Heater stopped working, blowing fuses, melted the wire connector
Hi everyone
Recently I broke the arms on my heater (no ac) so I got the unbreakable levers from Brothers. I put them on a week or two ago and all was good. Today I noticed my heater wasn’t on and the fuse was blown. I put a new fuse in and it blew right away. I looked at the wires that plug into the switch and it was a little bit melted at the bottom most terminal I will need new wiring harness for the heater, but do you think also I need a new switch? Or whole new heater control? Is there something else that may be or is likely the culprit? Posted via Mobile Device |
The Older Generation
Re: Heater stopped working, blowing fuses, melted the wire connector
I would replace the switch too. I would also check the heater resistor located in the heater duct. (follow the wires to it) It may be shorted inside. I can't remember if the screws are 1/4" or 5/16", 5/16" I think. Careful when you remove it, the wire coils are pretty fragile. A heater motor that is dragging or squirrel cage that is full of mouse nests might cause the electrical components to overheat too. LockDoc
#3 | |
I had an extra wiring harness so I decided to hook it up. Blew a fuse again, a little smoke from the fuse box and the switch on the heater control was hot. I’m going to get a whole new assembly to see if that fixes it.. the reconditioning kit I used looks kinda ****ty anyway with the sticker decal .
1977 SWB (c20 conversion) SBC350 Springfield Oregon Instagram: @nevernotchevy |
#5 | |
Let us know if that cures the fuse problem. LockDoc
Replaced the blower motor and connected it with a better ground wire than i had, and it works! thanks for the suggestions
#7 | |
![]() Join Date: Jul 2015
