#826 |
Re: 1956 Chevy Pro-Street Build
Very nice. Cops stop me now days to see whats inside my trailer. Still makes me nervous every time expecting a ticket or they will find something wrong.
Thanks for the grill info. I found the solder stuff I'm good to go now.
My 55 Build 55 C-4 |
#827 |
Truck build has been so interesting all along, so clean and smooth too, plus the tires, ahh so killer.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#828 |
Haven't been on this board for a while, too busy...
Now I see the pics that weren't on FB, I see what I missed, my bad. Looks like I have got to see it in person ![]() American tour in the making.....
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#829 |
Bring your brushes, Ill buy paint - I want some of the "Rockin'Kees" pinstriping on my rig!
My Build: 57 Chevy Pro-Street |
#830 |
![]() ![]() Join Date: May 2015
man that truck looks sooooo good...that stance is killer
#831 |
Ptc, have a question on your paint, is that a satin paint, matte paint, semi gloss,? It looks good, thanks
#832 |
![]() Join Date: May 2007
how did I miss this? the grille is amazing!nice work and congrats on the drive
#833 | |
Dont thin it much at all - i did too much and basically had to wash it all off with a garden hose the first go around. It looks decent in the pics but its kinda splotchy in places. Im sure if I had a paint booth and controlled environment to spray in, it could have been better, but it was a driveway paint job and thats it. ![]()
#834 | |
"Amazing" is a bit much but thanks, I did have really big ideas for that grill but had to dial back my expectations just a bit. but it came out ok after it was all done and said. Overall I wanted to keep the truck body exterior looking 'old'... and I didn't want any chrome. The satin Stainless color came out pretty nice. Gonna be some more of that. Still doing some fine tuning of things here and there before I take the big cruise.... down to the alignment shop! ![]()
#835 |
last I checked in I think you had just modded the hood, still one of the most unique mods I have seen!
that was probably a year ago ![]()
#836 | |
![]() I have all the metal in the rear bed to complete and the inner fender wells to custom make, so I do have some more winter work to do yet. But once I get it aligned and I can take it for drives to the store or just locally wherever. The dirt this thing kicks up is incredible!!!! needs a bath everytime I take it out. ![]()
#837 |
Got all the 5" intake tubing at a Trucker Supply Store and its all welded up into place and had to make a support rod for it since it hangs out so far off the supercharger.
I had to redo the hat as the 1/4-20 air cleaner rod was not holding the hat on. I spoke with the guys at Extreme Velocity and they said yea you need to get rid of that, drill and thread it 5/16-18 and put in stainless steel rod. It wont stretch when it comes on boost. I was wondering why I kept blowing out the air cleaner paper gaskets no matter how tight it was. So I drilled it and re-threaded it and put a 5/16 S/S rod in there, a new Fel-Pro composite gasket that is metal lined , double nutted with a nylock too and it holds boost now! Got all the boost reference lines done in Vibrant poly tubing and quik insert fittings, I love these things! they work great. And then I got the hood onto the truck finally and it looks almost complete. Needs alot of adjustment but its on for now. I tried riggin up a remote latch release because of my grill but found an easier way. If anybody needs a really nice custom latch release I got one! ![]() ![]() ![]()
#838 |
Super clean design.
Mudman.
#839 |
Looking good PTC!
#840 |
I never would have thought the bolt would stretch.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#841 | |
Thanks DG |
#842 |
I know your question wasn't directed towards me but I'll throw this out there anyway. I grafted a VW style hood latch in place of the stock one. It's a lot cleaner looking and has a better secondary latch...
#843 | |
The stock latch on mine I just bent the lifter handle down just a bit more to clear my grill matte material and then cut the grill matte material for the handle to come through it. I also painted the handle satin black so you cant really see it in the grill matte. Thanks guys for all your other comments!!! appreciate it!
#844 |
Yea me either! --1/4"?? The EV engineer said at 12psi boost there is actually about 300 lbs of pressure lifting up on a 4150 carb throttle body (5" dia). At 30 psi it can be upwards of 750 lbs!!! thats crazy.
My truck now at idle, opens the blow off valve because it is producing boost that goes no where with the throttle plates closed. I thought it was messed up, but before I fixed it, it was blowing past the carb hat gasket. Learn something new every minute on these things! ![]()
#845 |
Heres my battery box cover that slammed57 built for me - Thanks SO MUCH!!! - it came out real nice with the lifeter handle and powdercoat.
I just have to get my sheetmetal all cut into place so I can mount it up. ![]() ![]()
#846 |
This is the latch I used, they can be found used on '85-'92 VW Jettas, Golfs and other models. It is set up for a cable release FWIW.
http://www.yogisinc.com/index.cfm/pa...d/prd13796.htm Keep in mind that the filler between the radiator and the grille is different on a '56 and '58 so installing one might be a little different. I cut out the oval shape in the filler panel and welded in the lower latch from underneath. The upper latch was bolted to the existing under hood latch plate, only minor shimming and trimming was necessary. Sorry no other pics and with the truck blown apart I cant go take one for you. |
#847 | |
Mighty car mods explane it well. https://www.youtube.com/watch?v=atretf9u-Mc
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually Last edited by lower50's; 12-12-2017 at 08:13 AM. |
#848 |
![]() Join Date: Jan 2015
Glad it work out for you buddy, Truck is comin along quite nicely!
#849 |
clean work on the battery box, slammed57 does some nice work
#850 |
Everything looks great!
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
