#551 |
Re: 1964-1966 center a/c vent
Thank you so much Jim!!!! This product is worth every penny. The vent kit helped me transform this....
Into This.......... |
#552 |
I'm just glad to be here!
That looks good Jeff. Would you be willing to part with that small heater only control panel and knob?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#553 |
Looks good Jeff...how was the install?
#554 |
![]() Join Date: Jun 2011
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#555 |
![]() Join Date: Jan 2002
im sure in the hot season they really help with cooling ????anybody tested any yet ??
#556 |
i started making the center a/c vent for the 1965 Chevelle if you know somebody that needs one.
#557 |
Sorry Been away for a while
Aggie91. I happened to give the panel, switch and cable away to another member of the board. Sorry, would have been happy to part with it. roll_the_dice. The install was a breeze. Jim provides a template to cut out the dash around the ashtray. The only issue I had was that the side vents are for the larger hoses (defroster size) while my aftermarket AC (OldAir Products) had the small hoses. I just made a little adapter from a pvc fitting, epoxied it to the side vents and connected the smaller hoses to that. All in all it was a breeze. The hardest part was painting.....and that was due to my lack of skills |
#558 |
I live in Myrtle Beach and it gets pretty hot in the summer. I have an aftermarket AC and I also put sound deadener and jute under the new carpet, installed a new firewall pad and sealed every hole in the firewall (including the side vents. It gets super cold in there in short order.
#559 | |
#560 |
![]() Join Date: Feb 2016
i lost my contact info for the plastic AC vents to be chromed.
it was in Jims kit now i can find it. can someone shoot over the info? thanks! |
#561 |
![]() Join Date: Aug 2004
That person retired, I do know there is a place in NY state that can do it. I’ll post it if I find it...
Found it!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 03-13-2019 at 02:30 PM. |
#562 |
quick question all.
the plating shop is asking what the material is and whether it was 3d printed?? over my head. |
#563 |
Jim will have to answer, I believe it is epoxy resin but not for sure.
The guy Jim recommended did mine and just asked if it was new material or not.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#564 |
got it. i was able to text him.
he suggested to use Coat of Chrome in PA. moving forward ![]() |
#565 |
My 1964 through 1966 AC vent kit comes with a template to cut the dashboard correctly like the factory. Also some recommendations on what color to use if you want it to look Factory stock. And it comes with a company that I highly recommend to get your vent balls chromed. The whole kit is $355.61 priority mail shipped to your door. That price include shipping if you're in the USA.
#566 |
Just So I get this right, the nozzles aren't chromed when the assembly is ordered? So, I have to disassemble them and have it done myself?
#567 |
Jim gives you a couple of companies that will do the chroming, there are a few different ways to accomplish the factory look.
Jim used to chrome them, however costs and delays on the chrome companies was putting him in a huge bind. Chroming anything isn’t cheap, especially for a quality job.
#568 |
Any pix of how the center vent clip goes together
#569 |
It would be easiest if you shoot me a text message then I can take detailed pictures for you it's too hard to load pictures here. Very time-consuming.
602-361-6421
#570 |
1964 1965 1966 center A/C vent assembly
$355.61 shipped free in the US Outside US I'll get a shipping quote.
#571 |
PM/e-mail your pics to me. I'll post them up for others that will likely have similar questions.
#572 |
Has anyone tried chrome spray paint on the balls? Here is a test of manufacturers.
https://www.youtube.com/watch?v=mL4IYoxJqu4 Last edited by vet57air; 08-10-2019 at 06:39 PM. |
#573 |
Same guy did this video on the application of chrome paint. Vents would have challenges but I might try.
https://www.youtube.com/watch?v=XkG5kW3u6kQ |
#574 |
so I guess my Photobucket images don't work for this site anymore do you have any recommendations so that I can show you pictures since this website does not have a cell phone user-friendly application
#575 |
Jim, I upload pictures from my phone all the time! What brand do you have? Android or IOS?
