01-19-2017, 09:24 PM | #1 |
Painting Hard Top (SMC)
So, i just completed some repair work on my rear hatch and i am wondering what type of coating i should be using on it. Does anyone know if Gel Coat will stick to the hatch? Also, what type of prep work should i do to get the surface ready for paint or gel coat. Please feel free to post what you have done on your projects.
01-20-2017, 11:50 AM | #2 |
Re: Painting Hard Top (SMC)
From what ive seen, a bedliner like monstaliner or raptor liner work great, you can choose how thick you want to lay it down and its tintable. also very durable. depending on how you lay it down you can manipulate the texture of it as well
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
01-20-2017, 12:32 PM | #3 | |
Interesting...I just ordered some raptor liner the other day and am going to spray my top with it. I wasnt sure if anyone else has tried that before. My top has a ton of blemishes so I figured the raptor liner would protect it and hide the imperfections. Curious if anyone else has sprayed their top with liner and how it came out. |
01-20-2017, 03:51 PM | #4 |
I use body shutz/chip guard, you typically see it on rocker panels to stop rock chips, but it's light weight and super easy apply, topped with base coat and satin clear coat it turns out perfect
This was my last truck, top had quite a bit of repair work done to it screen capture software
1972 Dark blue, Cst, Highlander |
01-20-2017, 05:15 PM | #5 |
I used a custom mix on all my plastic blazer parts. Top included...UPOL raptor tinted with white urethane base coat, the difference in my mix is 50% urethane basecoat, not the 10% recommended. Same amount of harder and 10% plus reducer to smooth it out. Sprayed with 1.8 tip from regular HVLP. Result is semi satin finish without the pebble grain.
01-21-2017, 02:08 PM | #6 | |
This is an interesting solution. What did you use to spray it and do you know how much you used? I was looking online and it's about $20 a quart.
Kirk 72 Blazer CST 4wd highlander |
01-21-2017, 03:50 PM | #7 |
I used 3m's gun for it, the stuff is a cream color, it's not the rubberized black stuff.
I seem to recall it being 30-40 a quart and I used 3.5 quarts including the hatch. Prep with 180 on a DA, make sure you tape off when the window gasket goes, the bottom side I did really far away so it came out with far spacing and such, top side i did a nice even coat. Let it flash and base coat right over it https://www.amazon.com/3M-08874-Rock.../dp/B000PEPJKW
01-21-2017, 05:06 PM | #8 |
X2 on the Raptor liner. It has the same texture as the original Blazer SMC tops. I used this product on the inside of the fenders for my street rod, and after 25000 miles there wasn't one mark in it. I also tinted mine to get it close, but I would recommend spraying the entire top with a single stage urethane to get an even color. If you spray the final color within a day or so, the paint will still crosslink to the Raptor so you won't need to scuff the whole thing. I used a Shutz gun also like Classic Style mentioned.
Edit; I found a picture of some trailer fenders I made, and I also sprayed these with Raptor liner on the inside. Will give you an idea of the texture. Good luck ! Last edited by hemi43; 01-21-2017 at 05:12 PM. |
01-22-2017, 06:03 PM | #9 |
Thanks for the input guys, i appreciate it!!!
03-08-2017, 10:42 AM | #10 | |
Did you prime the top before you applied the shuntz or did you just scuff, clean and shoot? 1. Prime (high build)? 2. Apply rocker shuntz 3. base coat (gm 521) 4. satin clear |
03-08-2017, 03:39 PM | #11 |
Sanded with 180 on a da, wax and grease remover and shutz
A boat shop fixed the cracks and gel coated the repairs so all I had was gel coat, da with 180 and go to town
03-08-2017, 04:10 PM | #12 |
HMMMMM, now I am thinking about just going the raptor liner route and just have it tinted gm521. Scuff and then apply in one step, it seems a little easier and cheaper.
03-09-2017, 09:31 AM | #13 |
Between shutz paint and clear, 350ish in paint, I went this route because I didn't want to add a bunch of weight, and wanted a very specific sheen
03-12-2017, 10:56 PM | #14 |
I need to redo my top and fix some cracks here and there. I know you should use epoxy resin for the glass work because the polly won't stick but what about the raptor liner? Will it stick to the bare smc or should it be primed with an epoxy primer first? I've got a raptor kit setting in my garage that I bought a few years ago to do a truck bed which never happened. Hope it's still usable. Not sure what the shelf life is on that stuff.
03-13-2017, 08:57 AM | #15 | |
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
03-13-2017, 09:29 AM | #16 |
I've got some west systems two part epoxy already... Didn't think about needing special filler too. Thanks for the heads up. That's some pricey filler.
07-17-2017, 11:34 AM | #17 |
Good information on this thread, thanks a lot everyone.
01-15-2018, 04:48 PM | #18 |
I like the chip guard
01-16-2018, 08:58 AM | #19 |
Here's another good source for some epoxy resin and such
https://www.fibreglast.com/product/S...0/Epoxy_Resins
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
04-16-2018, 01:56 PM | #20 |
04-16-2018, 06:32 PM | #21 |
I sprayed raptor liner on mine with the supplied shutz gun... Turned out great.
04-16-2018, 06:34 PM | #22 |
That does look good!
04-18-2018, 10:32 PM | #23 |
Carpe manana
My top is almost to the paint point. Was looking at the work member Ironcanine did with his top using the U-Pol product Gravitex with a very nice result.
04-18-2018, 10:34 PM | #24 |
Carpe manana
04-18-2018, 10:52 PM | #25 |
Carpe manana
Anyone familiar with Zolatone and would it replicate the OEM texture?
