09-01-2016, 01:45 AM | #276 |
Re: Post your 1960-66 STEPSIDES
Not mine, but it could be yours for a mere $30k:
http://www.gatewayclassiccars.com/sa...c20-S6750.html |
09-01-2016, 09:03 AM | #277 |
It's a bit of a bodge right now, but I kind of like it that way. A little cooler and a little drier and I'll get the driver's side exhaust back together and take it for its first drive in a while. |
12-23-2016, 10:17 PM | #278 |
^^^ wtf ^^^^^
12-23-2016, 11:15 PM | #279 |
1961 crewcab
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-29-2017, 12:34 AM | #280 |
But Found Her 25yrs Later!
Not mine,
Just a cool pic:
06-29-2017, 11:11 AM | #281 |
you have got to love that back tire
06-29-2017, 11:50 AM | #282 |
06-29-2017, 02:04 PM | #283 |
Perfect stance, Scoot! Do you mind sharing the specs on your drop?
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
06-29-2017, 02:21 PM | #284 |
5.5/7 drop. CPP 2.5" drop spindles and 3" springs up front and 5" springs and 2" blocks in the back rolling on 275/40r18 tires. Thinking I'll drop the front (cut 1/4-ish coil) another half inch to tuck the tire and match the back a bit more.
06-29-2017, 11:43 PM | #285 |
60-66 Nut
Did you happen to see a side view of this truck? I'd like to see the center caps.
06-30-2017, 12:27 AM | #286 | |
http://67-72chevytrucks.com/vboard/s...62#post4144562
07-02-2017, 11:59 PM | #287 |
Half of it
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) |
07-03-2017, 09:55 PM | #288 |
Here's mine I just recently traded for this stepside with the spare cutout...I still have to put my fake patina paint job on it..and mount the bumper that wraps around the fenders..
1964 BBC 402 4x4 |
07-05-2017, 11:49 AM | #289 |
Here's my 1962:
07-07-2017, 11:05 AM | #290 |
Hi,
Here are the pictures of my 1964 Chevrolet C10 Stepside from Istanbul, Turkey. Cheers |
07-07-2017, 04:24 PM | #291 |
Moderator
Wow, Looks great. Tell us more about how this corner trim was installed please.
07-08-2017, 12:31 PM | #292 |
Active Member
Mine in the ramp at work.
10-01-2017, 10:40 AM | #293 |
Let's see some more trucks! .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
10-01-2017, 08:31 PM | #294 |
Ok here's mine Dang photobucket.
1964 BBC 402 4x4 |
10-01-2017, 09:16 PM | #295 |
My 65 with her winter wheels.
10-01-2017, 09:55 PM | #296 |
There's a very rare original piece and sails that was on I think only a 60. But an old member Lakeroadster mimicked it using a side trim piece.
09-11-2018, 09:25 PM | #297 |
Not mine
09-12-2018, 08:55 AM | #298 |
Old member
Nice trucks!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-12-2018, 10:23 AM | #299 |
Mine has been revised.
'66 "Wrong bed" (Long stepper) 350, 4-speed '66 Shortbed Stepside, 350/TH350 www.instagram.com/d_ray_pinstriping |
09-12-2018, 05:47 PM | #300 |
64 C10 A bunch of Volvos Luthier Simpsons Nerd |
