Old 05-25-2017, 10:21 PM   #1
shibbby911
55 chevy porterbuilt
Recently got me a 55 apache and porterbuilt front and rear kit
shibbby911 is offline   Reply With Quote
Old 05-25-2017, 11:08 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 55 apache porterbuilt
It's traditional to introduce your self here and to state what you intend for your project. Obviously, with your post you intend to change the suspension. Anything else? Engine? Trans? Interior?
By the way, 1955, 56 & 57 are NOT "Apaches". That name only applies to '58 & '59 in the Task Force ('55.2-'59) era half ton trucks. The 3/4 tons are Vikings. The larger trucks are called Spartans.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-25-2017, 11:15 PM   #3
shibbby911
Really I didn't know that thanks for the info hopefully I can change the title
Old 05-26-2017, 06:15 PM   #4
Russell Ashley
Russell Ashley's Avatar
Welcome to the forum. You started out with a great looking truck, wish mine looked that good. We love pictures so be sure to post lots of them as you go. That PB suspension looks beautiful, almost a shame to cover it up by putting it under the truck, LOL.
Russell Ashley is offline   Reply With Quote
Old 05-26-2017, 06:20 PM   #5
mongocanfly
mongocanfly's Avatar
That is a nice looking unit..
Old 05-28-2017, 09:16 PM   #6
Az. Hank
Az. Hank's Avatar
Nice! We need pictures....
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 05-31-2017, 11:41 AM   #7
shibbby911
Nothing has changed yet it has a rear end out of 90's chevy truck right now. Trying to figure out if I should have this one cut down or just get another one
Old 06-08-2017, 08:15 PM   #8
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Good looking 55!
I've got a PB frame going together for mine too!
ChuckDriver is offline   Reply With Quote
Old 06-11-2017, 02:15 PM   #9
shibbby911
Originally Posted by ChuckDriver View Post
Good looking 55!
Ya I actually follow you on instagram. Can't wait to see yours all finished up
Old 06-11-2017, 02:16 PM   #10
shibbby911
Me and a buddy worked on the truck some last night
Old 06-11-2017, 06:25 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
This is going to be a nice truck. Subscribing,...
Keith
Convert to disc brakes.
Old 06-18-2017, 03:56 PM   #12
shibbby911
Old 06-18-2017, 03:58 PM   #13
shibbby911
Anyone know which way the shock mounts go I haven't been able to figure it out or find any pics of it mounted
Old 06-18-2017, 04:00 PM   #14
lolife99
lolife99's Avatar
I believe that mount goes on the other side.
Keith
Old 06-20-2017, 10:55 AM   #15
shibbby911
I think your right it does fit better on the other side but it does still hit the frame bolt a little bit. I think I might be good tho if I upgraded to the ridetech shocks
Old 06-24-2017, 01:51 PM   #16
shibbby911
Any one know the widest rim and tire I can fit in the stock fenders on the rear?
Old 06-24-2017, 04:36 PM   #17
ChuckDriver
Are you going to mini tub the bed?
Old 06-24-2017, 05:16 PM   #18
shibbby911
No I'm not wanting to
Old 06-24-2017, 08:41 PM   #19
ChuckDriver
Without tubing it, it think 8in will be the max rim size that will fit under the fender.
Old 06-25-2017, 02:28 PM   #20
shibbby911
I went ahead and ordered 2 15 wheels that are 7 wide with a 4.25 backspace just to check the figment on the rear and because I figured I could use them on the front. But now after looking at the front I don't know if they are going to work
Old 06-25-2017, 09:48 PM   #21
ChuckDriver
The width of the rear end will determine what backspacing will work.
Old 06-28-2017, 02:56 PM   #22
shibbby911
Well 15x7 with a 4.25 backspace doesn't work on the front looks like Im gunna need a 6" wheel just gota figure out what backspace I need
Old 06-28-2017, 03:33 PM   #23
ChuckDriver
Will a 15in wheel work with the brake caliper installed?
Old 06-28-2017, 05:29 PM   #24
shibbby911
I haven't tried that yet but I was told that it would. I also just found out that I need the same size wheel that comes on a 74 c10 to clear every thing on the front. I've found that the stock size is 15x6 but I can't find the stock back space
Old 06-28-2017, 06:33 PM   #25
ChuckDriver
It looks like you have the CPP modular spindle. I would put the caliper on the spindle to confirm the 15in will fit over it.
