Old 08-22-2017, 10:12 AM   #426
99 to Life
99 to Life's Avatar
Re: "Geronimo" 54' 3100 LS built in PA
when you coming in october? I need all the time I can get! Getting front bags in my 51' almost done with that, then onto the rear. as for geronimo going to tig up the exhaust friday I think, and try and get trans in. Then I can put cab on if I want, but I gotta lot of interior stripping and primer work to do still.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-22-2017, 11:37 AM   #427
Desert1957
Desert1957's Avatar
Originally Posted by 99 to Life View Post
8-19 hard to get good pics of the paint. but the one you can really see the color and metallic in the sunlight. trans was painted the other day and what a nightmare I had with my gun (last time I sprayed primer, I was out of gun cleaner so to say the least I had a hard time with color) I used a different cheapy gun to spray the firewall etc. came out good I think. I may buy another spray gun by the time I do doors and interior. was eyeing up this astro pneumatics.
started tearing about front clip to get stuff ready for body work and primer. doors need a tad more work than I thought, so started tearing them apart. Hoping to have everything painted by next month and start final assembly and wiring. Be nice to drive it bf snow fall!
You didn't tell us you're a painter also....
Desert
Desert1957 is offline   Reply With Quote
Old 08-22-2017, 05:57 PM   #428
99 to Life
99 to Life's Avatar
I wouldn't call myself a painter. hardly enough practice but I can get by and make it look pretty presentable to most! This is just single stage paint from summit, basically made by kirker. I use single stage bc of time. I want to paint a full truck someday and a car actually but its just a long ways off, I'd prolly do base clear on something like that.
Old 08-22-2017, 07:00 PM   #429
lower50's
lower50's's Avatar
We are going to the same Good Guys show we went to last year in Charlotte NC. We would be rolling through your neck of the woods on our way home Oct 25-26
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-09-2017, 12:20 AM   #430
99 to Life
99 to Life's Avatar
9-9 Feels like winter is right around the corner. Weather has been killing me. anyway, I really need to wrap up these doors, inner fenders and interior so I can get them painted. Once I do that, I'm most likely taking this truck down to my garage in town. I then have another 54' I'm going to set up the suspension on in this garage, its a truck I'm doing for a friend. So just racing against the weather again.
Doors were a tad rougher than I thought, and take longer to teardown and clean up too. Welded up a ton of ext mirror holes. My hobart shat the bed, so I'm using my back up eastwood. I'm dead broke but I need to get another welder bc the eastwood is for my home garage and I need it bc I'm doing the suspension on my 51'. I'm doing some trade work to obtain a nice Lincoln tig which I'll have at my main garage.
Lastly got trans mounted finally. Here is an adapter I needed bc this 4l60e wasn't mated to an LS from the factory. only other thing you have to do is expand the flexplate bolts (just 3 of them). I was going to paint this flexplate many times and the weather was trash so it never go done. Kinda regret not doing it. but oh well. getting driveshaft made soon and putting cab back on soon.
Old 09-10-2017, 10:44 PM   #431
99 to Life
99 to Life's Avatar
9-10 got doors about ready for primer I'd say 10hrs in the doors, stripping and fixing them. Spent about 4hrs on the inner fenders, patched all the extra holes, and fixed some other areas on them. Stripped back sides and coated with chassis saver. I'll be spraying raptor liner on them, then prepping top for primer and paint.
I still have some interior of cab to finish up, finalize dash, front fenders to strip and coat, also rear fenders and I'm done with the majority of parts. Then its basically final assembly, brakes, steering, trans lines, wiring, glass, interior. hahah its gonna take way longer than I expect!
Old 09-10-2017, 11:11 PM   #432
oldman3
oldman3's Avatar
99, those inner fender are in amazing good shape, and the black just shows it off...Jim
oldman3 is offline   Reply With Quote
Old 09-10-2017, 11:24 PM   #433
99 to Life
99 to Life's Avatar
yah not too bad. I'v seen much worse for sure. I have quite a few inner fenders bc it is def one thing that gets overlooked on a build. I buy em when I can. I like the stock inners on these trucks alot.
Old 09-11-2017, 06:21 PM   #434
lower50's
lower50's's Avatar
I love gloss black inner fenders.
