Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-11-2019, 09:16 PM   #1
lownslw64
lownslw64's Avatar
WTB...suburban clamshell parts
I wanted to see if anyone has a lower seal plate that goes from side to side for a clamshell gate to bolt onto available in decent condition. Preferably local but would entertain shipping items also. I am switching my suburban over to clamshell from Barn doors and these are the last items needed. I've attached pics of were the parts would be. Thanks
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
Old 01-15-2019, 01:15 PM   #2
lownslw64
lownslw64's Avatar
Re: WTB...suburban clamshell parts
ttt
Old 01-16-2019, 03:23 PM   #3
GMCNUT
GMCNUT's Avatar
I should have a spare set of the Chrome tailgate supports but they are not cheap if you haven't found that out yet - 200 a set.
Also, do you already have the clamshell upper liftgate supports? they are even higher but I think I have one
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-16-2019, 04:20 PM   #4
lownslw64
lownslw64's Avatar
let me clarify a little bit for the hardware that is needed for the lower gate. I don't need the tailgate supports I just need the part that goes above it that the lower gate will latch to. here is a pic from another burb I found. I have both the lower gate and upper gate supports.
Old 01-16-2019, 10:28 PM   #5
1960chevypanel
I probably have those catches. With the storm tomorrow I can't check until Friday, but I'll let you know.
1960chevypanel is offline   Reply With Quote
Old 01-17-2019, 10:25 AM   #6
lownslw64
lownslw64's Avatar
ok, thanks for looking everybody!
Old 01-17-2019, 11:06 AM   #7
GMCNUT
GMCNUT's Avatar
Gotcha - yeah, I had a bunch of those at one time but systematically sold them all over time dont think I have any now
Old 01-18-2019, 03:43 PM   #8
1960chevypanel
Just checked a couple of my trucks, your top and bottom center barn door catches are the same as left and right clamshell, so you can just relocate them. I have extras if you need them.
Old 01-18-2019, 04:20 PM   #9
lownslw64
lownslw64's Avatar
awesom! thanks for looking and noticing that. i can use mine then.
Old 01-21-2019, 11:00 PM   #10
lownslw64
lownslw64's Avatar
ttt
Old 01-27-2019, 11:35 AM   #11
lownslw64
lownslw64's Avatar
ttt
Old 02-16-2019, 10:32 AM   #12
lownslw64
lownslw64's Avatar
ttt
Old 03-02-2019, 10:51 AM   #13
lownslw64
lownslw64's Avatar
ttt
Old 03-02-2019, 11:05 PM   #14
tjmb1086
tjmb1086's Avatar
I believe i have those parts will know forsure Monday
tjmb1086 is offline   Reply With Quote
Old 03-03-2019, 09:24 PM   #15
Grandpa54
Grandpa54's Avatar
Are they the same as the top and bottom of the doors?
Grandpa54 is offline   Reply With Quote
Old 03-03-2019, 09:51 PM   #16
lownslw64
lownslw64's Avatar
Are you asking about the latches? If so yes......another board member let me know that so I am able to use mine from my barn doors.
Old 03-04-2019, 01:54 AM   #17
1960chevypanel
It's actually the catches that are the same, not the latches. None of the latches interchange.
Old 03-04-2019, 03:11 PM   #18
Grandpa54
Grandpa54's Avatar
Originally Posted by 1960chevypanel View Post
it's actually the catches that are the same, not the latches. None of the latches interchange.
correct
Old 02-10-2020, 12:27 PM   #19
My65's
I know im resurecting an old post but has anyone found these catches repopped? I need a new set for my 65 clamshell.
My65's is offline   Reply With Quote
