Cutting tail lights
Anybody tried to modifying tail lights cut lenses and lay them down ?on 72 burb
Re: Cutting tail lights
Good question, I have thought about trying that myself but if someone has the lessons learned and can share; that would be great!!!!
#3 | |
The Older Generation
You mean so they are flat like a pickup? LockDoc
![]() Join Date: Mar 2000
Fleetside tail light lenses fit the Suburban / Panel trucks exactly, so you can get the lens flat by just installing these. That still leaves the taillight housing protruding from the body. To get the lens flush with body remove the tail light housing. On the back of the at the top outside of the recessed bowl the bulb sits in you'll see a 90 degree metal tab, remove tab, now trace shape of bowl onto metal directly behind the housing and cut the metal out. You can now set the tail light housing flush with body to mount it, install the fleet side tail light lens and your done.
Paul Jr. @ GMCPauls Last edited by GMCPaul; 01-26-2017 at 01:27 PM. |
That is a good tip.....
#6 | |
#7 | |
Take a moment to remove 1 lens on your tail light and you'll easily be able to see the small metal tab that holds the housing up off the body and you'll be able to easily see the metal behind bulb section of housing that needs trimmed out so the housing will sit flush. Paul Jr. @ GMCPauls |
Great tip!
The truck lenses are narrower there's a step I think I will still cut the stock lenses thanks for the other helpful info
The base of truck lens are Exactly the same width as a Suburban tail light lens mounting base. The Suburban lens is thicker ( greater in depth front to back ) that's why they stand up off the body, and just slightly wider at bottom outside of base to hide the housing standing up off the body but the difference in width there is only 3/16" per side and when you lay the housing flat and use the truck tail light lens it appears just like that shown on our 67 panel truck.
I ordered a set of LED truck taillights to do this "mod". The gap was way too big for me so I just reinstalled my factory taillights. Ill just sale the LEDs I bought. It was worth a shot, I just could not live with that big of a gap around the lights (3/8" +/- all around). If anyone else has a solution to the gap, please share or provide detailed close up pictures of how you did this. Thanks
#12 | |
