Old 07-20-2018, 06:51 PM   #126
WEBBY1
WEBBY1's Avatar
Re: HOW TO: Crossmember sectioning ...
I'm running spindles and mmw control arms. looks like you might have to notch the control arm for steering shaft?
WEBBY1 is offline   Reply With Quote
Old 07-20-2018, 07:00 PM   #127
Wingnut Way
I’m all stock, going as cheap as possible. Yea probably I will do so after I slap cab back on and see exactly how much I need to knotch and where exactly
Wingnut Way is offline   Reply With Quote
Old 07-20-2018, 07:10 PM   #128
WEBBY1
WEBBY1's Avatar
I've been trying to stay cheap through the whole thing. and I have 7k into it
Old 07-20-2018, 08:40 PM   #129
jjzepplin
jjzepplin's Avatar
One of a kind is "priceless"! In my neck of the woods it sure would be...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-21-2018, 05:43 PM   #130
crakarjax
crakarjax's Avatar
I went 1.5" and when I realized that I'd need to notch the control arm I ordered a no limit R&P kit. I don't like spending $1k on a single component but for the amount of work it would take to DIY a R&P I think it's worth it.
Whether the no limit kit will work with a pancaked crossmember is yet to be seen...
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-21-2018, 06:37 PM   #131
Wingnut Way
I’ll save my $1000 and just weld some notches in
Old 07-23-2018, 12:24 PM   #132
crakarjax
crakarjax's Avatar
Yeah I think if you're fine with the stock steering there's no need to go R&P -- in my case I was going to convert in the future anyway, and just didn't want to waste the effort getting the stock steering to work now only to upgrade it later.
Old 07-24-2018, 05:53 PM   #133
tinydb84
tinydb84's Avatar
Nvm
David
Instagram: myfabguy
Old 07-26-2018, 06:42 PM   #134
SCOTI
SCOTI's Avatar
The X-member on my dually is notched 1.5" (89 Square body). The lower a-arms are PB 1" forward units but I originally had the modified OE lowers moved forward .750".
My set-up did require the small notch to the upper driver a-arm as mentioned. MMW uppers & later model OE uppers also had too large of an OD @ the bushing area & would not have cleared (I still have the MMW arms sitting in a box on the shelf three years later ).
When I'm air'd out, I can slip a slim piece of cardboard between the shaft/notch (like a spiral notebook cover).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-27-2018, 02:06 PM   #135
crakarjax
crakarjax's Avatar
Out of curiosity why did you ditch the factory lowers?
Old 07-27-2018, 02:46 PM   #136
SCOTI
SCOTI's Avatar
When I cupped the arms, I allowed for ~1/2" of clearance on my mock-up bag @ 25psi. Installed, the weight of the BBC plus those heavy hubs expanded the bad more than I liked (my clearance was about the thickness of a yardstick). I felt once the suspension started moving around, the bag would likely make contact.
I opted for Porterbuilt arms as they would swap right in place, had the forward placement option, & already had a tab for a sway bar (I still had to figure that out for the modified factory lowers as the original mounting position was no longer an option).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2018, 10:57 PM   #137
rudyyloverboiii
I too tried this and failed. Now i have to make my own motor mounts for my 292
nevertheless, it is an awesome write up
rudyyloverboiii is offline   Reply With Quote
Old 08-08-2018, 11:40 AM   #138
SCOTI
SCOTI's Avatar
Failed how?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-08-2018, 02:53 PM   #139
rudyyloverboiii
well it isnt a complete failure cus it looks cool and i made it work but im having a hard time leveling the engine and making motor mounts. So i went to put in a spare c20 cross member i had and its not the same. they are different
Old 08-08-2018, 04:07 PM   #140
SCOTI
SCOTI's Avatar
The way the x-member in this thread was sectioned should not alter the MM tower dimensions. Makes me wonder how yours are not working? I've done 4 of these & all re-used the MM towers w/o issue. One even used aftermarket MM towers & they fit/worked w/no problem.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-12-2018, 02:00 PM   #141
rudyyloverboiii
they bolt on just fine the problem is that i too have to section them as well to bolt on to the motor...
unless i make up the difference from the frame to the engine with some square tubing which i found out about yesterday
Old 08-13-2018, 11:42 AM   #142
crakarjax
crakarjax's Avatar
I think you did it wrong, the surface where the engine mounts should not have moved at all relative to the frame.
Old 08-13-2018, 06:04 PM   #143
SCOTI
SCOTI's Avatar
Not so much 'wrong' since there's more than one method/version of x-member notching. But, if he did it the way this "How To" thread describes, the MM towers should not require mods unless an x-member from a different year model was used.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-13-2018, 10:17 PM   #144
rickoner
I think the issue is when you raise the steering up to keep the stock geometry. That's the problem I ran into with mine. My crossmember was sectioned 2" and raised the steering the same. I had to move the engine up to clear the drag link. When I had the 292 in it, I spaced the mounts up about 1.750" and chopped some of the oil pan. I've now switched to an LS and had issues with the crank pulley hitting the drag link. I have the mounts spaced 1.5" and used dirty dingo sliders on square body clamshells. It took some moving around but I think I have the engine in a spot that they can coexist peacefully.
rickoner is offline   Reply With Quote
Old 08-14-2018, 01:14 AM   #145
SCOTI
SCOTI's Avatar
I didn't move the steering. I also limited things to 1.5" to avoid the domino effect. These trucks had geometry issues w/o modification. I didn't notice steering related issues until my Dually. But, that's my fault as I was super agressive on Caster (7-ish).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2018, 02:48 AM   #146
MQUnlimited
MQUnlimited's Avatar
Its been done.
MQUnlimited is offline   Reply With Quote
Old 08-14-2018, 10:35 AM   #147
SCOTI
SCOTI's Avatar
Originally Posted by MQUnlimited View Post
Its been done.
Post that info up if possible?
I've seen how they did their initial set-up for their R&P kit (notching the x-member @ the rail area only). I didn't think sectioning an x-member as described within this thread would work w/the NL R&P kit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2018, 11:55 AM   #148
crakarjax
crakarjax's Avatar
I got my no limit kit and it looks like everything will clear with some modifications to the mounting bracket and steering linkage location, and probably frame notches for the R&P links. Side note, not super happy with the quality of this kit -- sloppy grinding on the rack, hoses installed crooked, plastic crossover line instead of metal... probably more to notice upon install.
Old 08-14-2018, 12:09 PM   #149
SCOTI
SCOTI's Avatar
Ahh..... It could work w/further modifications.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-31-2020, 08:24 PM   #150
68c30bagged
what happened to the pics they dont show up
68c30bagged is offline   Reply With Quote
