04-19-2018, 02:18 PM | #626 |
Re: 67 long box
Putting in the 0ne blocks seams strange me wanting to raise my truck but It will look better and ride better. I noticed that I never put in the bump stops so they are in mow too.
04-19-2018, 02:28 PM | #627 |
Re: 67 long box
Had to make a set of short drill bits to drill the bump stops as I forgot that too.
04-20-2018, 02:41 PM | #628 |
Re: 67 long box
My cover plate had too much flex so I put a bead in it old school style. Bent a piece of 1/4 round bar and beat the bead in with a hammer.
04-20-2018, 07:57 PM | #629 |
Re: 67 long box
Looking good, Doc. Still one of my favorite trucks.
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
04-21-2018, 01:09 AM | #630 |
Re: 67 long box
04-23-2018, 07:45 PM | #631 |
Re: 67 long box
Put the engine and tranny together and dropped them in the truck. Literally dropped it, the hoist hydraulics broke and down it went. Not a lot of major work to repair but what a piss off. I didn't even get a scratch so all is good. All cosmetic paint work and engine / tranny are fine.
04-23-2018, 08:11 PM | #632 |
How did I get this OLD!
Re: 67 long box
Ouch!!!!!
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
04-23-2018, 08:46 PM | #633 |
Re: 67 long box
Already looks better
04-23-2018, 09:49 PM | #634 |
Re: 67 long box
Much better...had to be a heart stopping moment when it dropped!
04-23-2018, 10:12 PM | #635 |
Re: 67 long box
I was very lucky just about crushed some fingers, but all good. I'm not doing to bad, this is only the second one I've dropped trying to do it myself without help. Stubborn old man won't ask for help. Just let it fall and fix the damage path.
04-24-2018, 12:09 AM | #636 |
Re: 67 long box
Did you seriously fix that in an hour and one minute?! Never mind the time to take your pics and post,,, That would be a 6 hour job for me, sheesh.
Last edited by cornerstone; 04-24-2018 at 12:10 AM. Reason: misspelled an... lol |
04-24-2018, 12:53 AM | #637 |
Re: 67 long box
Metal Doc for a reason But still needs a buff where I touched up the chips. I was going to fix it tomorrow but it was driving me nuts seeing it.
04-25-2018, 09:36 PM | #638 |
Re: 67 long box
Working on the tranny x member, too late now to start the grinder so tomorrow it is.
04-27-2018, 03:23 PM | #639 |
Re: 67 long box
One custom tranny x member done. Got all my pieces cut with my CNC plasma grinder.
04-27-2018, 09:12 PM | #640 |
Re: 67 long box
Dang brother! I need one of those! Very cool man.
04-28-2018, 12:49 AM | #641 |
Re: 67 long box
04-29-2018, 09:37 PM | #642 |
Re: 67 long box
Installed the new tranny mount and it looks great. I found out the clutch master was going to be too close to the exhaust so only other option was on the other side. Then had to add to the master push rod to reach the pedal. I'm going to replace the made piece with a heim joint. I made a cover plate that seals against the old grommet to fill the manual clutch rod hole.
04-30-2018, 07:12 AM | #643 |
Re: 67 long box
I appreciate the offer, but actually I was referring to your joke about the CNC grinder. Great work as always sir.
04-30-2018, 02:12 PM | #644 |
Re: 67 long box
04-30-2018, 06:49 PM | #645 |
Re: 67 long box
Had the CNC grinder going again to make a spacer/ strong back for the second hole on the clutch master
04-30-2018, 09:41 PM | #646 |
Re: 67 long box
great build as always.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
05-01-2018, 07:11 PM | #647 |
Re: 67 long box
Had a good day today and got lots done. Still waiting on the slip yoke and not sure what's going on with it. Makes it hard to seal the tailstock without one.
05-01-2018, 07:18 PM | #648 |
Re: 67 long box
Looking Good. I'm back in the Ayr area the 16th to 24th. I would like to pop by if your up for some company.
05-01-2018, 11:23 PM | #649 |
Re: 67 long box
Absolutely, but I'm gone on that weekend to the cottage. But I'll be home some of those days. I'll let ya know what days I'm here after I consult with the boss that's sleeping right now.
05-02-2018, 12:58 AM | #650 |
Re: 67 long box
Looks as good as if the General himself assembled it! When do you think you will get to fire it?
