Heater Housing Metal back
Hello All,
Finally getting into getting my 72 C-10 updated. I have teamed up with a local shop for motor and transmission rebuild while I refurb all brackets and under hood items. I am working on getting the heater core and condenser housing cleaned and replacing all switches, resistor and gaskets. My problem comes in with the metal plate behind the housing that holds the blower motor. Is there any such luck of someone making replacements for these? Otherwise does anyone have ideas to repair?[ATTACH]1810774[/ATTACH Thanks, Charles |
![]() Join Date: Dec 2013
Re: Heater Housing Metal back
Just post a want to buy ad in the parts section , With everyone installing aftermarket A/C there are probably 100's of them under work benches all over the country .
Thanks Grumpy,
Took your advice and have it up now. Thanks, Charles |
I guess no one does make those heater housing parts, so as Grumpy Old Man says, used is your best bet. You shouldn't have a trouble finding one.
#5 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Give this guy a call he's in your neighborhood .
![]() https://knoxville.craigslist.org/pts...612201733.html |
laying low
![]() Join Date: Mar 2001
What’s the best way to save that metal part? I’ve got a rusty one. I was thinking about wire brushing it real good and maybe using por 15 on it. Possible toxic fumes from using it in that heated air flow a concern?
#8 | |
The Older Generation
POR-15 would seal it up OK but you still need to get the inside coated. As hard as the POR gets I don't think you would get any fumes from it when dry. LockDoc
laying low
It is coming off to get to both sides. I’ve not used por 15 so im unaware of its cautions. Replacement brads can be picked up at parts stores. Or used to be.
#10 | |
laying low
A simple “ nothing to worry about “ would have sufficed. You get up on the wrong side of the bed again?
![]() Join Date: Dec 2012
I've used it on my inner fenders and the cross sills on mine. Definitely be in a well ventilated area, but when dry its odorless...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#13 | ||
Everybody is afraid of toxins today and the State of California is out of control with label requirements on any products. Quote:
I say no worries but make sure it is fully cured before reassembly. Bill
#14 | |
Read my recommendations on POR-15 in this thread... Post #4. http://67-72chevytrucks.com/vboard/s...d.php?t=684585 LockDoc
#15 |
laying low
Yessir. Thank you.
