#126 |
![]() Join Date: Dec 2012
Re: 1970 Med Olive Project
It's a small world...I'll get those pictures to you tomorrow night
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#127 |
No problem thanks again
#128 |
Anytime sir
#129 |
![]() Join Date: Jul 2012
Nice work, looking very good!
#130 |
When I was calculating my driveline angles I used washers as spacers to put the carrier bearing where I needed it. I had a local shop machine a spacer to replace the washers.
![]() ![]() I also modified my PB crossmember today to allow room for my exhaust. ![]() ![]() ![]() I hope to have the exhaust finished tomorrow.
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 Last edited by MMcMasters; 02-19-2017 at 12:10 AM. |
#131 |
Wow nice work love it!
#132 |
![]() Join Date: Jan 2015
Looks great Mike!
Jimmy Hoelzel |
#133 |
![]() Join Date: Dec 2006
Looks good Mike!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#134 |
Thanks guys!
#135 |
I can't leave anything alone. I was looking at the crossmember mod that I did yesterday and started worrying about how heavy the tail shaft of the transmission is. I worried the open gaps would allow the boxed sections to flex. I cut some small pieces of 1/8" and used it for gussets.
#136 |
Perfection love the work!
#137 |
Being a gearhead gets annoying sometimes, no matter how good something is we always have to modify it to make it better!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#138 | |
Thanks Jason
#139 |
I worked on my exhaust again today. It's all tacked together and I'm fairly happy with it, almost...I may lower the mufflers
I want to be able to remove the entire system if the need arises so I flanged the head pipes in front of the H pipe and I'm going to use a band clamp just in front of the trailing arm crossmember. I plan to finish my hangers tomorrow and finish weld everything. Then I'm going to have the entire system ceramic coated. I'm running out of excuses to not start pulling the green truck apart and prepping it to go onto this chassis ![]() ![]() ![]()
#140 |
Nice job on the exhaust Mike!
#141 | |
![]() Join Date: Jun 2009
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#142 |
I finished welded everything from the h pipe forward this morning. The more I looked at how I had the mufflers, the more I didn't like it. I have been thinking how I want to raise my bed floor and where I want to put my air management and I realized the mufflers would be in the way. I simplified it a little and lowered them 4". I think it really cleaned things up and it will be less restrictive. What do you guys think, I'm hoping for some opinions.
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 Last edited by MMcMasters; 02-26-2017 at 09:19 PM. |
#143 |
The never ending exhaust project is almost complete. I pulled everything back off and ran every piece through the media cabinet to prepare it for coating. My initial plan was to send the entire system to Jet-Hot to have it coated but their quote of $900 about made me sick.
I have a buddy on my department who customizes AR-15's and pistols and he uses a product called Cerekote. He told me it is hard as a rock once cured and is good to 2000 degrees. I called Cerekote and told them what I planned to use their product on and they said it would work great for my application. I ordered 1 qt of their graphite black for $132.00. I spent the better part of 3 hours cleaning, blasting and re-cleaning every piece to prep it for coating. My buddy let me use his booth and he sprayed it all this afternoon. The tech sheet says it will tack up in 35 mins and partially cure, enough to handle, in 24 hours. It's fully cured and ready for abuse after another 4 days. Only time will tell if it will hold up but it sure does look nice right now. Fingers crossed!!! I will pick it up tomorrow afternoon and get it installed for the final time. Disassembly on the green truck starts tomorrow too. It's getting real now ![]() ![]() ![]() ![]() ![]()
#144 |
A320 Pilot/USAF Retired
Awesome detail work on the entire rolling chassis!
Looking forward to seeing the body swap too! ![]()
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#145 |
What do you guys think of the finished product? My main objective was to be able to remove the whole thing without any cutting. I'm pretty happy with it.
#146 |
Wow !!! That is one of the nicest looking builds I have seen
#147 |
So did the cerekote get sprayed dtm ?
#148 |
Looks great! Be interesting to see how the product holds up over time.
#149 |
Larry,
I degreased everything then prepped the surface with 80 grit glass beed. Everything was then wiped down with wax and grease remover and sprayed with two light coats. They recommend 1mil of coverage. Just made sure the bottle was mixed good and poured directly into the gun with no thinning. It sprayed like **** but flowed out nice once it was on. 30 minute flash time between coats. I let it hang for 24 hours before I touched it. They said it is fully cured 5 days after spraying. They also have a oven cured product but I didn't have access to an oven large enough so I went this route.
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 Last edited by MMcMasters; 03-07-2017 at 10:38 AM. |
#150 |
[QUOTE=Advanced Design;7877296]Looks great! Be interesting to see how the product holds up over time.[/QUOTE
I hear ya ![]() They told me if I followed their prep instructions I will get years of service with no discoloration or corrosion. Only time will tell.
