12-16-2016, 09:29 AM | #76 | |
Re: Project "Candy Apple"
BTW, I'm enjoying following your progress. |
12-31-2016, 12:48 PM | #77 |
How's the truck coming?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU Last edited by UKNOWME; 01-03-2017 at 02:29 PM. Reason: Fat fingers |
01-03-2017, 12:31 PM | #78 |
I took a short vacation from work and the truck for the holidays, but I did get a little bit done. I trimmed the engine covers and got them mounted, finished the air intake fab work but it still needs painted. Now here's where this project went south. When I changed the cooling system back to the mechanical fan I no longer needed the fan relays or wiring for the old electric fans. In the process of removing that stuff I found some other wiring that I wasn't happy with. As usual with me, the more I dug the more I found. So that led to basically a rewire from the firewall forward with proper wiring techniques and terminals. I built a new relay panel with the correct relays, fuse blocks, OBDll port, and check engine light. I still need to put a few more wires in loom, and waiting on a 18" maf extension harness.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
01-03-2017, 02:31 PM | #79 |
Did you know you can remove that oil fill tube and the cap will screw straight into the valve cover?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-03-2017, 02:38 PM | #80 |
Yeah, I had to trim the covers anyway because of the high mount A/C brackets so I just left the filler neck alone.
01-03-2017, 02:39 PM | #81 |
Sounds good
01-04-2017, 05:37 PM | #82 |
Junior Member
looks great
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-04-2017, 11:00 PM | #83 |
Truck is looking great... I'm interested in seeing how your 285/50 rear tires work out since I've got a set ordered myself. If you need a narrower spacer, dmvmotorsports sells a 1" hubcentric spacer on ebay for $40/pair. However, they have metric studs so you would need new lugnuts as well.
01-05-2017, 04:50 PM | #84 |
Thanks. I'll check them out.
01-15-2017, 08:58 PM | #85 |
Great looking truck!
01-16-2017, 08:46 AM | #86 |
I can finally say I'm finished with the truck and spent the weekend detailing and driving this thing. It's not to the level I originally hoped for, but given my time and budget, it turned out real nice and far better than what I started with. I have the exhaust scheduled for later this week, then I'm officially done.
01-16-2017, 08:48 AM | #87 |
A few more.
01-16-2017, 05:36 PM | #88 |
Well done, another beautiful creation.
Desert |
01-16-2017, 08:44 PM | #89 |
Thank you sir.
01-16-2017, 11:09 PM | #90 |
Do you have any info on the air intake setup? I need a better setup that goes to the drivers side like that.
01-17-2017, 08:35 AM | #91 |
UKNOWME I modified a 2003 Silverado air intake by cutting off and rewelding the stock mounting brackets. Then added a 90` elbow and coupling to get it to the fresh air opening on the core support. I also had a 24" MAF sensor extension harness made, and added a 4" cone filter.
01-17-2017, 09:20 AM | #92 |
Unless I missed it, do you happen to know the paint code for the red? Or the paint manufacturer? Awesome truck by the way!
01-17-2017, 10:14 AM | #93 |
The red is PPG Vibrance line called "Cherry Bomb" and its a true 3 stage base/candy/clear. Paint code: Gold base 908347 & mid candy coat 908347/2
01-17-2017, 10:34 AM | #94 | |
Happy to be here
01-17-2017, 11:22 AM | #95 |
Ken you mentioned quick... How about finalizing a deal now for the truck to head to Houston.
01-17-2017, 12:44 PM | #96 |
I'm just glad to be here!
Truck came out nice. The bigger rear tire looks good.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-17-2017, 12:49 PM | #97 |
Thank you sir
01-17-2017, 02:33 PM | #98 |
Thank you for the quick response. I have an '84 K30 4x4 SRW that I am just starting to round up parts for. I plan on a two-tone paint job that is basically the opposite of yours. I'm thinking your red in the middle with a gun metal gray top and bottom. If I do a cowl induction hood then maybe two SS style stripes down the hood.
01-18-2017, 09:47 AM | #99 | |
Man I didn't even get a shot, LOL.
Desert |
01-18-2017, 10:03 AM | #100 |
Truck sale is pending, but Desert1957 I'm trying to close a deal on your next truck. SWB, solid black, gray & black interior, my drop and wheel & tire package.
