Old 03-06-2017, 08:47 AM   #201
MMcMasters
MMcMasters's Avatar
Re: 1967 Custom Sport Shop Truck
Nice work Jesse! Rust sucks but you have the right attitude about it, one fix at a time! Great progress man!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 03-06-2017, 09:10 AM   #202
boostedc10
boostedc10's Avatar
Nice work so far, following along for the ride!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 03-06-2017, 10:01 AM   #203
67ChevyRedneck
67ChevyRedneck's Avatar
Originally Posted by GR8-68 View Post
Looking good Jesse, I like the tag. Did they powder coat it to be reflective ?
No, we just went back with close to the original colors. The blue is a bit off, but I like it. The same guy redid my Mustang plates for me too, but he said he hated doing them so much that I wasn't allowed to tell anyone who did them
It's a lot easier mentally knowing I can still jump in the truck and cruise or go to a show (like I did on Saturday). I'm trying to minimize how long the truck itself will be down. The cab is very solid overall, but I made my own homemade rockers out of roofing tin (I know I know, I promise it's the only place I red-necked the body). They were meant to be temporary, I did them like 19 years ago... you can't even tell they're not real rockers today... The overall floor and inner rockers are very solid, but the lower kick panels will need a small section. I did have holes around the back window and expect some damage around the windshield, "just because." The under floor braces are a little crunchy the last couple inches near the rocker. So not terrible bad.
Thanks! Wait until y'all see the bed I bought... I've been keeping that quiet...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-06-2017, 06:13 PM   #204
rusty76
rusty76's Avatar
Really good work
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-12-2017, 12:25 AM   #205
67ChevyRedneck
Thanks man. Definitely a steep learning curve. I *hope* to have 1/2 the time in the 2nd door.
I finished up my high hump project. It's out of my grandpa's 72 1 ton, I used to put my feet up on it as a kid and help shift sitting between my grandparent's. My grandpa drove it like a DD. It was yellow ochre with a white top and black flat bed with the wood sides that pop off.
There's a few other pieces off the old 1 Ton on my C10 as well to help her live on.
It's going to be nice to have more clearance around the NV3500.
Jesse James
Project "On a Dime"
Old 03-12-2017, 12:42 AM   #206
67ChevyRedneck
I drilled the holes for the 67-70 mirrors. Lined them up, drilled a couple holes and plug welded the backing plate in. They're a total PIA to install when loose.
Jesse James
Project "On a Dime"
Old 03-12-2017, 12:49 AM   #207
67ChevyRedneck
Because I wanted to reuse the GM skin and I couldn't bend the original fold up without destroying both pieces, I cut the back skin off after the curve.
It came out way nicer than even I thought it would.
So that meant welding a new skin on the back. I also drilled holes and plug welded it about every 6-8" or so, like the factory one was.
Jesse James
Project "On a Dime"
Old 03-12-2017, 12:53 AM   #208
67ChevyRedneck
Good day. The door skin went back on pretty well. Very very minimal distortion. Very happy.
Jesse James
Project "On a Dime"
Old 03-12-2017, 01:00 AM   #209
67ChevyRedneck
Got some pics inside the door. It's been thoroughly coated. When the paint drys I'm also going to fill in the seam along the door bottom up along the sides with seam sealer leaving only the two vent holes open. Hopefully, that will keep any water out of the door seam itself diverted to the drain holes.
It literally looks like a new repop door inside.
I did find a couple cracks around the window frames I need to fix. I *hope* to finish the speaker hole close up tomorrow, but they're calling for snow and I'm not kicking my Mustang out in the snow.
Jesse James
Project "On a Dime"
Old 03-12-2017, 08:50 AM   #210
flashed
Very impressive work on the doors Jesse .
flashed is offline   Reply With Quote
Old 03-12-2017, 09:02 AM   #211
GR8-68
GR8-68's Avatar
Yes, it is looking great. Looks like you are making some great progress as well
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-12-2017, 04:08 PM   #212
67ChevyRedneck
Thanks guys. I was getting a bit worried in the middle. On the DS door I'm definitely going to repair the skin rust while it's still attached THEN remove the skin to do the inner corners.
