Old 04-17-2018, 05:04 PM   #26
68blackbird
68blackbird's Avatar
Re: Cab install jig?
Originally Posted by joedoh View Post
uh, that cab lifter is bigger than my garage.
THAT tractor makes the cab look like a Tonka toy...
Kel's 1950 GMC 1/2 ton build
68blackbird is offline   Reply With Quote
Old 04-18-2018, 02:19 PM   #27
R&B51
I saw you got it done. Be patient with me, 1st time to try posting pics. Just FYI pics since someone's help guided me to this and maybe have figured out how to post pics of description I put in earlier:
R&B51 is offline   Reply With Quote
Old 04-18-2018, 02:21 PM   #28
R&B51
sorry weren't sideways when pulled from my photo files. Ideas on how to know if a pic from phone will show sideways on this site?
Old 04-18-2018, 04:05 PM   #29
vintovka
vintovka's Avatar
I found on mine you have to hold phone horizontal with button under right thumb.
vintovka is offline   Reply With Quote
Old 04-18-2018, 04:15 PM   #30
68blackbird
Little help...
Old 04-18-2018, 05:23 PM   #31
R&B51
Thanks men. Sorry to take this thread sideways. Haven't started a build thread yet, didn't want to waste people's time and also humiliate myself if my crazy plan didn't work. Have lots of pics but not sure how phone was oriented when snapped em. Is there a way to tell? Check them before posting (all my reply said was <attch---> before actually hit reply button?
Any how did you straighten em up after I posted em?
Old 04-18-2018, 07:25 PM   #32
dsraven
send them to your home computer, orientate them correctly, save, then when you pic "manage attachments" here they should show up right side up. you prolly have a file on your home computer or laptop or tablet for your truck build....right....?
Old 04-18-2018, 10:06 PM   #33
Fred n' Ethel
Fred n' Ethel's Avatar
Originally Posted by 68blackbird View Post
Little help...
Hey Kel.
A bit hard for me to see what's going on here at the attach point of your fixture.
Is there an attachment ? or, are you just butting the hoist boom against the wood ?
Thanks.
Fred n' Ethel is offline   Reply With Quote
Old 04-19-2018, 10:03 AM   #34
R&B51
Fred N Ethel,
He was helping with my crummy pics, here's another attempt to send some better ones. This is a HF hoist and the end is just a little bigger than the receiver the hitch goes in on the truck, so took the hook off, slid the hitch in, cut a hole to match the pin from hitch or bolt already in hoist. Then this pic is wrong in that to use this, I flipped the ball upward (just took off my Bronco for this pic).
The frame upside down in pics from how you use it-is just a rectangle that fits across the level upper doorway of cab, I nailed cross braces on ends where it was centered side to side. The center brace has (3) 2x4's and center one has a few holes drilled front to back to allow the cab to sit level when pick up. I'm pretty sure I used the front most one. When you lift with hoist, it just sits level side to side and front to back on that one pivot point. Really stable and easy to move and position alone.
Cab dolly is long enough to tilt cab up on that firewall slant and prop up to work on bottom of it.
Again, these are all ideas I saw from someone smarter than me I think on this site.
We're all really standing on someone else's shoulders.
Should I be able to see the pics before sending? Just show up as "ATTACH..." files on the reply.
Old 04-19-2018, 08:06 PM   #35
Fred n' Ethel
Hey COOL... a ball n' socket joint. I like it !
All the "safe" flexibility you would need.
Thanks for the details.
Kindly.
Old 04-19-2018, 08:07 PM   #36
dsraven
you can click on the attachment after you upload (right where it says manage attachments) and it will open in another window/tab. you can see it and then close just that window/tab. dunno if it shows the pic as it will be shown on the site when you click submit, but you could try it. wouldn't be the first time a pic was upside down.
Old 04-19-2018, 08:10 PM   #37
Fred n' Ethel
There is also a "preview post" button that should show your post with the attachments exactly as it will appear prior to actually posting.
Old 04-20-2018, 08:19 AM   #38
gigamanx
Originally Posted by Advanced Design View Post
Another option...
Oh my lord. You don't even need a floor jack. Could probably pick up the whole truck at once and just work underneath.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 04-20-2018, 03:33 PM   #39
roger55
roger55's Avatar
Both the strap and the come along came from HF.
roger55 is offline   Reply With Quote
Old 04-20-2018, 10:10 PM   #40
Fred n' Ethel
Smile Re: Cab install jig?
Another option...
What is that ? ? a 6030 ?
