Old 01-31-2019, 12:31 AM   #351
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: "Crewcab Jake" the 84 to 74 conversion
Once I reached the crossmember, I cleaned around the mounting bracket. The factory bracket will be replaced with a Ridetech piece.
The stock bracket is riveted to the crossmember so the air chisel got to earn its keep again
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-31-2019, 12:49 AM   #352
N2TRUX
Happy to be here
N2TRUX's Avatar
With the rivets removed the four bolts through the frame are next. This is can be a task since one bolt is buried under the fuel lines inside the frame.
Once all the bolts are out the brackets were free. They were set aside and the wire cup was used on the crossmember and frame
Articles-
"Refining Sierra"
Old 01-31-2019, 01:51 PM   #353
Dads79GMC
Dads79GMC's Avatar
Looking good!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 01-31-2019, 04:50 PM   #354
aggie91
I'm just glad to be here!
aggie91's Avatar
I think you missed a spot...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-31-2019, 07:06 PM   #355
trixter99
I have no time for this
trixter99's Avatar
Are you going to leave the big block in it?
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 01-31-2019, 11:34 PM   #356
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Dads79GMC View Post
Looking good!!
Thank you sir
I missed a couple of spots. Krylon cant decide what formula they want to use. This weeks version is super thin. It requires lots of really light coats with plenty of flash time in between.
Articles-
"Refining Sierra"
Old 01-31-2019, 11:37 PM   #357
N2TRUX
Happy to be here
N2TRUX's Avatar
For now, yes it stays. I haven't had time to do a leak down test, but the bottom end seems to be solid. If it tests good I'll do a a top end swap with EFI.
Articles-
"Refining Sierra"
Old 01-31-2019, 11:44 PM   #358
N2TRUX
Happy to be here
N2TRUX's Avatar
It rained and traffic was horrible coming home tonight. I got a late start in the shop so I was limited on what I had time to do. I decided to work on the bottom side of the crossmember.
After degreasing, I wire wheeled what I could. The rest was cleaned by hand with course sand paper.
Articles-
"Refining Sierra"
Old 01-31-2019, 11:50 PM   #359
N2TRUX
Happy to be here
N2TRUX's Avatar
After a wipe down with Scotch Brite and brake cleaner it was ready for paint. I cleaned inside the saddle as best as possible. I'll use undercoating to protect the inner surfaces once the paint dries.
Articles-
"Refining Sierra"
Old 01-31-2019, 11:53 PM   #360
N2TRUX
Happy to be here
N2TRUX's Avatar
One last coat or six on the rest of the frame and It was time to shut shop for the night.
Articles-
"Refining Sierra"
Old 02-01-2019, 01:13 AM   #361
rustytruck50
rustytruck50's Avatar
Ken...the makers of Krylon owe alot to you for making the product look so dang good! I have a question....in the last picture, for example, where you stopped painting at the pitman arm...how do you get such a seamless, consistent finish when you stop & resume painting? Do you scuff the painted area leading up to the unfinished area or does it blend well enough that it's just a continuation from where you left off? Its impressive and I've seen it time & again through your other builds. Its definitely something I can use on both of my trucks, especially the '72.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 02-01-2019, 11:14 AM   #362
N2TRUX
Happy to be here
N2TRUX's Avatar
It has been a lesson in frustration dealing with the changes in Krylon formulas. I can imagine they aren't happy either.
I have found that Krylon does a good job of adhering to itself. Consequently a lite scuff with Scotch Brite is all that's required when overlapping. It helps that the painted surfaces are under the truck so you cant see the overlap , but it truly blends well.
Articles-
"Refining Sierra"
Old 02-01-2019, 11:18 AM   #363
N2TRUX
Happy to be here
N2TRUX's Avatar
@n2trux shop hack. When painting or undercoat requires a light, here what I do to keep the lenses clean. Slip a baggie over the head of the light. It's cheap, quick, and easy to replace
Articles-
"Refining Sierra"
Old 02-01-2019, 08:21 PM   #364
nlped
nlped's Avatar
^^^ I do they too. I keep 1 quart baggies in a drawer just for that.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-02-2019, 12:53 AM   #365
N2TRUX
Happy to be here
N2TRUX's Avatar
I bag and tag all my bolts as I take things apart. I keep a couple of sizes handy.
Articles-
"Refining Sierra"
Old 02-02-2019, 01:07 AM   #366
N2TRUX
Happy to be here
N2TRUX's Avatar
This morning I got a quick shop session in. I knew I wouldn't be able to throughly sand inside the crossmember. I decided to protect it with undercoating as we as possible.
I prepped the surface as much as possible and masked the surrounding area. A few coats of undercoating and I felt better.
Articles-
"Refining Sierra"
Old 02-02-2019, 01:28 AM   #367
N2TRUX
Happy to be here
N2TRUX's Avatar
I needed the inside to cure today since Chris and I had plans to start the installation tonight. We got off to a good start by unpacking boxes. If you ever order anything from Ridetech plan on spending some time to unpack it. They ensure thier products arrive safely with very secure packages.
Articles-
"Refining Sierra"
Old 02-02-2019, 01:43 AM   #368
N2TRUX
Happy to be here
N2TRUX's Avatar
We started the install by bolting the upper coil over mount in place. Ridetech provides a template for cutting a hole in the crossmember. I prefer to bolt the the bracket in place and scribe the cut line instead. It takes a bit longer but it I feel it's worth it.
Articles-
"Refining Sierra"
Old 02-02-2019, 01:57 AM   #369
N2TRUX
Happy to be here
N2TRUX's Avatar
The easiest way to cut the hole is with a plasma cutter. Unfortunately I don't own one so I used a cut off wheel instead. It's a slower process but it is effective.
I painted the raw edges of the cut, then bolted the bracket in place for the final time. Chris assembly the upper tubular arm by installing the caster spacers and we hung it in place.
Articles-
"Refining Sierra"
Old 02-02-2019, 02:13 AM   #370
N2TRUX
Happy to be here
N2TRUX's Avatar
This is where the install paused for the evening. I realized I still had not cleaned and painted far enough away from the install area. I decided to stop and finish cleaning the frame and crossmember before proceeding.
Articles-
"Refining Sierra"
Old 02-02-2019, 03:13 AM   #371
orngsikL
orngsikL's Avatar
LST crunch?
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 02-02-2019, 04:11 AM   #372
LT7A
Great tip. ..for LEDs. I tried it with a halogen. That's what happened to my "first" garage ;)
Old 02-02-2019, 10:47 AM   #373
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by orngsikL View Post
LST crunch?
Yes sir. Its obviously not going to be "finished " but it will be there
Articles-
"Refining Sierra"
Old 02-02-2019, 10:48 AM   #374
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by LT7A View Post
Great tip. ..for LEDs. I tried it with a halogen. That's what happened to my "first"garage
Should I add a disclaimer?
Articles-
"Refining Sierra"
Old 02-02-2019, 10:52 AM   #375
N2TRUX
Happy to be here
N2TRUX's Avatar
After my frustrated melt down Chris quietly slipped out and headed home. I continued on with my detail work and got half of the crossmember and frame painted.
Articles-
"Refining Sierra"
