Old 07-21-2019, 04:19 PM   #1
harrij4
What goes here? (Interior bedside gap)
I just got some new interior bedside panels and they look great! But, there's a gap I need to solve for. It's between the interior panel and bedrail, about 3/4" toward the front, and basically 0" at the rear. What goes there? It looks like it needs to be a tapered filler or some sort. Is this the infamous "chrome strip"?
harrij4 is offline   Reply With Quote
Old 07-21-2019, 06:25 PM   #2
notsolo
notsolo's Avatar
Re: What goes here? (Interior bedside gap)
Yep chrome strip would be even with the top of bed side, strip is 66 3/4" long.
notsolo is offline   Reply With Quote
Old 07-22-2019, 06:53 AM   #3
72gmguy
72gmguy's Avatar
I don't remember a gap like that on mine. I will have to check.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 07-22-2019, 01:08 PM   #4
harrij4
That would be great. Anyone else who has a closeup of this intersection would be great. I don't mind fabricating a part, but have no idea what it should look like or how it is installed.
Old 07-22-2019, 08:11 PM   #5
1rippen6
Here is what you need, not an easy fab. item.
http://67-72chevytrucks.com/vboard/s...ighlight=panel
1rippen6 is offline   Reply With Quote
Old 07-24-2019, 10:56 AM   #6
Blazerowner
Blazerowner's Avatar
I’m hopeful the guy that makes the carpet strips will make these. Mine aren’t bad but it would be nice to have a new set.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 07-26-2019, 04:03 PM   #7
Stokester
The new bedside panels don’t fit. Should be snug against bedside. You might try and roll back the material and trim the backer board.
72 blazer 4x4 4" 35's
02 f150 work truck
15 f350 super crew long bed 6.7 4x4(stock but loaded)
02 f350 horse hauler 7.3 (need to sell)
Stokester is offline   Reply With Quote
Old 07-28-2019, 12:17 AM   #8
harrij4
So you're saying that the rigid backer board should stop at the back edge of the B-pillar and just the vinyl should continue up over the B pillar to the door opening? Can anyone with factory panels confirm this?
Old 07-28-2019, 09:20 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
OEM rear panels have a cardboard backing that (for lack of a better descriptor) conform to the contour bend of the B pillar and are affixed posterior from the B-pillar by the chrome strips along the top and screwed to the face of the B-pillar, the stands along the quarter panels, and to the rear "post" near the tailgate. This is the best example pic I can post at the moment. There is nothing amiss with your panels. A set of the chrome strips is what you need for best fitment.
It's also worth noting that for single wall tops there are two styles of upper stainless top to bedside trim pieces: one with and one without CST panels.
Old 07-28-2019, 01:43 PM   #10
harrij4
Mine is a single wall. If you've got one, I'd love a close up shot of what's happening at the B pillar and C pillar.
Old 07-28-2019, 02:56 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
When possible I will. At the moment my Blazer is having a few details tended to at a local resto shop: http://www.musclecarrestorations.com...Blazer-72-001/
If you post a pic of the top to bedside trim pieces you have we can try to sort out if they are CST or non-CST pieces as a lot of changes may have occurred since the Blazer was built. From what I recall, the non-CST pieces project down along the inner bedside and may interfere with the chrome panel retainer strips. The CST top to bedside strips are reproduced and are of good quality (or were). The panel strips can be re-chromed at a fairly reasonable cost if you locate a set.
Old 07-29-2019, 07:43 AM   #12
A1971Blazer
A1971Blazer's Avatar
From the factory assembly manual....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-29-2019, 12:11 PM   #13
harrij4
Attachment 1923533
Attachment 1923534
Oooh...that's useful. It looks like the panels do "warp" up over the B-pillar a bit. So, I'll have to form them accordingly.
I wonder if those strips can be approximated using aluminum or stainless j-channels. Those can be bought in various profiles at lengths up to 8ft.
Old 07-29-2019, 12:45 PM   #14
A1971Blazer
On my '70 I used some textured ABS plastic sheet for side panels...
I bought some aluminum "J" channel for the top trim and some push-on vinyl trim for the ends and bottom....
it fits so snugly that I only used about 3 or 4 black trim screws per side
1967 C10 Step side
1968 C10 Step side
Old 07-29-2019, 02:41 PM   #15
notsolo
notsolo's Avatar
Attachment 1923620
Attachment 1923621
Nice job with this....That's about as clean and tight a fit as your going to get.
Old 07-29-2019, 02:48 PM   #16
A1971Blazer
Thanks...
only regret......just wish I had made it a little taller to come flush with the bedside....
1967 C10 Step side
1968 C10 Step side
Old 07-29-2019, 03:41 PM   #17
Woodsloafer
Following - great information!
Woodsloafer is offline   Reply With Quote
Old 07-29-2019, 05:45 PM   #18
harrij4
Thanks for the help so far, this may all be old news, but given how hard it is to find this info I bet others have similar questions. Here's another weird wrinkle, it appears as though the door panel trim used for '67-'71 is the same profile, but just shorter pieces. Can anyone confirm that?
https://www.manestruckparts.com/stor...Category_ID=19
Old 07-29-2019, 06:29 PM   #19
A1971Blazer
The profile is very similar...the ends are finished a little different....I have a decent set of panel trim pieces...looking for a reputable plater to refinish them
1967 C10 Step side
1968 C10 Step side
Old 07-31-2019, 11:05 PM   #20
71K5Randy
71K5Randy's Avatar
I have heard of someone using multiple pieces of the reproduction door panel trim instead of the long rear strips. They said they cut the contoured ends where the two pieces met, and the seam didn’t stand out when installed.
71 K5 CST Blazer 350
70 Suburban 350
71 Chevelle SS 454
69 Olds 442 454 (yes, Chevy power!)
68 Camaro RS 327
66 Chevelle SS 396
Members I have met: 62cdan, 60case, daddymoo2, aotte1, 70shortfleet, countr, Cowboy#40, chevy71super, davischevy
71K5Randy is offline   Reply With Quote
Old 07-31-2019, 11:54 PM   #21
harrij4
I was thinking the same thing. That said, I wonder who is reproducing the door trim. They should easily be able to make "longer" versions of the door trim using the same roll-tooling.
Old 08-01-2019, 12:14 AM   #22
71K5Randy
71K5Randy's Avatar
Agree but that’s only if it’s rolled. Given how the ends are formed, it’s possible it’s all done in a long die.
70 Suburban 350
71 Chevelle SS 454
68 Camaro RS 327
66 Chevelle SS 396
Old 08-01-2019, 12:24 AM   #23
harrij4
Yeah. I'd put good money on roll-forming with a secondary operation to form the ends. Either way Im sure those tools are somewhere overseas and not likely to be willing to do "one-off work. Buying three sets of door trim, welding them together, grinding/polishing the welds, and having it plated would work, but sure sounds expensive!
Old 08-01-2019, 12:39 PM   #24
SeventyOne
Probably just as expensive as finding the correct strips and re-chroming
SeventyOne is offline   Reply With Quote
Old 08-22-2019, 08:35 PM   #25
harrij4
OK, I think after some serious searching (and concluding that I'll never find a set of OE strips) I think I've settled on using these stainless steel tile bullnoses. They won't have the exact profile of the original, but they're a nice radius and can be polished to a mirror finish.
Alternately, the local Home Depot has some chrome plated options
https://www.homedepot.com/p/Custom-B...DC98/305238415
