Leaking steering box
The steering box on my 3/4 ton 4x4 Suburban is leaking out of the seal and it's getting worse. How difficult is it to change out this seal? I also have a steering box from a 1/2 ton 2 wheel drive Suburban. Will they interchange? Both vehicles have over 500k miles.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
![]() Join Date: Jun 2012
Re: Leaking steering box
4x4 box pitman arm is clocked differently than a 2wd box. not interchangeable....unless you want to go with cross over steering. to replace the seal in the box that is leaking, you will need a pair of snapring pliers and a small seal puller although I do it slightly differently with a drill and sheet metal screws. disconnect the rag joint remove the snapring remove the dirt seal and use small seal puller to get old seal out then install new seal.
I bought a seal kit from Napa for like $20 |
you sir do it the hard way . . . .
remove pitman arm . clean mud/dirt from seal area . remove snap ring . BIG drain pan to catch fluid under the box . fluid in system . fire up and turn the wheel to the bump stop of the box . then bounce it off the stop with the steering wheel . . . .and POP the seal should come right out by its self. old school gm tech showed me this trick years ago . NOTE : orignal poster never said if input or output seal tho .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
It's the input seal that is leaking in mine.
I'm just glad to be here!
There is a great How To thread on resealing a power steering gear on here. Ill see if I can find it for you.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I found it, but let me make this statement before I add the link to it...Photosuckit has made this thread nearly useless. All the pictures are no longer there....
http://67-72chevytrucks.com/vboard/s...d.php?t=619634
#7 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Kevin, You are the man!
#9 | |
Not hardly.....I was referring to the input shaft. I too know many shortcuts that I have learned and USED with great success, that so called shortcut works about a third of the time but you ALWAYS get the MESS. No thanks |
Thanks for the tips. I changed out the input seal and put her all back together and it's leak free. It took me about 4 hrs to do the job. Fairly simple job IMO but if I were to do the job again, I would not remove the power steering box from the frame. I would have changed it in place. It was a challenge getting the box bolted back to the frame. Had to use rachet straps to lift it into place and it was horribly greasy from leaking for several years.
