#51 |
![]() Join Date: Oct 2014
Re: 67-72 Bench Seat Bracket Differences
Another pic. 69-70?
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 04-01-2017 at 10:37 PM. |
#52 |
67-72 parts collector,…
![]() Join Date: Nov 2002
That's a 69-70 seat bracket.
#53 |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#54 |
![]() Join Date: Jul 2001
Subscribed to this, good info here. I have a pair of brackets in the garage I need to look at now, hope to identify exactly what they are from.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#55 |
Just wondering what the difference is between the 67-68 and 69-70 bench seat brackets, other than the different rear riser? I bought a '70 full foam seat that the guy had lowered the brackets on, and I picked up a set of spare brackets he had too so I could bring the seat back up to regular height. I came across this thread and now I realize the extra brackets I bought are 67-68. They bolt onto the frame fine, so I'm just wondering if there is a height difference or something between the brackets, or if it is simply a difference in construction/appearance.
#56 |
![]() Join Date: Dec 2013
Awesome thread, sub'd
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
#57 |
Keith,
Not trying to high jack your thread, it's very interesting and I know that the 67-68 seats both I believe tilt forward, but I don't believe it has anything to do with the seat brackets. Does anyone that you know of repo the drivers side seat brackets for the 69-72 buckets? |
#58 | |
That's why buckets are so high priced. Especially if complete.
#59 | |
Anyone know what the difference is between the 67-68 and 69-70 bench seat brackets, other than the rear riser? Will everything line up properly when I go to install the seat? Don't mean to hijack the thread, I figured this was a good place to ask the question. I can start a new thread if need be, I'm new to the site and still figuring it all out. |
#60 |
I can't imagine them interchanging.
They are shaped totally different. I would think the lower seat frame would have to match the year of the bracket. Maybe since you have the 70 seat and the 67-68 seat brackets, you could take a few pictures and tell US the answer.
#61 | |
So to add to the list of seat brackets, I did run across a C60 that had very similar tracks to the 69-70. I was restoring them, when I realized that one of them sat a hair lower than the other set. And there is a piece that is flat, where the other set is angled. Here a pic. The one on the left came out of the 80's C60, the right is the 69-70 track.
#62 | |
I finally got around to getting some pictures of the seat brackets. These are the 67-68 style brackets, and the seat is the 69-70 full foam style. The brackets seem to bolt up fine even though the brackets and seat are from different year ranges. I'm not sure if there is a height difference between the 69-70 brackets and these ones, or if the seat is at a slightly different angle with these brackets, but if there is a difference I would think it would be very minimal. Hope this helps someone else in the future. |
#63 |
Hope you guys can help. I am was gifted a 67 C30 that i am trying to bring back to life as a farm truck.
Can anyone tell me if a C10 from the same years and a C30 bench seat are the same. thanks much |
#64 |
Active Member
![]() Join Date: May 2016
Great information, Thanks!
#65 | |
I don't know about the bigger C40/C50 trucks.
#66 | |
#67 |
Another good picture of the differences in seat brackets.
Starting from the top: 67-68 69-70 71-72
#68 |
Wow, there is sure a lot to know about the various seat brackets! Does anyone know if 72 brackets will fit on a 73 bench seat? My seat is toast but the brackets are fine and I found a lead on a nice 73 seat. Thanks!
#69 | |
The 1973-1987 trucks are another generation up from 1967-1972 trucks. The other thing I would check, would be the length of the seat. The 73-80 seats are a bit longer than the earlier style seats. So you want to make sure it will even fit from door to door.
#70 |
Thanks TKCR! From other threads it sounds like the best way to go is to hope to find a 88-98 Silverado bench seat, fingers crossed the hunt begins!
#71 |
So, as long as we use the same year seat and tracks, they can be used in any 67-72 truck? I found a 70 seat that includes the tracks, that I would like to recover and put in my 71.
It's a plaid highlander seat, so it should be the full foam, right?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#72 | |
As far as it being a full foam, you’ll have to strip the seat down to know for sure.
#73 |
So, the 70 seats sat higher than the 71's? I thought the risers were taller to match the seat frames.
#74 |
That maybe the case. I would really need to see the underside of the frame & tracks to know better. I would have to compare pics of where they are mounted to the frame.
#75 | |
They will not interchange. Since the 67-68 and 69-70 seat brackets appear to be close, they may interchange. I do not know for sure. All seats sit at the same height.
