Old 03-20-2018, 12:09 AM   #1
67ChevNut
Active Member
Problems with lights
Having issues with my taillights, etc. My taillights don't work unless I turn on the emergency flashers. The emergency flashers work ok if my headlight switch is off, but if I turn it on, they stop and my steady taillights work. My brake lights don't work, and my gauge cluster lights don't work either. The reverse lights don't work. My headlights work and my turn signals work too, only front passenger turn signal doesn't work. My headlight switch is new, my rear taillight wiring harness is also new, the flasher is new, and as far as I can see, the fuses are good too.
Where do I begin to fix this problem? What may be the problem(s)?
Sure appreciate any input, thank you.
67ChevNut is offline   Reply With Quote
Old 03-20-2018, 10:48 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Problems with lights
The first thing I would do if I were you is read this thread and make sure you have ground straps/wires in all necessary locations and that the ones that are already there are clean between the terminals and metal....
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
LockDoc
Leon
Old 03-20-2018, 10:02 PM   #3
Keystone_Hate
Like LockDoc said. Grounds.
Keystone_Hate is offline   Reply With Quote
Old 03-21-2018, 12:14 AM   #4
67ChevNut
Active Member
Great tip LockDoc, I'll follow your advice, hope I solve my problem. Thanks!
Old 03-21-2018, 08:50 AM   #5
LockDoc
LockDoc's Avatar
Let us know how it goes.
LockDoc
Leon
headlight, tail light, turn signals, wiring
