Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-12-2018, 08:51 PM   #26
Advanced Design
Advanced Design's Avatar
Re: Bought a new high quality locally built car trailer
Originally Posted by mongocanfly View Post
dang....sounds like you put the trailer through the ringer...sounds like your trip was like mine to Oklahoma when I went to get the IH.....I just thought our rds around here where bad....in Arkansas every bridge I came to felt like hitting a 6in curb going on the bridge ...and dropping off a curb going off the bridge....I mean every bridge..and they got a bunch of em....I couldn't believe I made it through with the truck still on the trailer....
duct tape'll fix everthang...haha
Yeah, you really notice how rough roads are when towing a trailer. Makes you grit your teeth. Gotta say other than the issues mentioned, this trailer floated along well when loaded.
A friend has it this week end to haul a small tractor so it is getting good use.
Advanced Design is offline   Reply With Quote
Old 05-18-2018, 08:47 PM   #27
Advanced Design
I called Imperial trailer about the ramp falling out and the retention pin bent upwards. They said sorry that happened, bring it down and we will take care of it for you. While I haven’t had time to take it there, I am really pleased with their response. Awesome customer service.
Now, the jack foot retention pin disengaging was my fault. I screwed the jack up too high, causing the retention pin handle to contact the frame. This caused the pin to back out allowing the jack foot to drop. Hmm...I need to post this one over in the stupid mistakes I have made discussion thread.
Old 05-22-2018, 06:06 PM   #28
lower50's
lower50's's Avatar
At least they are going to take care of you and you didn't bend the jack.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-22-2018, 09:57 PM   #29
Advanced Design
For sure! It could have been a lot worse.
A friend borrowed it to haul a small tractor and it was pretty dirty after. I couldn’t stand that....
Old 11-25-2018, 09:12 PM   #30
Advanced Design
Imperial trailer manufacturing fixed the bent retention pin issue right away. Bring it down ASAP they said and apologized for the problem. They did fix it right away and I just had opportunity today to slide under to take a look.
They cut out the old pin and retention ring then welded in a new one. I probably need to hit that with a little paint.
Old 11-25-2018, 09:15 PM   #31
Advanced Design
The wireless remote control for the winch is a handy upgrade, especially when you are loading one by yourself.
Old 11-25-2018, 10:37 PM   #32
Advanced Design
Trailer makes the Burb look short.
Old 11-26-2018, 12:07 AM   #33
truckster
truckster's Avatar
Hmm. If I had borrowed it I would have returned it cleaner than when I picked it up. That's just how I believe you should treat other people's stuff if they're nice enough to let you use it.
I'm glad to hear the manufacturer was quick to stand behind it. But I have to think that if you can wind the jack up far enough that it unlocks that's a design flaw.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-26-2018, 12:53 AM   #34
mongocanfly
mongocanfly's Avatar
Now your just showing off Doug...haha...very nice trailer...and the load!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-26-2018, 05:52 PM   #35
Advanced Design
Me too on borrowing stuff. I clean it, fill with fuel if applicable or fix it if it broke when I was using it. Another friend borrowed it to haul his Buick, accidentally scratched the fender and took it to a painter friends shop to have it fixed. I can’t tell which fender was scratched.
Friends Buick.
Old 11-26-2018, 06:00 PM   #36
Advanced Design
Lol...I don’t know. Get to showing off or feeling too high and mighty something will set us straight pretty quick.
Like loading the Burb with the remote operated winch, feeling kinda smug, then scrape grind. Oops, running board bracket dragging on the floor and scraping the paint off. Bring out the load height enhancement devices.
