guide plates
Are they required on vortec heads, bought them from GMPP but did not include guide plates
Moderator
![]() ![]() Join Date: Aug 2011
Re: guide plates
Looking at an earlier post it doesn't seem so: http://67-72chevytrucks.com/vboard/s...d.php?t=477168
60-66 Nut
Re: guide plates
If you are running the self-aligning rockers, then no you do not need or want guide plates. If you are running the standard early rockers, you might want to consider guide plates.
Re: guide plates
Is there a way to identify the self alligning rockers
Re: guide plates
Here you go, multiple pics of OE and aftermarket rockers:
http://garage.grumpysperformance.com...er-studs.2746/ |
![]() Join Date: Jan 2011
Re: guide plates
It looks like the locks are upside down. The hex goes up so you can hold it with a wrench and tighten the set screw.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: guide plates
Re: guide plates
Thats why I hang out with you guys, you've got all the right answers... will I loose my adjustment when I rotate the nut, seems so EOIC?
Re: guide plates
Yep, you got it - EOIC
Re: guide plates
Thanks all for the help
Lots of reading to do....
