Old 10-08-2017, 11:53 PM   #1401
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Well, seems like every project gets bit by the cancer bug sometime in its life. One day you're chugging along getting ready to install your sweet porterbuilt suspension when you remove a fender and find a few bubbles in the cowl. No big deal, you think, until you start poking at it with a screwdriver...
Best part: this was covered in a layer of bondo before being sprayed with bedliner/undercoating There was also a thick, rubbery sealant applied over bare metal in the wire gutter which trapped water, but there thankfully doesn't appear to be any rot through, just surface. Wonder what other surprises the PO left for me on the firewall? Guess I'll find out soon enough
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-09-2017, 10:26 AM   #1402
SCOTI
SCOTI's Avatar
That's a bummer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-09-2017, 11:08 AM   #1403
mcbassin
Still Learning
mcbassin's Avatar
That really sucks!
Old 10-09-2017, 11:14 AM   #1404
69gmcc10
69gmcc10's Avatar
...but if you fix all of the rust, what will you do without the sweet smell of exhaust and fuel and other engine compartment goodness smells wafting into the cab and soaking into your clothing and soul? It seems if you "fix" this your just gonna need to roll in the dirt every morning to smell like a man... not that there is anything wrong with that it's just more effort.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-09-2017, 03:18 PM   #1405
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by SCOTI View Post
That's a bummer.
Originally Posted by mcbassin View Post
That really sucks!
Haha, I got a giggle out of this. With the LS, I won't even have the sweet smell of unburnt fuel in the exhaust. Now at least I can get that hard-to-reach dead mouse out of there!
Fortunately, they make a cowl replacement panel now, but I'm still looking for experience from someone who has actually installed one to know what fitment is like. Guess I don't have any real choice other than to dig in. It's only time and money, after all--so much for the "quick suspension swap"...
-Chris
Old 10-09-2017, 06:38 PM   #1406
knomadd
knomadd's Avatar
I think this is only true if you use cat's. I don't have them on my 6.0 swap and I can smell unburnt fuel from the first couple of starts. That might change though.
Sucks about the rust. I had a similar cover-up happen on mine.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-09-2017, 09:17 PM   #1407
gringoloco
A guy with a truck
gringoloco's Avatar
Might get better as it learns? Either way, it has to be better than my bolt on out of the box and only set idle screws tuned edelbrock.
As for the rust, this is literally the only part of this truck I haven't explored, so this should be it for surprises. I know there's a little in the kick panels that I'll have to deal with at some point, but nothing of concern until I get ready to paint for real someday. Just hate that people cover stuff with bondo instead of fixing it properly. Oh well, it will get fixed right this time.
-Chris
Old 10-09-2017, 10:33 PM   #1408
knomadd
knomadd's Avatar
I hope so, but you're probably right. It has to be better than the carb on the small block.
-Duane
Old 10-09-2017, 10:59 PM   #1409
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Call, PM, or email DeWayne Morgan at Nsane Hot Rodz he's done a few and can hook you up with the parts you'll need.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 10-10-2017, 01:57 PM   #1410
aggie91
I'm just glad to be here!
aggie91's Avatar
based on what you did with the Blazer's rust spots, you should have no issues fixing that area even if the panel does not fit exactly right...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-10-2017, 04:57 PM   #1411
gringoloco
A guy with a truck
gringoloco's Avatar
If nothing else, it will run better. I'm ok with a little eye-watering
Thanks, I've been messaging with him. Seems the replacement is not a perfect solution. I may still order it and decide if I use it complete or for patch panels.
Thanks for that! I was just hoping not to have to do any more of this again right now
-Chris
Old 10-11-2017, 12:01 AM   #1412
gringoloco
A guy with a truck
gringoloco's Avatar
Minor tear-down progress. Almost ready to pull the engine That's not rust you see on the frame, but a thick layer of dirt. I swear I cleaned and painted last time I was in here, um, wow, almost 7 years ago. Guess it deserves to be a little dirty...
-Chris
Old 10-11-2017, 10:34 AM   #1413
SCOTI
SCOTI's Avatar
Yes sir. It does indeed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-23-2017, 11:12 AM   #1414
gringoloco
A guy with a truck
gringoloco's Avatar
Well, pushed her outside for a pressure bath (which was fun, due to the steep incline and no brakes, steering, or driveshaft). Once it was clean enough to work on, it was time for tear down...
-Chris
Old 10-23-2017, 11:23 AM   #1415
gringoloco
A guy with a truck
gringoloco's Avatar
Good bye, little small block. Almost feel bad about pulling this one, as it’s a strong running little motor and the last piece remaining from the old yellow Blazer. Oh well, life goes on. I’ll just have to slap some SBC valve covers on the 5.3 to make me feel better about it...
-Chris
Old 10-23-2017, 08:39 PM   #1416
knomadd
knomadd's Avatar
Looks like good progress (if tearing it down can be considered progress ) I remember going through that part like it was just last month.
-Duane
Old 10-24-2017, 12:23 AM   #1417
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, it’s kinda moving backwards. I’m also spotting a bunch of things I had been meaning to fix that I hadn’t planned on touching right now. So much for this little project not snow balling
-Chris
Old 10-24-2017, 10:17 AM   #1418
SCOTI
SCOTI's Avatar
= Scope Creep......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-24-2017, 10:34 AM   #1419
gringoloco
A guy with a truck
gringoloco's Avatar
= Scope Creep......
Haha, yes, which leads to budget and schedule over-runs
-Chris
Old 10-24-2017, 10:55 AM   #1420
SCOTI
SCOTI's Avatar
Well.... That will be a first
Not.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-24-2017, 02:41 PM   #1421
gringoloco
A guy with a truck
gringoloco's Avatar
Not.
Well, considering this was originally devised as a mild PB front with a NoLimit rear kit which has now become PB touring front and rear with an LS swap and major rust repair, I think I’m doing pretty well. Oh, wait... maybe not
-Chris
Old 10-24-2017, 09:31 PM   #1422
gringoloco
A guy with a truck
gringoloco's Avatar
Got the transmission pulled out and gave it a bath, only to find a big chunk of the tail shaft missing. Not sure how this happens, but sure goes a long way toward explaining the nagging leak I thought was coming from the rear seal...
-Chris
Old 10-24-2017, 09:45 PM   #1423
gringoloco
A guy with a truck
gringoloco's Avatar
Trying to decide what I’ll do with the firewall, as I plan to paint it while I’m doing the cowl panel. Might as well, right?
Few options I’m pondering are fully shaved (with ac lines where they currently reside), factory style “heater delete” panels (ac lines moved), or “ac delete” box, with lines coming through the hump. All are appealing, though I think shaved will be the cheapest and easiest while I’m already welding.
Thoughts?
-Chris
Old 10-24-2017, 10:01 PM   #1424
darkhorse970
darkhorse970's Avatar
I like the look of the factory style delete panels.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 10-24-2017, 10:25 PM   #1425
gringoloco
A guy with a truck
gringoloco's Avatar
I’m kinda digging them, too, especially when painted to match. Of course, that’s the most expensive of the options when you factor in having to move the ac and heater lines.
-Chris
