08-12-2018, 06:47 PM | #1 |
Heater Housing Metal back
Hello All,
Finally getting into getting my 72 C-10 updated. I have teamed up with a local shop for motor and transmission rebuild while I refurb all brackets and under hood items. I am working on getting the heater core and condenser housing cleaned and replacing all switches, resistor and gaskets. My problem comes in with the metal plate behind the housing that holds the blower motor. Is there any such luck of someone making replacements for these? Otherwise does anyone have ideas to repair?[ATTACH]1810774[/ATTACH Thanks, Charles |
08-12-2018, 09:06 PM | #2 |
Re: Heater Housing Metal back
Just post a want to buy ad in the parts section , With everyone installing aftermarket A/C there are probably 100's of them under work benches all over the country .
08-13-2018, 06:35 AM | #3 |
Thanks Grumpy,
Took your advice and have it up now. Thanks, Charles |
08-13-2018, 07:28 AM | #4 |
I guess no one does make those heater housing parts, so as Grumpy Old Man says, used is your best bet. You shouldn't have a trouble finding one.
08-13-2018, 08:08 AM | #5 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-13-2018, 08:42 AM | #6 |
Give this guy a call he's in your neighborhood .
https://knoxville.craigslist.org/pts...612201733.html |
08-13-2018, 11:46 AM | #7 |
laying low
What’s the best way to save that metal part? I’ve got a rusty one. I was thinking about wire brushing it real good and maybe using por 15 on it. Possible toxic fumes from using it in that heated air flow a concern?
08-13-2018, 01:04 PM | #8 | |
The Older Generation
POR-15 would seal it up OK but you still need to get the inside coated. As hard as the POR gets I don't think you would get any fumes from it when dry. LockDoc
08-13-2018, 02:13 PM | #9 |
laying low
It is coming off to get to both sides. I’ve not used por 15 so im unaware of its cautions. Replacement brads can be picked up at parts stores. Or used to be.
08-13-2018, 02:57 PM | #10 |
OK , Quit ! There are no toxic fumes you need to worry about. Give it a break your not gonna be exposed to any " adverse gasses " The air your breathing everyday has worse affects than a short exposure to paint fumes . You "kids " need to realize us old guys used to paint with NO safety equipment and a cigarette as an air filter spraying real paint and we are way older than you . use a current chemical paint mask and you'll be fine . Whats next robotic paint spraying to avoid any over spray ?
08-13-2018, 03:14 PM | #11 |
laying low
A simple “ nothing to worry about “ would have sufficed. You get up on the wrong side of the bed again?
08-13-2018, 03:59 PM | #12 |
I've used it on my inner fenders and the cross sills on mine. Definitely be in a well ventilated area, but when dry its odorless...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-13-2018, 04:33 PM | #13 | ||
Everybody is afraid of toxins today and the State of California is out of control with label requirements on any products. Quote:
I say no worries but make sure it is fully cured before reassembly. Bill
08-13-2018, 06:32 PM | #14 | |
Read my recommendations on POR-15 in this thread... Post #4. http://67-72chevytrucks.com/vboard/s...d.php?t=684585 LockDoc
08-13-2018, 09:52 PM | #15 |
laying low
Yessir. Thank you.