Old 04-20-2018, 10:39 PM   #41
Advanced Design
Advanced Design's Avatar
Good guess. It is a 4620 and here is some information for anyone interested.
http://www.tractordata.com/farm-trac...eere-4620.html
Advanced Design is offline   Reply With Quote
Old 04-21-2018, 12:43 AM   #42
joedoh
joedoh's Avatar
fellas, I have grunted and yanked around on my last cab
IMG_1086 by Joe Doh, on Flickr
side shift, 48" forks, all maintenance. my brother in law (soon to be knighted for this score) bird dogged me on it from his shop that just replaced it. I wish it was a pneumatic instead of a smooth tire but at the price, I am not complaining.
Old 04-21-2018, 01:18 AM   #43
mongocanfly
mongocanfly's Avatar
nice score joedoh....now all you need is that 135hp that Doug's 4620 "forklift" has.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-21-2018, 07:46 AM   #44
Advanced Design
Great score on the fork lift! That would really be handy in the shop.
That 4620 is better outside.....just a little too big for easy maneuvering inside.
Old 04-21-2018, 11:54 AM   #45
MARTINSR
MARTINSR's Avatar
As long as you KNOW the hook is attached to a strong beam and you KNOW the hook is strong enough to hold it. That is an AWESOME way to do it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-21-2018, 12:04 PM   #46
MARTINSR
MARTINSR's Avatar
This was the dolly I made for my cab. I the OP is talking more about lifting the cab but I thought I would post this being it's a great way to go IF you can for a dolly. Being my cab was being modified so much mounting it to a frame with the proper mounts to hold it was essential. I lucked out and got a frame that was cut up pretty bad and worthless, all but this area was wasted, so it worked out great! When I am done with it, I hope I can find someone who needs it, I would hate to have to cut it up and throw it away.
But my next endeavor is to make a cart of some sort that I can roll the cab up and off our flatbed tow truck (or a car trailer) and get it over to the sand blasters. The thing is, I can do that with this cart, but I need to take it one step further and that's make it be able to tilt onto it's back so the underside can be blasted. Then when it's back home or at the shop in the booth be epoxy primed under it and then tilt the cab back to it's normal position to be primed on the top side.
I am thinking of making that dolly out of 2x4s.
Brian
1948 Chevy pickup
Old 04-21-2018, 12:09 PM   #47
roger55
roger55's Avatar
Brian
Thanks.
It is. It's an eye bolt that goes through a 2X6 laying on top of 2 2X8 rafters. Big heavy washer under the nut on the eye bolt. It would handle a bunch more weight than a completely stripped cab.
Old 04-21-2018, 12:13 PM   #48
roger55
roger55's Avatar
the OP is talking more about lifting the cab...
I dealt with that issue by having both a dolly and a table with wheels.
I just roll the cab off the dolly onto the table. Need 1 helper is all.
My good friend and neighbor (clay54 on this site) made this dolly for me:
The table was something my wife put together for moving plants inside the garage in the winter. I temporarily pilfered it and added the wheels:
Cab rolled on it's back on the table cutting all the rusted areas out:
Old 04-21-2018, 12:58 PM   #49
MARTINSR
MARTINSR's Avatar
Yeah, I was thinking of a cart like the one your cab is on in the upper picture. Something like that with extensions going up holding the cab so that the underside can be blasted and primed without tilting it, thought of that too. But I am going to work on a long cart, about 8-10 feet long with a tilting portion in the middle. Using large wheels that way it can be rolled onto the tow truck easy.
it will be made out of wood so it will be pretty inexpensive.
Brian
1948 Chevy pickup
Old 04-21-2018, 01:16 PM   #50
R&B51
MARTINSR:
[But my next endeavor is to make a cart of some sort that I can roll the cab up and off our flatbed tow truck (or a car trailer) and get it over to the sand blasters. The thing is, I can do that with this cart, but I need to take it one step further and that's make it be able to tilt onto it's back so the underside can be blasted. Then when it's back home or at the shop in the booth be epoxy primed under it and then tilt the cab back to it's normal position to be primed on the top side.]
That is why I made my cart a couple feet longer (again, stole that idea) and did all you said-rolled onto trailer, to blaster and back BUT I cheaped out and used some wheels I had laying around-worked fine but they hung up on every crack and will swap out for bigger next use. Surprising how easy it is for one guy to just tip forward and prop up 45 degrees (has been enough for me sitting on a roll around stool) but on the AD cab would have to be longer to get vertical.
