Old 05-29-2018, 01:29 PM   #1
1966burb
1966burb's Avatar
Tahoe whining noise
My 2001 Tahoe has a high pitched whining noise that seems like it is coming from the front end. Jacked up each wheel and spun and one front bearing sounded rough. Changed front hub bearing assembly. Road test -- same noise. Changed other side. Still has noise. About 40 to 60 mph. Can shift to neutral and noise remains. Can turn off key and coast and still has noise. Any ideas??
1966burb is offline   Reply With Quote
Old 05-29-2018, 07:16 PM   #2
YoungPup1977
Re: Tahoe whining noise
I missed something here, is it 4wd or 2wd ?
YoungPup1977 is offline   Reply With Quote
Old 05-29-2018, 11:12 PM   #3
1966burb
1966burb's Avatar
4wd
Old 05-29-2018, 11:36 PM   #4
truckdude239
truckdude239's Avatar
Its possible its a cv axle or something let go in the diff
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-30-2018, 09:14 AM   #5
1966burb
1966burb's Avatar
Thanks Jim
Old 05-30-2018, 09:44 AM   #6
YoungPup1977
start by eliminating things... I know its work, but in order to find it do the following:
remove the front driveshaft. drive vehicle, noise?
remove both front axles....most likely your noise will go away once you remove the axles....noise could be in the front differential, just guessing but once you start eliminating items you will find the problem GOOD LUCK !!!!
Old 08-10-2019, 10:33 AM   #7
1966burb
1966burb's Avatar
FOUND THE NOISE. Took it to a Chevrolet dealership where my buddy is the service manager. They put it up on a hoist and tested it running in 2WD and 4WD with no noises. Took it on a road test and heard the noise again. He concluded that something on the outside of the vehicle was causing the noise. At that moment the light came on!!! It's my BILLET grille that I had added. Came home and googled it, sure enough- another guy with Tahoe and same issue. Duct taped the loose ends and noise went away. I will be cutting some short 1/4 aluminum rods painted black and using epoxy to secure them across the loose ends on the back side. PROBLEM SOLVED.
Old 08-10-2019, 06:38 PM   #8
Glad you found the issue!
Old 09-02-2019, 03:05 AM   #9
mikelom
Glad that you found the culprit.
mikelom is offline   Reply With Quote
Old 09-02-2019, 05:23 AM   #10
95 S_Trucker
95 S_Trucker's Avatar
You will destroy your front hub bearings if you do this.
95 S_Trucker is offline   Reply With Quote
