11-15-2016, 01:56 PM | #576 |
Re: 49 ls1
Glad to see you back Chris. I've got a lot of help and ideas from your posts with my '51 S10 swap project.
11-15-2016, 08:08 PM | #577 |
Re: 49 ls1
Welcome back! Hope all is well as can be!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
11-15-2016, 08:22 PM | #578 |
Re: 49 ls1
Chris, good to see you back and posting!
11-15-2016, 09:35 PM | #579 |
Chris it was so good to hear your voice today. You truly made my day! Cecil is great and I promise someday I will bring him back to you and we will go drive him! God Bless you and thank you again for your service to our country!
Posted via Mobile Device |
11-17-2016, 12:19 PM | #580 |
Re: 49 ls1
And a big thank you to Sean sparks for starting that gofundme page.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
11-17-2016, 03:48 PM | #581 |
Re: 49 ls1
Welcome back!
No bolt or nut in the world will remain tight if you turn it to liquid!!! |
11-17-2016, 07:18 PM | #582 |
Re: 49 ls1
Glad to see you getting back. Glad your doing better.
1950 3100 5 window |
11-18-2016, 02:58 PM | #583 |
Formerly- 1972SuperCheyenne
Re: 49 ls1
MAN! Glad to se youre doing better. Sorry to hear about the mishap. Hope all is good with you.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-18-2016, 09:47 PM | #584 |
Re: 49 ls1
Chris! Glad you're posting again. I saw you in Ottawa, glad you made it out. You haven't left our thoughts. Leevon
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-19-2016, 01:48 AM | #585 |
Re: 49 ls1
Just been reading your thread and did not expect to see what happened as I came up on your last 2 pages. God bless you and your family Bro and wish you complete recovery.
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
11-24-2016, 01:50 AM | #586 | |
Re: 49 ls1
It appears that you have welded the wrap around ends to the door panel, which then makes the window surround trim impossible to remove. How did you engineer that so the window surround can be removed? Are you eliminating the rubber weather stripping that seals the inside of the door to the door jamb? Thanks, |
08-01-2017, 12:11 AM | #587 |
Re: 49 ls1
Hey Skymangs,
I wanted to check with you to see what the track width is on the front end of your frame. I have read that a camaro sub is about 2.5 inches wider than the stock track width and I wanted to see if you had to do anything different to get those wheels to fit. Thanks again for your help! You have always been amazing and willing to help everyone! |
08-01-2017, 08:10 AM | #588 | |
Re: 49 ls1
08-01-2017, 08:27 AM | #589 | |
Re: 49 ls1
08-01-2017, 10:45 AM | #590 |
Re: 49 ls1
Thanks!!!
11-10-2018, 05:27 PM | #591 | |
Re: 49 ls1
11-10-2018, 06:55 PM | #592 |
Re: 49 ls1
I used speedway’s 19x22 universal rad w/ pass inlet/outlet. For the fan I used a single hayden 16", that’s one thing I’ve learned, not to skimp on fans. I only use hayden 16" now.
11-14-2018, 05:46 PM | #593 |
Re: 49 ls1
That dash is very cool! You said you useded a speedway universal 19 x 22 radiator? Those are 22 wide it looks like, I did not think that would fit. Did you remove the flange of the support on the inside to fit it?
11-14-2018, 06:07 PM | #594 |
Re: 49 ls1
It is 19" wide, you’ll have to trim the backside of the core support.
11-15-2018, 07:01 PM | #595 |
Re: 49 ls1
not to disagree, but the speedway rad is 22" wide and just barely fits in the (trimmed) core support. its listed at that width on speedways site.
one thing I dont like about the speedway rads is that they use the same end tanks as wider (32-40") rads, which on a wider rad needs the lower hose pointed at the water pump. but using it on a 22" rad, that angled hose fitting points at the harmonic balancer. I used an aluminum rad on the last 41 I did and the 19x22 was just barely too wide for the 41 core support, searching on ebay I found a 19x21 rad, and another benefit was that the lower hose outlet was straight and not pointed at the lower pulley. if you think you will run a stock mechanical fan, it will be very tough to get the rad in a good spot to do that, the way it mounted in mine the fan would have cut the lower hose in half. I used a 16" electric puller on that truck.
04-02-2019, 10:41 AM | #596 | |
Re: 49 ls1
10-20-2019, 11:46 AM | #597 | |
Re: 49 ls1
Great job by the way.. Love all that you have done...
Semper Fi Check out my project: http://67-72chevytrucks.com/vboard/s...d.php?t=559086 |
10-21-2019, 11:18 AM | #598 |
Re: 49 ls1
It’s a 30" Gearhead motors from eBay
10-21-2019, 11:37 AM | #599 |
Re: 49 ls1
Soooo happy you're back bro.
10-21-2019, 02:22 PM | #600 |
Re: 49 ls1
Thank you, I’m so happy to be back! The alternative is unthinkable! Almost got me, but I managed to squeak by!
