Old 01-25-2018, 05:38 PM   #2026
dsraven
Re: Kabwe's aka Bam's build
ha ha, thats a good one, get rid of some stuff. I have a bunch of stuff stored at a daughters garage. wife knows there is some stuff but no way she knows how much, lol.
trying to consolidate a few things myself so less mess seen out the kitchen window. working on getting the box on the frame and building mounts. then get the floor jacked up to clear the frame bump.
did you use a steel trailer fender for the inner edge of the tub?
Old 01-25-2018, 05:46 PM   #2027
BAM55
BAM55's Avatar
no I am using the stock 58-59 Fleetside tubs. I thought I would save time going stock, but they needed to be widened anyway.lol
BAM55 is offline   Reply With Quote
Old 01-29-2018, 01:52 PM   #2028
BAM55
BAM55's Avatar
Due to my narrowed rearend I had to widen the new wheel tubs for the fleetside bed. I had some sheet metal laying around that I cut into long 2 inch wide stripes.
Very simple mod but someone may be interested in how I widened them so I posted it. I will post another pic of them as soon as I finish the welding and metal finishing.
Old 02-01-2018, 06:51 PM   #2029
Rods57
Rods57's Avatar
Looks good, as always.
Rods57 is offline   Reply With Quote
Old 05-07-2018, 05:49 PM   #2030
BAM55
BAM55's Avatar
The truck is moving along slowly, but its moving along.
First a mod I did to the inner fenders.
I welded up one of the valleys in the inner fender to use a s a wire loom for the electrical wire going to the front of the truck.
Here is the other side that will hold the wires.
Filler, primer, block sanded, and painted
Front Fenders
New Radiator
Old 05-07-2018, 06:30 PM   #2031
Black_Sheep
Black_Sheep's Avatar
It looks great!
Black_Sheep is offline   Reply With Quote
Old 05-07-2018, 07:08 PM   #2032
Indian113
Indian113's Avatar
looking GOOD! So Smooth and I'm Lovin that Color
Indian113 is offline   Reply With Quote
Old 05-07-2018, 07:12 PM   #2033
oldman3
oldman3's Avatar
Bam, great work as always. Nice detail an looks super...Jim
oldman3 is offline   Reply With Quote
Old 05-07-2018, 07:54 PM   #2034
BAM55
BAM55's Avatar
Thanks guys. I appreciate all the comments.
Old 05-07-2018, 08:08 PM   #2035
Dan in Pasadena
Dan in Pasadena's Avatar
Hi Bam!
As usual, your work looks great, well thought out and pro performed.
Question: Have you had any issue making the paint match when you paint at different times due to...I don't know, humidity, drying times, etc?
Once again, the truck is looking SO good!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-07-2018, 08:38 PM   #2036
BAM55
BAM55's Avatar
Originally Posted by Dan in Pasadena View Post
Hi Bam!
No I have no issues with paint match. When I had that issue it was because I used paint mixed at different time or in different containers. So if I buy 2 gallons of paint I now pour it in one big bucket mix them together and put them back in the paint cans. My matching issues went away after that.
Old 05-07-2018, 10:28 PM   #2037
solidaxel
solidaxel's Avatar
Great color and the right shade
If you were going to but an accent/pinstripe what color(s) would you chose?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-08-2018, 01:56 AM   #2038
Dan in Pasadena
Great idea.
My painter painted my interior and interior steps before later painting the entire exterior. There is a very slight - but unacceptable to me - color difference just on the strip below the doors. He will repaint that and the difference from interior to exterior is so slight you can't see it UNLESS it's directly adjacent like that area. He says it al came from the same but I suspect it's like you are saying. two gallons that were not co-mixed before using.
Old 05-08-2018, 03:57 AM   #2039
Nut Case
Nut Case's Avatar
Fandamntastic X 10
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 05-08-2018, 07:54 AM   #2040
murd969
Been following this build for a while and as usual the work is flawless. Great job and can’t wait to see it done.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 05-08-2018, 08:00 AM   #2041
Kim57
Kim57's Avatar
Looks great.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-08-2018, 08:02 AM   #2042
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Color looks great!
ChuckDriver is offline   Reply With Quote
Old 05-08-2018, 01:03 PM   #2043
Daze57
Daze57's Avatar
great work as usual sir !
Daze57 is offline   Reply With Quote
Old 05-08-2018, 01:42 PM   #2044
dsraven
anybody know what that triangle shaped piece is for on the back side of the inner fender? just curious.
nice work Bam. gonna be great looking at the shine from those fenders while cruising this summer.
Old 05-08-2018, 07:05 PM   #2045
Dan in Pasadena
anybody know what that triangle shaped piece is for on the back side of the inner fender? just curious...
As far as I know it is just the factory's way of reinforcing the sheet metal inner fender so it wouldn't tear over the years. I could be wrong but that's what I have always assumed.
Old 05-09-2018, 10:05 AM   #2046
dsraven
ya, same here. it's "compromised" on mine now.....
Old 05-09-2018, 10:15 AM   #2047
bowt1ed
Love that color BAM!
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 05-10-2018, 11:46 AM   #2048
Az. Hank
Az. Hank's Avatar
Sweet!!
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 05-10-2018, 07:21 PM   #2049
BAM55
BAM55's Avatar
Thanks for the compliments guys.
Old 05-11-2018, 09:02 AM   #2050
57tailgater
I assume the triangle piece is a reinforcement as well. When you got a V8, the radiator was moved rearward and the core support was bolted further back in the recess. Picture the core support just being slid back. Looks like on these inner fenders the rear holes have been filled. You would need something more than some thin sheet metal to hold it all in place. The forward position has a lot of items converging at the top corner to supply the support.
57tailgater is offline   Reply With Quote