So this was the horrific snow storm we got! Ok, it was a tad worse, for maybe 30 minutes there was barely a dusting on the ground and maybe 1/4" on the cars. Not the 2" that was predicted for here It was all gone in an hour or so.
Jesse James
Project "On a Dime"
Old 03-12-2017, 04:12 PM   #213
67ChevyRedneck
It sucks the pic is blurry... any guesses as to what I did here?
If you guessed "cut through the skin and brace" you are correct! It only took a few minutes to weld it back up but it was one of those "really" moments.
Jesse James
Project "On a Dime"
Old 03-12-2017, 04:17 PM   #214
67ChevyRedneck
I seam sealed the bottom making sure to leave the drains nice and clean. When it was almost dry I used the flat blade to smooth the transitions on the sides so water couldn't get behind it or sit.
Jesse James
Project "On a Dime"
Old 03-12-2017, 04:29 PM   #215
67ChevyRedneck
Last few pics are a close up of my plate (the specs are dirt, I can't keep anything clean...) There's also rubber washers under the washers
What's left of the inner door patch. For sale, slightly used door patch, $20
And finally, the speaker hole repair tacked in. That's all I could handle today, it was like 45* and I was freezing my ass off.
Jesse James
Project "On a Dime"
Old 03-12-2017, 06:15 PM   #216
rusty76
rusty76's Avatar
Doing some great work
My build thread
Crossmembers CC
Old 03-12-2017, 06:19 PM   #217
flashed
Looks great ,you want to put a new door skin on my non rusty California door ?
Old 03-12-2017, 08:55 PM   #218
67ChevyRedneck
Thanks guys! Taking her to run to the sun this coming weekend, so no progress for a bit.
Wait... what Bad dent damage?
I don't even know how I'm going to get done what I have planned for me this year! When we get back from Cali in May I'm supposed to start residing our house! I need a clone?
Jesse James
Project "On a Dime"
Old 03-12-2017, 09:17 PM   #219
flashed
Yes ,my Cali 4x4 dont have many straight panels on it but it has no rust .You are working pretty fast on yours .
Old 03-12-2017, 10:59 PM   #220
67ChevyRedneck
Ugh, bent up panels are *almost* as bad as rusty ones. That's why I kept these doors. Aside from a little "bondo over rust" in the lower corners I had them stripped when I was like 16, there is almost zero filler in them, they're completely straight. If I remember right, I didn't strip them completely bare, the red you see in the pics under the black is the factory primer, I just took the original White paint off. The factory medium blue the interior is painted is also under the dark blue I painted them.
Jesse James
Project "On a Dime"
Old 03-14-2017, 07:25 AM   #221
bluex
bluex's Avatar
Looking good man! I'm going to bug the crap out of you when I start my panel replacements.
bluex is offline   Reply With Quote
Old 03-14-2017, 10:02 AM   #222
67ChevyRedneck
So, I still have a few more years before I need to worry?
I still have a whole 'nother door to do. Come by and watch me screw up for a few hours before I finally get it right. It's probably pretty funny to watch...
When I get the bed done I'm doing rockers
Jesse James
Project "On a Dime"
Old 03-14-2017, 10:16 AM   #223
GR8-68
GR8-68's Avatar
I think the rockers was one of the easier parts to put on, with what you have already accomplished the rockers will be a breeze for you
Larry
"Project 68"
paypal.me/ldgrant
Old 03-14-2017, 10:40 AM   #224
bluex
bluex's Avatar
Possibly I'm either starting on that or fuel injection as the next big project. Havent decided which one yet honestly.
Old 03-14-2017, 11:14 AM   #225
Beetle
Beetle's Avatar
Read this from the start to now. Looks good man! Makes me wanna take all the rust outta mine and make it nice
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
