Made some progress
Finally made some progress on my 74.. Front SuicideDoors crossmember is installed, motor and transmission is installed and bolted down, front spring perches are bolted, lower link bars done, upper wishbone is mocked up along with the upper crossmember.
Finally can see the end of the tunnel now.. Here are pics from yesterday.. ![]() ![]() ![]() ![]() Where the axle was before we found out we had to get a new frame.. ![]() One of the last pics while it was still rollin ![]() |
Re: Made some progress
It's been a bit but yeah have made a little more progress..
Motor that is now in it.. The other one needed to be rebuilt and I had this available. Needed a little going through but everything is new inside. ![]() Underneath the truck.. We did have to get a new frame because the other was tweaked.. Here is one shot from underneath. ![]() ![]() Passenger side shot.. Went with the SuicideDoors crossmember. This will allow me to lay flat on the ground. ![]() Truck on the ground with the body on it. ![]() |
![]() Join Date: Nov 2010
I love this truck, big inspiration for my 77. Had it as my wall paper forever
