09-02-2019, 10:58 PM | #151 |
Re: 1966 C-10 build
Tearing this out
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039 She may not be the prom queen but at least she puts out.. |
09-02-2019, 11:05 PM | #152 |
Re: 1966 C-10 build
Got a wild hair to change a few items while doing the disc brakes and axle swap... thinking of these wheels
got a new bumper from my buddy had to get a new front to match it
09-02-2019, 11:10 PM | #153 |
Re: 1966 C-10 build
Of course it takes a bunch of work to get the brakes to work right. the power brake unit from CPP along with the power steering unit and all the associated parts is allot of work..
09-02-2019, 11:46 PM | #154 |
Re: 1966 C-10 build
the specs:
Front POL upper control arms -3 front coil springs Bell tech -2.5 drop spindles Torq thrust II 15x8 wheels ET -18 Tires cooper cobra 245x60x15 Rear -4 Rear coils 2"block Torq Thrust II 15x10 wheels ET -44 Tires Cooper Cobra 255x60x15 Front lower control arms shaved for clearance flipped rear shock mounts upper relocated front shocks relocated CPP disc brake kit Cpp power steering kit CPP hydra brake system
09-03-2019, 12:02 AM | #155 |
Re: 1966 C-10 build
09-03-2019, 07:48 AM | #156 |
Re: 1966 C-10 build
That looks perfect.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
09-03-2019, 09:36 AM | #157 |
Moderator
Re: 1966 C-10 build
Thos background pics sure looks like souther california.
09-03-2019, 10:15 AM | #158 |
Re: 1966 C-10 build
Looks great!
Check out my 66 C10 build here: http://67-72chevytrucks.com/vboard/s...d.php?t=546694 Look here, I also built a canoe: http://stevescedarstripcanoe.blogspot.com/ |
09-03-2019, 11:49 AM | #159 |
Re: 1966 C-10 build
That stance is perfect!
Black Bart-63 panel http://67-72chevytrucks.com/vboard/s...d.php?t=664660 |
09-03-2019, 12:47 PM | #160 |
Re: 1966 C-10 build
Nailed it!
09-03-2019, 05:04 PM | #161 |
Re: 1966 C-10 build
Dadgum, that looks good!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-03-2019, 05:59 PM | #162 |
Re: 1966 C-10 build
Thanks guys.
It didn't come cheap and it didn't come easy. But she's worth it. Now I need to convince her to stop smoking every time we go out. Its like taking out your best girl but you know she's a smoker.. Thinking of getting her the patch. LOL The new motor wont be done till next spring so we're gonna have to come to some sort of an agreement. Time to give her a bath and take her out for a test drive
09-03-2019, 05:59 PM | #163 |
Re: 1966 C-10 build
nor-cal
09-09-2019, 05:16 PM | #164 |
Re: 1966 C-10 build
When you see your truck from across the parking lot and say...…...YESSSS...…. Nailed it!
09-11-2019, 12:07 PM | #165 | |
But Found Her 25yrs Later!
Re: 1966 C-10 build
I'm going to post this in the Longbed thread.
09-15-2019, 09:48 AM | #166 |
Re: 1966 C-10 build
09-15-2019, 11:12 PM | #167 |
Re: 1966 C-10 build
Looks Killer Scott!!!!!
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
09-16-2019, 12:35 PM | #168 |
Re: 1966 C-10 build
Thanks everyone for the kind words. She still has quiet a ways to go but we are enjoying her as she sits right now.
We went to the Intervention this past weekend and had a good time. So many trucks it was overwhelming at times. Recognized a few trucks from here and chatted it up with as many as possible. Nothing but positive comments on the truck and a few offers to buy her as she sits.. Flattering but that's a HELL NO! still have lots to do to get her where we want her at so its little by little..
09-16-2019, 12:38 PM | #169 |
Re: 1966 C-10 build
Looking good Scott! Love the lettering on the door and everything else you did!
09-16-2019, 12:56 PM | #170 |
Re: 1966 C-10 build
Thanks buddy! havin a blast with her as we all should be doin.....
I had no idea but at the show this past weekend they had a little cruise She performed great... smokes a little at idle but that should be fixed this winter with a new motor...
09-18-2019, 11:54 AM | #171 |
Re: 1966 C-10 build
Looks good , But being another long bed owner over in the U.K. I may be biased .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
09-18-2019, 03:35 PM | #172 |
Re: 1966 C-10 build
09-18-2019, 03:44 PM | #173 |
Re: 1966 C-10 build
More work on the horizon:
I am convinced to replace the junk yard special small block that came with the truck to a robust BIG BLOCK... would go with another small block but hey!!! A man needs big toys to play with.. LOL Not quite sure what size yet but that will be governed by the over all price tag. also looking at a complete front suspension change over to possibly coil overs. love the lowered stance but want to be able to drive her everywhere without issues. Air bags might still happen but I'd rather not and just go with coilOvers if possible. Next will be a new transmission with OverDrive.. really need to be able to run her over 55mph. she hit 60 a couple times this past weekend but she was screamin.
11-08-2019, 01:26 PM | #174 |
Re: 1966 C-10 build
Well the time has come... The ol' tired and worn out junkyard motor has got to go. I am actually gonna miss that old power plant for some reason. It was always a challenge that I just loved to make her run right. Oh well. Spent the last few weeks getting a good block, machine work, heads, rotating assembly, cam, intake and all the other fun parts to make a new one.. This weekend I will be in the back of the secret laboratory building a new mouse to put in the truck. Pics to come.
11-08-2019, 04:30 PM | #175 |
Re: 1966 C-10 build
Did you get a big block or small? Always something to do on our trucks...that is what makes it fun! Now if we had unlimited funds!
