Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-10-2018, 08:57 PM   #176
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
The panel is clamped into position but I'm feeling a bit of a bulge/bow along the top edge. Not sure if I should order another panel and try again or weld it up and break out the shrinking disk.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-13-2018, 09:23 PM   #177
LockDoc
The Older Generation
LockDoc's Avatar
Re: NJ Suburban
Paul
The disk would probably do it. I can see where you are talking about. I wonder what would happen if you would brace something against that area while you welded it. Dunno....
LockDoc
Leon
Old 09-17-2018, 07:35 PM   #178
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Ran into a problem with the pillar support. Couldn't find any pictures of how it is supposed to look so I welded it up how I thought it should be.
Paul
Old 09-17-2018, 08:27 PM   #179
Average Joe
Average Joe's Avatar
Re: NJ Suburban
Looks good to me! ^^^
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-17-2018, 08:33 PM   #180
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Joe check out the problem with the rocker and the quarter alignment posted in the regular forum. Not sure how to make things line up!
Paul
Old 09-20-2018, 08:50 PM   #181
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Ok I can live with this fit!
Paul
Old 09-20-2018, 09:53 PM   #182
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
That doesn't look too bad from here. I think it will blend in more when it is all one color too.
LockDoc
Leon
Old 09-20-2018, 09:58 PM   #183
dozerbill72
dozerbill72's Avatar
Re: NJ Suburban
That looks nice. Did you shim the rocker out full length?
dozerbill72 is offline   Reply With Quote
Old 09-21-2018, 07:52 AM   #184
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
It’s shimmed about 3/16 of an inch toward the back and tapering down to zero for about 3 inches. The inner rocker got bent outward to make it even.
Paul
Old 09-26-2018, 08:27 PM   #185
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Finally got it to lay down straight and flat!
Paul
Old 09-26-2018, 08:37 PM   #186
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: NJ Suburban
Looks good Paul, was it the bottom lip that was causing the issue?
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 09-26-2018, 10:22 PM   #187
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
It was the whole damn panel Richard. It wasn’t till I made a dozen cuts in the wheel arch and a relief cut above the wheel arch that it would lay flat.
Paul
Old 09-27-2018, 11:01 AM   #188
richard2717
Re: NJ Suburban
Glad you got it figured out without having to start over. Looking real good.
Members I have met.
Old 09-29-2018, 03:57 PM   #189
Average Joe
Re: NJ Suburban
Looking good! Thanks for posting the results and how you accomplished such a nice fit!!
Old 10-01-2018, 10:16 PM   #190
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Richard and Joe maybe I spoke too soon. After welding the panel doesn't lay as flat as I'd like. Can't figure out why it is so uneven! I tack welded in between the panel clamps and waited at least 15 minutes before putting down another tack. Nothing overheated and there is still warping. When I lay a flat edge down along the body it seems to start bowing inward two or three inches above the lower panel body line. Anyone out there willing to compare panel flatness in that area to compare?
At around the 60" mark on the ruler the panel starts bowing inward. At the 72" mark the ruler is about 1/8" away from the panel. Is that normal?
Paul
Old 10-02-2018, 06:51 AM   #191
richard2717
Re: NJ Suburban
Paul
Did you check it before you ground the welds? Just wondering if it heated up enough while grinding to bow it some?
Richard
Members I have met.
Old 10-02-2018, 09:00 AM   #192
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
I was really careful with the grinding too. It never got hot. I think the warping came from stress on making the panel fit. Looks like I’m grinding this one off and ordering another panel.
Paul
Old 10-04-2018, 07:56 PM   #193
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Well I salvaged 2 weeks worth of work! Figured that it would have to be cut off and a new panel purchased. Also figured I couldn't screw it up worse with that in mind so I got out the shrinking disc on my 4" grinder. I used it to do areas about 4" in diameter and didn't let it get hot enough to discolor the metal. Have to say it did a pretty decent job. At this point the lowest area now is about 1/16" but I'll still work it with a hammer and dolly beror the filler goes on. The straight edge lays pretty flat along the panel and the 3/16" gap I had in my last picture is gone!
Paul
Old 10-04-2018, 11:46 PM   #194
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
I'll bet you are relieved about that! I figured you would try to come up with something to save it.... Glad it worked out for you.
LockDoc
Leon
Old 10-05-2018, 05:31 PM   #195
richard2717
Re: NJ Suburban
Glad you got it worked out without having to start over with it.
Members I have met.
Old 10-05-2018, 09:31 PM   #196
Average Joe
Re: NJ Suburban
Good job! Glad you were able to fix it!!
Old 12-03-2018, 11:09 PM   #197
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Truck and garage all prepped for epoxy primer tomorrow!
Paul
Old 12-04-2018, 10:29 PM   #198
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Epoxy done
Paul
Old 12-05-2018, 12:20 AM   #199
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Epoxy done
Paul
Looks great! It's always nice to see them all one color. Keep up the good work...
LockDoc
Leon
Old 12-05-2018, 08:18 AM   #200
richard2717
Re: NJ Suburban
Looking good Paul
Members I have met.
