#251 |
Happy to be here
![]() Join Date: Mar 2000
Re: Shucks First Build
I agree. Heres a pic of that combo of tire size I plucked from my Facebook feed
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-24-2017 at 08:55 PM. |
#252 | |
As for the wheel choice I think I'm sold on the gray Torque Thrusts. 20x8 4.75 BS and 20x10 5.75 BS. The custom shop wheels can get the 5-5.5 BS but man I can't afford the extra $300 per wheel... Tires (My opinion) : Nitto NT555 G2 245/45/r20 and 295/40/r20. Question time : So I'm spraying primer right now, and its laying on fine but where I did my badge delete, you can see where my body filler tried to feather into the metal and you can see the "dip" with the light just right on both fenders. Will this block sand out or will I have to dig deeper and get back down to the metal? I sure thought I had it as smooth as possible. ![]() ![]() Edit : I let it dry for about an hour and it leveled out better, the dip is not near as bad but still there.
#253 |
I'm just glad to be here!
LOL, because I have a 19yr old boy...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#254 |
I think it will block out, but you might end up taking off most of that coat of primer. Guide coat that area (above the body line, the length of the fender) and work it first. If you end up breaking through that coat of primer, just redo that part of the fender.
#255 | |
![]() ![]() ![]() ![]() While painting it makes me realize how poorly the trucks come out of the factory, spot welds everywhere and runs that I've already sanded out, but it's funny to me how bad some areas are.
#256 |
This series of trucks was kind of when trucks were making the transition from work only vehicles to work by day and go to town at night vehicles. Lots of available options and fancy interior offerings. But they were still built with work truck fit and finish. Of course 70's cars were probably some of the worst built cars american factorys ever built.
#257 |
Just a quick post because I really like the way this is turning out. Scared for painting the outside of the truck... which is coming up shortly.
![]() ![]() ![]() Has anyone used these gauges? Or any info on them? LMC sells them. I just like the way these look compared to Dakota. ![]()
#258 |
looking good, When painting the outside everyone has their own way but what I do for an overall paint is start the farthest from the fan so you are not pulling overspray over freshly painted surfaces. If the hood is towards the fan start with the back of the cab, then paint the roof I would use a 3ft. ladder and start on one side paint to center then switch sides and paint from center out. Next go back around and paint the door then go around and paint other door ,switch sides again and do the fender and paint that side of the hood, go to other side and paint from center out and then that fender. The Idea is to not let any area dry to long before painting the adjacent panel and not let dry spray pull over wet paint. Just my way others may disagree.
#259 |
Guide coat made me feel a lot better about my fenders and doors. I've been busy and unable to work on the truck and kept thinking I had super wavy doors and fenders. Did some blocking and guiding and this is my results the first time around. Sure there are a couple spots but it sure looks better than I kept thinking.
![]() ![]() ![]() ![]() ![]() There you can see that dip on the fender was able to come out
#260 |
Looks good. Patience is all it takes to get a good result when doing this step in the build. for a first timer, you are doing a good job. You should be proud of you results.
#261 |
![]() ![]() ![]() Some panels need to be shifted around but this is all I can get done today. I'll get the hood in primer tomorrow then will be close to shooting the truck.
#262 |
Happy to be here
Awesome progress. Its starting to look like a truck again
#263 |
The body work is looking nice. I am dreading getting to that point.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#264 |
Thanks guys, means a lot.
So today I took a break from painting. Tired of the fumes... I began working on the bed since I really haven't touched it yet. I put the new fenders on to see how they fit and then I mocked up the roll pan. I do have a brand new rear bumper but I can't find the bumper brackets because they don't make them anymore... so I settled for a roll pan, not my forte but it's all I can do. Then I put the tailgate latches on because I didn't want the chains scratching my new paint. Plus it's a nice touch and they turned out cool. I also put the hood braces on today. Not sure if they work but it's better than nothing I suppose. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() This is the main part I wasn't a fan of in this kit. It sucks I had to drill through my tail gate. They had a backing plate to be used for support with those bolts but it just didn't look right. I won't be throwing big stuff in the bed so I did away with it. ![]() ![]()
#265 |
Looking good!
#266 | ||
Happy to be here
#267 |
The roll pan does look good. If you decide to go back to the step side bumper, they sell brackets for the 67-72 step sides. The step side bumper is the same from 67 to 87.
I used the 67-72 brackets when I did Sunburn a few years ago. I had to modify the inner bracket to get the bumper to line up correctly, but the outer brackets worked without modification. Look thru that build thread near the end, I am not sure if the pics of the modifications are in there, but that would be the only place. I think I got the brackets from LMC.
#268 | |
N2trux : I dig that first bolt, I might look into it
#269 |
I'm not normally a fan of roll pans either, but I agree that it looks good on the step side.
That tailgate latch kit is really cool too! Looks like it was easy to install and looks like a nice part. Good job on the build so far!
BUILD IT! DRIVE IT! My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=734098 |
#270 |
Happy to be here
Just an option you may not have considered. There are several styles available and can be purchased at Summit.com
#271 |
Oh there's always something needing done. It's hard not to get burnt out on this project.
So I got some metal work to do. I plan on capping off the ends of the tailgate so it's smooth wrapping around from front to back. Then figure something out where the latch was on the bed. ![]() ![]() Opinions on my tail light idea? I'm not a good fabricator so I don't know what else to do, and I don't like frenched lights in the pan. I like it this way just curious on what you guys think. ![]() ![]() ![]() ![]()
#272 |
If those lights are legal I think they are great. It will allow the rear end to stay nice and clean looking.
A thought on the bolt heads for the latch on the tail gate...weld studs to the tail gate. You just need short pieces of all thread. Weld them into the holes and grind it smooth.
#273 | |
![]() I've seen worse where I live. If those guys that smoke their tail lights with black paint don't get pulled over I sure shouldn't... As for the all thread, I'll probably end up doing one of those billet bolts n2trux referenced. I like your idea though, I still will keep that in mind.
#274 |
We used the same light on Sunburn. Only thing I had different was that we had to have a rear facing red reflector on the back of the truck. I had a couple made that we could attach to the license plate for inspection and general daily driving. But when we went to a show, we could take them off to clean up the rear...
#275 | |
