Old 11-06-2018, 11:27 PM   #51
3757chevy
3757chevy's Avatar
Re: What did you do to your truck today.The 3rd chapter
It was yesterday , but I drove to Rocky Mountain Forest Products and picked up my special ordered 1"x8"x8' beetle kill pine. It came in to the yard in 5 16' boards and so they cut them down to 10 8'ers so I could haul'em home.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-06-2018, 11:37 PM   #52
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by 3757chevy View Post
It was yesterday , but I drove to Rocky Mountain Forest Products an picked up my special ordered 1"x8"x8' beetle kill pine. It came in to the yard in 5 16' boards and so they cut them down to 10 8'ers so I could haul'em home.
The beetle kill pine has some interesting colors and holes from the bugs, but for my money the beetles oughta be killed outright.
~Steven
Simi Valley, CA
Old 11-07-2018, 12:32 AM   #53
samkost
samkost's Avatar
I copied member OregonNed and replaced the battery terminals that the resto shop from Hell had ruined when I got my truck out of jail
Their shoddy work has me checking off a long list of items to correct, repair, and replace.
All is good now...moving on and feeling better that I am fixing things myself.
samkost is offline   Reply With Quote
Old 11-07-2018, 06:26 AM   #54
kcmarkd
kcmarkd's Avatar
Took apart the Rochester 2 barrel so it can take a bubble bath then get rebuilt.
1970 C10 CST, PS, PB, AC, patina, original, work in progress
kcmarkd is offline   Reply With Quote
Old 11-07-2018, 08:44 AM   #55
OregonNed
OregonNed's Avatar
looks good brother!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 11-07-2018, 04:26 PM   #56
tino0217
i realigned my driver side door on my 71 C-10. results are pleasing and the door closes 80% better but i'm still getting a draft in the upper portion so i think it's time to replace the weather strip
tino0217 is offline   Reply With Quote
Old 11-07-2018, 04:48 PM   #57
tommy3horse
tommy3horse's Avatar
Hi, i replaced the original Delco starter with a GM mini starter from DB Electrical a week or so ago. It crapped out after 5 days. I contacted DB and they replaced it right away. Sounds great now, hope I get more than 5 starts. DB’s service is first class, no tech assistance tho.
Tom
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline   Reply With Quote
Old 11-07-2018, 05:01 PM   #58
72c20customcamper
72c20customcamper's Avatar
New antenna installed.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-07-2018, 05:10 PM   #59
Colt_1911
Colt_1911's Avatar
New rotors, 2.5" drop spindles, lowering shocks, lowering springs, brake pads and new ball joints.
Colt_1911 is offline   Reply With Quote
Old 11-08-2018, 01:41 PM   #60
Mts67C10K20
Mts67C10K20's Avatar
Finaly freed up some time to work on the new motor for the 67
Crank and pistons installed now back in the bag till next time
Mts67C10K20 is offline   Reply With Quote
Old 11-08-2018, 02:50 PM   #61
72c20customcamper
Played with a cnc plasma cutter today that a friend just bought. Made a plate to install a stock radio in my truck. Used a piece of scrap stainless
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-08-2018, 11:53 PM   #62
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Some progress and learning a lot. I'm slow on things first time out, but I did manage to get this done over the last few days. Nice when you have the parts. 4" drop.
Ask me about torque on leaf spring suspension.......I can give you a lengthy unspecific answer, but close Go figure, you can buy replacement saddles and plates after all. Can't speak for their quality, mine were still good.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-09-2018, 12:38 AM   #63
samkost
samkost's Avatar
Excellent work on that radio face plate
How do you plan to attach it to your cut radio opening?
My dash was also unfortunately cut for a newer stereo by the previous owner.
That plate, color matched hugger orange and I would be good to go!
I think there would be a lot of interest from people with cut original dashes....just saying
Good job.
Sam
Old 11-09-2018, 07:42 AM   #64
Grumpy old man
Grumpy old man's Avatar
It must be frame / suspension assembly week ?
4" drop springs
all new brakes ,lines ,cables
cross member cut/tubed for tucked exhaust with new trailing arm bushings
Complete new front suspension cross member /all new Moog parts with drop spindles and springs , disc / power steering conversion ,factory front sway bar 9/16 U bolt upgrade ,all new grade 8 hardware . My 350 is ready to drop back in again . I'll be building a set of these rear shock re locators today to see how they work out .
http://67-72chevytrucks.com/vboard/s...d.php?t=763851
Old 11-09-2018, 09:08 AM   #65
70STOVEBOLT
70STOVEBOLT's Avatar
It's actually suspension disassembly week for me. Removed both front spindles for disc conversion and tore both ball joint boots on the right side, then discovered that the upper cross shaft bushings were worn, so next up is removing the upper control arms and replacing the bushings. Yay!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
2015 Silverado 1500 LS 4.3/6L80/3.23
70STOVEBOLT is offline   Reply With Quote
Old 11-09-2018, 09:24 AM   #66
72c20customcamper
Good job.
Sam
Plan to use 4 small ss screws Chamfering the holes and using flathead Philips . Maybe a dab or two of epoxy for insurance.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-09-2018, 09:34 AM   #67
Grumpy old man
While your there replace it all .
Old 11-09-2018, 11:43 AM   #68
74baggedbug
Getting it ready for autorama in a couple of weeks
74baggedbug is offline   Reply With Quote
Old 11-09-2018, 04:19 PM   #69
OregonNed
OregonNed's Avatar
Good job.
Sam
For sure..
Old 11-09-2018, 04:44 PM   #70
kcmarkd
kcmarkd's Avatar
For me it was carb-disassembly-week. Blew it apart and started the cleaning, rebuild process. Replacement parts arrived today, so tomorrow will be to reassemble carb, attach new choke components, install and test.
Old 11-09-2018, 04:55 PM   #71
C4UC101969
C4UC101969's Avatar
I stained my truck bed few days ago, its wood that came off a tear down barn so it was a real dull grey weathered color, so I thought i would make it a bit less dull and protect it as well as I really like the real old barn wood.
1969 'Matte Blackie' Oshawa Built Chevy C10 Stepside 307 three-on-the-tree
C4UC101969 is offline   Reply With Quote
Old 11-09-2018, 06:58 PM   #72
71CHEVYSHORTBED402
4" drop springs
I just ordered a bunch of parts so I can "catch-up". Nice work Grumps. You didn't replace your control arms did you? And if I can ask, where do your buy your rubbers to slip over shafts and that, on original hardware linkage, arms too?
Tony
Old 11-09-2018, 08:33 PM   #73
Grumpy old man
The original front cross member had some pitting on the upper control arm plate and I have a long bed parts truck that was much cleaner ,So I pulled the front member complete off the parts truck and stripped it down and bought all new parts to rebuild it . Upper and lower Moog control arm shaft kits , upper and lower Moog ball joints , inner and outer Moog tie rod ends / connectors, Moog pitman arm for power steering and Moog idler arm . Rock auto had the best price on all of it at one time and done . I thought about just replacing the shaft boots but it's apart and it was only a few hundred more to replace it all .
Old 11-09-2018, 09:54 PM   #74
71CHEVYSHORTBED402
Thanks Grumpy. I ordered Moog parts as well, through Summit.
Tony
Old 11-10-2018, 12:25 AM   #75
rjs53
Got the bed back together, had the bed on kinda lose when I realized there is no way to get to the back bolt unless I drop the fuel tank. With the bed on theres no way to get to the nuts when placing the fuel tank. Welded the nuts in place, then got the bed where I want it and tightened down, then was able to put the tank back on. Always a learning experience.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
