Old 08-12-2018, 06:47 PM   #1
CC's72
CC's72's Avatar
Heater Housing Metal back
Hello All,
Finally getting into getting my 72 C-10 updated. I have teamed up with a local shop for motor and transmission rebuild while I refurb all brackets and under hood items.
I am working on getting the heater core and condenser housing cleaned and replacing all switches, resistor and gaskets.
My problem comes in with the metal plate behind the housing that holds the blower motor. Is there any such luck of someone making replacements for these?
Otherwise does anyone have ideas to repair?[ATTACH]1810774[/ATTACH
Thanks, Charles
CC's72 is offline   Reply With Quote
Old 08-12-2018, 09:06 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Heater Housing Metal back
Just post a want to buy ad in the parts section , With everyone installing aftermarket A/C there are probably 100's of them under work benches all over the country .
Old 08-13-2018, 06:35 AM   #3
CC's72
CC's72's Avatar
Thanks Grumpy,
Took your advice and have it up now.
Thanks,
Charles
Old 08-13-2018, 07:28 AM   #4
I guess no one does make those heater housing parts, so as Grumpy Old Man says, used is your best bet. You shouldn't have a trouble finding one.
Old 08-13-2018, 08:08 AM   #5
bill3rail
bill3rail's Avatar
Originally Posted by CC's72 View Post
Hello All,
Thanks, Charles
Being in TN, you should have some junk yards to find old trucks. Here in NY nothing at all!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-13-2018, 08:42 AM   #6
Grumpy old man
Give this guy a call he's in your neighborhood .
https://knoxville.craigslist.org/pts...612201733.html
Old 08-13-2018, 11:46 AM   #7
Boog
laying low
Boog's Avatar
What’s the best way to save that metal part? I’ve got a rusty one. I was thinking about wire brushing it real good and maybe using por 15 on it. Possible toxic fumes from using it in that heated air flow a concern?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-13-2018, 01:04 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
You would have to drill the rivets out and blast it to get all of the rust.
POR-15 would seal it up OK but you still need to get the inside coated. As hard as the POR gets I don't think you would get any fumes from it when dry.
LockDoc
Leon
Old 08-13-2018, 02:13 PM   #9
Boog
laying low
Boog's Avatar
It is coming off to get to both sides. I’ve not used por 15 so im unaware of its cautions. Replacement brads can be picked up at parts stores. Or used to be.
Boog
primer is finer
Old 08-13-2018, 02:57 PM   #10
Grumpy old man
OK , Quit ! There are no toxic fumes you need to worry about. Give it a break your not gonna be exposed to any " adverse gasses " The air your breathing everyday has worse affects than a short exposure to paint fumes . You "kids " need to realize us old guys used to paint with NO safety equipment and a cigarette as an air filter spraying real paint and we are way older than you . use a current chemical paint mask and you'll be fine . Whats next robotic paint spraying to avoid any over spray ?
Old 08-13-2018, 03:14 PM   #11
Boog
laying low
Boog's Avatar
A simple “ nothing to worry about “ would have sufficed. You get up on the wrong side of the bed again?
Boog
primer is finer
Old 08-13-2018, 03:59 PM   #12
OregonNed
OregonNed's Avatar
I've used it on my inner fenders and the cross sills on mine. Definitely be in a well ventilated area, but when dry its odorless...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-13-2018, 04:33 PM   #13
bill3rail
bill3rail's Avatar
He was just pointing out the obvious from his experience. Walter is as Walter Does! He is Grumpy Old Man you know.
Everybody is afraid of toxins today and the State of California is out of control with label requirements on any products.
Anyhow, I read the question to be would the heater burn off the paint and concentrate it into his cab.
I say no worries but make sure it is fully cured before reassembly.
Old 08-13-2018, 06:32 PM   #14
LockDoc
LockDoc's Avatar
Read my recommendations on POR-15 in this thread... Post #4.
http://67-72chevytrucks.com/vboard/s...d.php?t=684585
LockDoc
Leon
Old 08-13-2018, 09:52 PM   #15
Boog
laying low
Boog's Avatar
Yessir. Thank you.
Boog
primer is finer
