Old 05-13-2018, 03:27 PM   #51
supercheyenne
Re: gm create motor ?
Originally Posted by PGSigns View Post
I have about 45000 on mine now in the 66. Mild comp cam, super victor intake, 670 street avenger carb. I have an in tank pump with an aeromotive return style regulator. works flawless.
Jimmy
Do you happen to have any info on your fuel pump and return setup? That sounds better than the external setup I'm dreaming up right now.
supercheyenne is offline   Reply With Quote
Old 05-13-2018, 05:21 PM   #52
Kudzupatch
Kudzupatch's Avatar
Originally Posted by swissarmychainsaw View Post
And you can do it for the same money... Just a thought!
Not the original poster but I am about the do the same L31 engine swap.
I looked seriously at the LS and the only way you can do it for the same money is with a used LS motor. The L31 is brand new, not a rebuild and it has a warranty. With a used LS there is no warranty if you have a bad one.
Plus there is a lot more work involved swapping in the LS. So it is not as cut and dry as it sounds. For me I figured I am going to get 80% as much for 25% of the work.
Kudzupatch is offline   Reply With Quote
Old 05-14-2018, 07:05 PM   #53
sweetk30
sweetk30's Avatar
any idea if this is a drop in cam for this crate motor ?
i can get it for less than retail and not much more than the gm cam .
https://www.summitracing.com/parts/cca-07-502-8
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-14-2018, 07:59 PM   #54
swissarmychainsaw
Also Jegs has the L31 for $1899
https://www.jegs.com/i/GM-Performanc...SABEgKRIfD_BwE
swissarmychainsaw is offline   Reply With Quote
Old 05-14-2018, 08:32 PM   #55
supercheyenne
Originally Posted by sweetk30 View Post
any idea if this is a drop in cam for this crate motor ? [/url]
It is NOT. Too much lift for the stock vortec heads.
REALLY if you're looking for "drop in" cam. I'd recommend running the one that comes in your motor. A drop in cam won't improve your motor enough to "cost justify' IMO.
If you were willing to change your springs, keepers, and retainers you could run that cam you selected. Google "ghetto grind". These guys sell a complete kit (and it's reasonably priced)
https://www.alexsparts.com/valve-spr...seat-pressure/
BTW, mine has arrived! I just tucked it away until I get some parts.
Old 05-14-2018, 08:55 PM   #56
sweetk30
sweetk30's Avatar
ebay is were i got mine . here with $100.00 visa gift card to boot .
https://www.ebay.com/itm/GM-OEM-NEW-...4AAOSwysRas9qX
Old 05-14-2018, 08:59 PM   #57
sweetk30
sweetk30's Avatar
cool info thanks for the answer . . .
Old 05-17-2018, 01:14 AM   #58
supercheyenne
If anyone comes up with a way to run an in tank fuel pump please share!
Or if someone could share what fuel pump would fit through the tank bulkhead I'm open to making my own stuff. I'm going with a Carb so I don't need high volume or pressure.
Old 05-17-2018, 07:11 AM   #59
PGSigns
PGSigns's Avatar
I have the Boyd welding EFI tank in mine with the Aeromotive pump. I had EFI on this truck for a bit till it quit and went back to a carb. I used Aeromotives return style regulator for running a carb and it sits dead on 6psi all the time. I like the idea of having the return as it helps keep the fuel temp down and that reduces the chance of vapor lock.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-18-2018, 07:38 PM   #60
Tom
driving is in my blood
Tom's Avatar
On a 73-87 you just swap in a 87 model tank with TBI pump already inside. Not sure what your working with though. Could always swap an 87 blazer tank into the spare tire area of frame too.
As for the distributor gear, just go to GM and get the oem melonized gear from a late 90's vortec 5.7L. I ran a take out vortec in my old 79 with a 200-4R behind it. Put a normal timing cover on, removed reluctor wheel. RPM intake. Melonzied distributor gear. Adjustable vaccum advance [way too much ignition timing for vortec heads stock, they want about 34* max] and ramhorns 2" manifolds [2.5" wont clear 73-87's]. Super easy.
Old 07-22-2018, 02:32 PM   #61
sweetk30
sweetk30's Avatar
update: leaving it as is out of the create .
water pump question .
can i just bolt on a 88-95 water pump for factory serp belt that i am going to run or do i have to mod anything ?
and any quick easy way to plug off the crank sensor hole in the timming cover ? as i dont plan to swap it over and my engine has a harmonic balancer on it from new out of the create .
Old 07-22-2018, 11:16 PM   #62
Captainfab
60-66 Nut
Yes you can bolt up any small block long water pump.
Look here regarding the crank sensor.
http://67-72chevytrucks.com/vboard/s...d.php?t=396643
Old 07-23-2018, 12:08 AM   #63
Captainfab
60-66 Nut
I found another option.
https://www.eficonnection.com/home/p...lt-kit-plastic
Old 07-26-2018, 01:48 PM   #64
Kudzupatch
Kudzupatch's Avatar
Your going to need a timing tab too.. I am just going to swap the timing cover with an old chrome unit I have. It has a timing mark. You can buy bolt on timing tabs.
Also consider putting in a one piece oil pan gasket while it is out. People rave about those so I plan on replacing the factory gaskets with one and doing the timing cover all at one time.
Old 07-26-2018, 11:16 PM   #65
Captainfab
60-66 Nut
Those crate engines as well as the factory installed Vortec engines have a one piece pan gasket from the factory. In fact I think all 1 piece rear main seal engines have a one piece pan gasket from the factory.
Old 07-27-2018, 07:33 AM   #66
Kudzupatch
Kudzupatch's Avatar
Thanks, did not know that. (obviously)
Old 09-11-2018, 12:47 PM   #67
RDrancher
RDrancher's Avatar
Glad I found this thread! I was all ready to pull the trigger with Jegs who price matched the ebay price of 1848.99 but, not only does the linked engine have a $50 Visa card, but also a $100 discount came outa nowhere at checkout! Total is $1748.99. Sweet!
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 09-11-2018, 03:32 PM   #68
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Score!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-12-2018, 10:12 AM   #69
RDrancher
RDrancher's Avatar
Old 09-17-2018, 11:56 PM   #70
LostMy65
LostMy65's Avatar
What minimum octane fuel can the L31 run?
Old 09-18-2018, 09:08 AM   #71
geezer#99
geezer#99's Avatar
Whatever your pump gas is rated at will work.
Old 09-19-2018, 08:19 AM   #72
Chevyrestorerman
I just purchased a GM turn key performance 350, going to install it into a 1971 blazer with a 700R4/NP205.
What is a create motor ?
Chevyrestorerman is offline   Reply With Quote
Old 09-19-2018, 08:51 AM   #73
geezer#99
geezer#99's Avatar
A ‘create’ motor is similar to your ‘turkey’ performance 350!
Add a letter, drop a letter!
Old 09-19-2018, 09:16 AM   #74
Chevyrestorerman
Is there a formula to know which letter to add and which to drop ? LOL!!!! Funny Forum.
Thought maybe this forum had a special create your own engine, changing camshafts and other parts to create your own, Thanks for the add and drop method
Old 09-19-2018, 10:06 AM   #75
geezer#99
geezer#99's Avatar
There is a formula!
It does involve some ‘metric’ calculations and a couple ‘french’ translations but otherwise easy to do.
Where is ‘X’ that it marks the spot and ‘Y’ do you live there?
