they sent me to a lady at Truck World named Dixie in Springfield,MO (417)883-8390
SHE WAS ABLE TO FIX ME UP WITH SOME SCROLL COVERS FOR FAT BOY SEATS(UTILITY) THAT IS WHAT SHE CALLED THEM. I SENT PICS IN THE OTHER TREAD TODAY. The back on these are metal and criscrossed as you said.
RLONG is offline   Reply With Quote
Old 06-13-2009, 11:11 PM   #28
70k5pk
70k5pk's Avatar
Does anyone have the rt frt seat brkt picutres or parts for a 1970 K5 Blazer?
70k5pk is offline   Reply With Quote
Old 06-14-2009, 03:39 PM   #29
71jimmy
71jimmy's Avatar
Sorry, no pics. But you might want to specify which seat brackets your looking for. Utility buckets or Sport buckets. The brackets are different bt. the two.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 06-14-2009, 04:17 PM   #30
70k5pk
70k5pk's Avatar
I guess the utility because the rt frt seat folds forward and latches when in the down position. The seat are pretty fat and the back part is low.
Old 06-15-2009, 07:40 AM   #31
RLONG
RLONG's Avatar
These are utility buckets or fatboy seats the others are narrow with plastic backs these are metal backs.
Old 06-15-2009, 08:02 AM   #32
70k5pk
70k5pk's Avatar
That is what I have. They have already been redone but the rt frt seat brackets have been missplaced. Can you get me a picture of the seat with it leaning forward?
Old 06-15-2009, 11:36 AM   #33
RLONG
RLONG's Avatar
I will try to remember this evening when i get home. It has a center female bracket bolted to the floor and the seat has a male bracket that it sets down in which can be unlatched by pulling on a rod or using the handle you can see at the back.
Old 06-15-2009, 12:09 PM   #34
70k5pk
70k5pk's Avatar
That sounds correct. I have the male part but nothing else. Thanks
Old 06-15-2009, 12:58 PM   #35
woodymm3
woodymm3's Avatar
I may have an extra female bracket. maybe i will have to check.
woodymm3 is offline   Reply With Quote
Old 06-15-2009, 01:09 PM   #36
RLONG
RLONG's Avatar
Here is a picture of a bracket where the latch is to the right mine is in the middle both were used. I copied this from another thread mine is the same only in the middle instead of the right.You can spot the female bracket at the bottom right.
Old 06-15-2009, 07:01 PM   #37
70k5pk
70k5pk's Avatar
Thanks, I have the long bar and the hook shown on the seat but i will have to see about the rest of the brackets. This helps a lot.
Old 06-16-2009, 07:41 AM   #38
RLONG
RLONG's Avatar
Here is mine that has brackets in the center.
Old 06-17-2009, 07:56 AM   #39
70k5pk
70k5pk's Avatar
After looking at these pictures mine is different. My seats are on a 1970. Is yours a 71? Maybe they are different?
Old 06-17-2009, 11:13 AM   #40
RLONG
RLONG's Avatar
Yes mine is a 71 blazer i think the first picture with it on the right side was earlier model just a guess.
Old 11-16-2016, 06:21 AM   #41
jondancer
Originally Posted by jaros44sr View Post
Just measured my mounting holes in the Jimmy/Blazer. DS bucket seat mounting holes are 12 3/4" cl to cl. Utility Buckets are 15 1/4" cl to cl
What does cl to cl mean? Thanks
jondancer is offline   Reply With Quote
Old 11-16-2016, 06:42 AM   #42
lolife99
67-72 parts collector,…
lolife99's Avatar
Centerline to centerline.
Keith
Convert to disc brakes.
Old 11-16-2016, 07:06 AM   #43
jondancer
Thanks so is that front to back or side to side?
Old 11-16-2016, 10:41 AM   #44
jaros44sr
jaros44sr's Avatar
Front to back
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-04-2017, 08:38 PM   #45
Rgatewood
I need a female bracket for the pass side seat for a 71 blazer. Also need 1 front bracket that bolts to the floor if anyone has them please let me know. Thanx
Rgatewood is offline   Reply With Quote
