Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-20-2019, 08:53 PM   #1
Clatterville trolley
Clatterville trolley's Avatar
Radiator support repair
I'm sure that I am the only one with a 67-72 C10 that has had to repair the area under the battery box. But, just in case someone else has run up against this problem I wanted to post how I am going about the repair.
Last edited by Clatterville trolley; 05-20-2019 at 08:54 PM. Reason: change photo order
Clatterville trolley is offline   Reply With Quote
Old 05-20-2019, 08:59 PM   #2
Re: Radiator support repair
1st photo is where I have cut away the rotten metal a little bit already.
2nd photo is lay out on 16 gauge sheet steel
3rd photo is hammer form I made out of MDF (medium density fiberboard)
4th photo is different view of hammer form
5th photo is with metal formed on hammer form
I set the holes where they should be on the finish piece and used them as the alignment holes where the bolts hold the two pieces together.
Old 05-20-2019, 09:04 PM   #3
This is to show how it will be when it is welded on. Have to cut some off yet but don't want to do that until I determine exactly how much I will replace.
Last process is to make the depressed area on the outer corner. I am building another form that I think will do the job. More photos as I progress.
Thanks for looking.
Jay
Old 05-20-2019, 09:29 PM   #4
mongocanfly
mongocanfly's Avatar
Looks good Jay!...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-20-2019, 10:09 PM   #5
Originally Posted by mongocanfly View Post
Looks good Jay!...
Thanks for the encouragement! Jay
Old 05-21-2019, 09:16 AM   #6
KMC3420
KMC3420's Avatar
Awesome ingenuity! I love it, and it’s “Made in USA”.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 05-21-2019, 10:55 AM   #7
And, "Hand made at that!" Jay
Old 05-21-2019, 12:08 PM   #8
tinydb84
tinydb84's Avatar
Awesome work right there.
David
Instagram: myfabguy
Old 05-21-2019, 07:39 PM   #9
franken
Thanks for the pics to show how a hammer form can be used.
That patch is available but it's way thicker than the original part...
Old 05-21-2019, 08:55 PM   #10
I didn't think it was reproduced at all. I worked on mine some more today with the piece I built to make the depressed area in the upper corner to fit the contour of the rest of the support. It didn't work as well as I thought it might, but I was able to still get it formed - just not as easy as I had hoped.
I'll post some more photos as soon as I take them. Now to get the rest of the old piece off of the support. There are several spot welds to drill out yet before I can do final fitting. Also have to weld in threaded inserts for the inner fenders to attach to. A lot of work for such a little part!
Old 06-22-2019, 10:21 PM   #11
I have been working on the support in between some other jobs - but I have been taking pictures along as I complete more.
Have the pieces fitted and ready to weld in as soon as I get the area sandblasted to clean it all up to prepare for welding and primer. So much rain that I haven't caught a good day to roll out the sandblaster and shoot that small area.
Here are some pictures to show my progress:
Old 06-22-2019, 10:24 PM   #12
More photos of progress:
Old 06-22-2019, 10:26 PM   #13
Last photos for now:
