ford bolt pattern on chevy
ok so first off, i know some people are going to pull their hair out and yell at me for this, just know your rants fall on deaf ears, i am not looking for your opinion of what i should do with my truck, only tech help, now that we are clear on that, my question is as follows:
is there a way to convert the FRONT of a 67-72 c10 from the stock 6lug pattern to the big ford 5x5.5 truck pattern (spindles that fit the ford rotor, ford rotor that fits on chevy spindle, etc), i know what your going to say "you idiot why would you want to do that", simple, i have a ford 9" that was given to me that i intend to swap into my truck in place of the 12 bolt, for obvious reasons, i know you can convert the rear to 6 lug chevy pattern, the only swap kit i found is 800 bucks, so if i can swap the front to the ford pattern to match the rear for cheaper, i am willing to buy new wheels (cause lets be honest, ford wheels are cheap too). i know speedway has rotors that fit the chevy spindle and has a ford pattern, HOWEVER, they use the small ford car pattern, i want the big truck pattern, if someone sells rotors that have the big pattern and fit on chevy spindles, that would be perfect. thanks for any advice. |
Re: ford bolt pattern on chevy
Good Luck ,,, I have not heard of this being done but more will chime in... even more if your post didnt start so defensively .....
Stan 67 swb BLU MULE posted via flip-fone |
apologies, i have had a few run ins on other forums where people seem to be there only to bash others for their choice in modifications
It's yer truck , make it better however you want !
I’d yell at you and pull out my hair but alas I don’t have much hair left!
Have you looked into redrilling the rotors. That might work but the hub(centre hole) might be the problem. Or you could try adaptors. Next thing you’ll be doing is putting a ford motor in that Chevy. Lol! And welcome to the zoo! |
naw, its a twin turbo 350 with a built th400
if i could find a cheaper kit to convert the rear to 6 lug i would not even think about this, im open to all options at this point so any advice or ideas are welcome |
ok i seem to have found something that might work better,
http://www.quickperformance.com/Quic...pair_p_49.html also i have found 71-72 5x5 front disc brake setup with spindles in my area on craigslist for around 150, thoughts? |
#8 | |
![]() Join Date: Feb 2002
Moser may be able to custom build you a pair of axles that fit your Ford 9'' and have the Chevy 6 lug bolt pattern.
#9 | |
The Older Generation
Welcome to the best board on the net! I think you will find this forum doesn't work like that. Anyone starts bashing on this forum they won't be around long... ![]() LockDoc .
There were Lincolns that came with 9" disc brake rears and their bolt pattern is 5 on 5. I'd think you could just use those rotor/hubs. Then again, Ford isn't known for parts swapability on the level Chevys are. I guess look to see if those front rotors will swap, too
If you redrill the rotor, you may run into a couple of problems. One is insufficient space inside the hub area for the studs to move out the extra 1/4". The other is the stiffening ribs between the studs.
If you want to drill the rear to six lug, using a trick from the import guys MAY work. Since both bolt patterns are on the same CIRCLE size, some times it's possible to take a drum or rotor of the pattern you want and bolt it on backwards using one stud ( after the rest have been knocked out ), and use it as a template to drill your new bolt pattern. This works if none of the holes overlap or are dangerously close together. I've never done this with the bolt patterns in question, only four-to-five lug, so idk if it'll work here. An easy way to get a visual of how it'll line up is to use spray paint through the drum holes after you bolt it to the axle flange. Apologies for the long post, but hope it helps. |
#12 | |
#14 | |
#15 | |
#16 | |
#17 |
![]() Join Date: Feb 2016
It would be much easier to to have your current 9 inch axles redrilled for the chevy pattern. It is not a big deal we just had a pair of 58 Pontiac axles redrilled for 5x4-3/4. It was under 100 bucks. If the pattern won't fit (6 on 5) then look at using later model metric 6 lug axles and redrill them. The off road web sites are full of information on these kinds of projects. Or run adapters (I'm not a fan of them but they seem to be everywhere these days).
Good luck and welcome aboard!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 02-07-2018 at 01:36 PM. |
#18 |
So you have the money for twin turbos, but not enough to build up the 12 bolt rear?
#19 |
Why don't you just take the axles out and drill them for a chevy bolt pattern? Any good machine shop should be able to do that for a reasonable cost.
#20 |
#21 |
thank you all for the ideas, i have learned two things so far,
1: i have good options that i can look into 2: this forum does not suffer from the same rampant assholes as other forums i have used, i will absolutely stay, i will be posting a more detailed build for my truck. |
#22 |
At the body shop.
Get new axles from moser. It's easy I narrowed an F-150 housing on one side to center the pinion in the rearend.
Tell them spline count and bold pattern. They'll walk you thru the rest of the measurements. Any bolt patern you want too
" That didnt make it any newer " " Dont antique the equipment " |
#23 |
Yes you are right we will be pull our teeth out
Brian Ritter |
#24 |
Nothing on a Ford should ever be installed on a Chevy
Brian Ritter |
#25 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Open mouth insert foot. You might want to rethink that statement. ![]() Then there's Vice Versa. and just for good measure.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
