05-14-2017, 02:54 PM | #1 |
steering shaft question
hi all,purchased an ididit retrofit tilt column.looking for opinions on steering shaft,
collapsable or solid.steering box is 3/4 x 30 spline,column is 3/4 x 36 spline. any thoughts?? |
05-15-2017, 09:47 AM | #2 |
Re: steering shaft question
Collapsible is safer and in my opinion the way to go.
05-15-2017, 10:08 AM | #3 |
Rag joint with two different spline count halves? Borgeson Joint?
Definitely collapsible. From a safety aspect, the box is way too close to the front for a straight shaft. I knew a guy that got speared by one. It only happened once. |
05-15-2017, 01:41 PM | #4 |
these kits are avl. a new piece that bolts to the rag joint. double d that slides into that piece and a u-joint to the column from the DD shaft.
1961 chevy K10 my build is------------61K10 build |
05-15-2017, 08:22 PM | #5 |
thanks guys!collapsable it is!
05-15-2017, 09:33 PM | #6 |
But Found Her 25yrs Later!
Do you have the part #s ?
05-16-2017, 09:19 AM | #7 |
if you look on the borgeson website you can piece it together for your'e application
with rag joint,collapsible shaft and coupler for column end Last edited by oldtrux; 05-16-2017 at 09:20 AM. Reason: spelling |
05-16-2017, 07:28 PM | #8 | |
I guess I don't know exactly which pieces I need for a 65 2wd. I even sent them an email asking. They still haven't replied. I just figured if someone ordered such and such pieces and it worked, then I could just order the same. I'll keep researching.
05-16-2017, 07:58 PM | #9 | |
column end u joint (stainless) 3/4-36 spline x 1'' DD part # 113452 collapsible shaft part #450024 they also have 36" but i don't think we need that long just have to check your steering box spline size and your column end spline size funny,i emailed them and they got back to me within minutes.maybe they got busy.ordered through summit.hope this helps....dan |
05-16-2017, 08:33 PM | #10 | |
Moderator
05-16-2017, 08:43 PM | #11 |
Thank You!
05-16-2017, 08:50 PM | #12 |
05-16-2017, 09:05 PM | #13 |
Here's the other thread I've been posting in:
http://67-72chevytrucks.com/vboard/s...d.php?t=668946
05-17-2017, 12:38 AM | #14 | |
Moderator
What is the part number?... Hope you find it and share it with all of us.