1951 MG TD
Old 09-11-2017, 10:35 PM   #435
99 to Life
99 to Life's Avatar
well as do I, but they are getting same blue as firewall. doors and jams will be blue, bottom of dash blue, everything else will be accented with a khaki brown color. Just prepping and painting that stuff and firewall is prolly 80-100hrs dep on condition. I got 386hrs in this build so far. I was guessing this would take 500hr. So I'm prolly gonna be right on the money. Budget is pretty dang close too!
Old 09-15-2017, 10:28 PM   #436
99 to Life
99 to Life's Avatar
9-15 hours are adding up. put 5 more in today doing some final sanding on dash and doors, masked off cab and sprayed epoxy. I hit a few small parts and still have alot more to do. also got to do inner fenders. My goal is to get more stuff in high build, more stuff in epoxy and be caught up for moday so I can spray the color on everything. But I'll still prolly have some straggler parts I'll need to paint later on.
Old 09-15-2017, 11:13 PM   #437
oldman3
oldman3's Avatar
99, looks good buddy...Jim
Old 09-15-2017, 11:35 PM   #438
lower50's
lower50's's Avatar
Coming along really nice. It takes a lot of time but it will be worth it.
1951 MG TD
Old 09-16-2017, 01:07 PM   #439
joedoh
joedoh's Avatar
man you have a lot of hours in this truck but its really paying off. looks great as always.
Old 09-16-2017, 09:55 PM   #440
99 to Life
99 to Life's Avatar
9-16 Thanks guys, yes hours feel loooong when doing body work. I spent almost 7hrs straight today just prepping all these little parts and inner fenders. Bought a replacement steering wheel and filled some cracks in it. Cleaned the door hinges, stripped door molding, did body work on the glove box (Iv never seen on not dented) luckily the 54' ones are smooth. Cleaned up some carriage bolts that I'll use on a few visible areas of cab.
I feel a little hokey showing yinz my paint setup, but its what I got to deal with. I'll do high build primer tomorrow and sand. Then when I paint, I'll do that in closed doors most likely. Even though at this rate I can only paint a partial truck every two years, I'v been thinking of ways to make a paint and body only area. Either my other garage here and or adding onto my commercial garage in town.
Lastly, as most of you guys can relate, buying tools is sometimes not in the budget. I'v been doing all my work with HF guns and its ok but I want to start really seeing what I can accomplish with some decent stuff. So I'v read alot of good reviews on this 100$ gun. I'll try it and see and eventually just keep getting better guns and comparing. Im a huge believer in most of quality is the user not the tool.
Old 09-17-2017, 10:23 AM   #441
oldman3
oldman3's Avatar
99, I agree about the spray guns. I did mine with a cheap HVLP gun and my truck came out nice (for an at home job) even won best paint at a couple car shows. It's mainly used for primer now, since Mark bought better guns for paint and clear...Jim
Old 09-18-2017, 08:43 AM   #442
lower50's
lower50's's Avatar
Coming along nice. I have seen some great paint jobs with really cheap guns, so your one up on them.
1951 MG TD
Old 10-05-2017, 11:04 AM   #443
99 to Life
99 to Life's Avatar
10-5 Sorry for the lack of updates. My life has been super crazy. Finally about done with paint. Now onto final assembly. I'm happy with the color scheme. I seem to struggle with colors sometimes, I'll think about it for months and months sometimes. I did base clear on the tan and single stage on the blue. Some of the blue I didn't get to spray as wet looking, so I shot clear over it. Looks really nice even without cut and buff.
I don't have a booth so its hard not to get some contamination, but again its not going to be a perfect paint job for what this truck is.
Old 10-05-2017, 11:07 AM   #444
OutlawDrifter
Looks great, I like the color combo!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 10-05-2017, 12:05 PM   #445
MIKESAD50
Thats looking great. combo looks nice
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 10-05-2017, 06:08 PM   #446
lower50's
lower50's's Avatar
Can't wait to see it in person.
1951 MG TD
Old 10-05-2017, 07:15 PM   #447
oldman3
oldman3's Avatar
99, paint looks great to me, nice choice on two colors...Jim
Old 10-05-2017, 07:41 PM   #448
Advanced Design
Advanced Design's Avatar
Looks very good!
Advanced Design is offline   Reply With Quote
Old 10-06-2017, 09:49 AM   #449
joedoh
joedoh's Avatar
jeeze o man thats a gorgeous color
Old 10-06-2017, 08:30 PM   #450
Flysocal
Man I really like the color!
Flysocal is offline   Reply With Quote
1954, ls engine, patina
