Gauges - what are you running?
i currently have stock gauges the speedo doesnt work nor the fuel gauge. well what are you guys running? i was thinking something aftermarket
Re: Gauges - what are you running?
Restored factory gauges with tachometer and vacuum gauges. With the amp gauge converted to volt gauge.
I really like the way they came out and I didn't have to buy a new wire harness. I had the same as you, a speedometer and fuel gauge that didn't work and the rest were just lights. I bought a gauge cluster on ebay and had RedlineG add the tach and vacuum gauge. |
Ken, those oem gauges really look nice, plus take up NO extra space.
Sam |
![]() Join Date: Aug 2004
Autometer
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#5 | |
I just bought a stupid expensive vhx shi@ and now wish I had this! Oh well |
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#7 | |
The guy had me send the temp sending unit so he could calibrated the gauge to it. Now I know for sure my temp is correct. He also gave me choices on where the volt gauge would zero at. It could have zeroed pointing straight up so that when the key is off it would look like a stock Amp Gauge but I had him do the full sweep. I also had him add the numbers to the face. The tach is an original GM part that he converted to 6-cyl, not one of the aftermarket tachs that only work with a V-8. I also know now that my fuel sending unit is going bad. I wasn't sure if it was the gauge or the sender. I thought it was the gauge but now I KNOW it's good. Now I can order the sender and know I'm not buying parts I don't need. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Here's another thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=371684
Engine turn panel from Hayline, SoCal gauges
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Moderator
![]() ![]() Join Date: Aug 2011
Stock all new rebuilt with new volt meter, oil sender, fuel sender, tachometer, temp sender, clock. Ooooew we stitch jones.
Scrapper 1
How much dose that set up for the 1964-66 The one under me with the Clock an tack can this be used with the LS engines
Scrapper 1
It looks cool for my 1964 short bed fleet side big window
#15 |
