63 GMC throttle pedal conversion
Hey what's up guys , I'm in need of some help. Has anyone done a gas pedal conversion. If you have please get back with me. Please. I need direction.
Moderator
![]() ![]() Join Date: Aug 2011
Re: 63 GMC throttle pedal conversion
Conversion to what?
![]() ![]() ![]() Join Date: Jan 2018
Are you wanting a cable style gas pedal?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Are you talking about something like this?
Yes, I'm looking to go cable.
After talking to the tech department at cpp ( classic performance products ), I found out that there wasn't no information on a 63 GMC throttle pedal conversion, so I had to figure out something, so I removed the original throttle assembly that was bolted to the side of the transmission tunnel. I found a flat spot next to that area and mocked up my lokar pedal and marked a line around the base of the mounting surface, then I put the plate that mounts to the firewall over the line that I marked around the base of the pedal to marke the 2 holes that needed to be drilled for the installation. Worked out perfectly. Thanks for all y'alls responses. |
